Like Tree64Likes
 Old 03-05-2012, 11:40 AM   #1
MS6_Newb's Avatar
Posts: 105   (View Stats)
MS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud of
Groaned at 7 Times in 3 Posts
This post is very useful and full of info. However, you asked if there are any more pros and cons on overboring an engine. There is one massive con when it comes to overboring. If you overbore you increase the chance of overheating your engine. Your cylinder walls act like a heatsink to spread the heat around evenly to all the coolant passages. If you overbore the is less material to spread the heat so hot spots occur and boils the coolant. Another thing is when you overbore the heat generated during the power cycle is greater which acts as a multiplier to the above. If your wondering why I say/know this, well, I talk from experience. I overbored a honda .020 over and ever since then the car ran hotter than normal. It over heated a few times until I upgraded the cooling system. I don't want to discourage anybody but let this be a fair warning to not go to big.
sarm1084 likes this.
MS6_Newb is offline   Reply With Quote
The Following 3 Users Say Thank You to MS6_Newb For This Useful Post:
l4nc3r (02-09-2015), sarm1084 (12-22-2018), TWOptSL0W (03-05-2012)
 Old 03-05-2012, 02:54 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
thanks, op updated
The Following User Says Thank You to TWOptSL0W For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f658/what-you-need-know-build-motor-106962/
2008 speed3 sedan - Page 9 This thread Refback 11-28-2013 06:48 PM
speed6 believe it spun a rod bearing. - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-28-2013 11:00 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
Motor build parts list ? jracer MazdaSpeed 3/6 - Big Turbo Builds 6 12-25-2010 06:20 PM
everything neded to build motor? ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-04-2009 11:14 PM
Page generated in 0.27009 seconds with 23 queries
