Like Tree3Likes
  • 1 Post By
  • 1 Post By
  • 1 Post By
 Old 06-27-2016, 08:04 AM   #1
torquemaniac's Avatar
Posts: 733   (View Stats)
Originally Posted by BuddySpeed3 View Post
Thanks that's interesting. What turbo were you running at the time? And what was your PCV setup like when this happened?
I was running the same Holset HY35 I have now (journal bearing turbo)
I had the PCV and valve cover vented to atmosphere (but keep im mind I had 3 broken pistons)
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
BuddySpeed3 (06-28-2016)
Excessive Crankcase Pressure and Blow By skemmm Mazdaspeed3/6 General Discussion 10 04-01-2018 05:03 PM
Need Help! Excessive positive crankcase pressure resulti in RMS leak jayadams66 MazdaSpeed 3 - Engine, Transmission & Driveline 1 10-24-2015 10:32 PM
OCC and crankcase pressure testing diaries Matt@DamondMotorsports Damond Motorsports 125 05-19-2014 06:02 PM
BT Crankcase venting ideas and current setups PapaSmurf Mazdaspeed3/6 General Discussion 66 04-07-2014 09:10 PM
Negative Crankcase Pressure kore2000 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-16-2010 07:56 AM
Page generated in 0.24143 seconds with 22 queries
