| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() | | #41 | ![]() |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score I can test one if needed. My car has the Balance Shaft Deleted. GTX3076 blah blah blah etc etc. I have tried JBR, CP-E and Corksport. With the BSD, none of them are nice enough to make you want to drive the car for a long period of time. The engine is firm sure, but some of the enjoyability is gone. With BSD and stock PMM/TMM, there are no issues what so ever. If your mount plays well with BSD cars, then it will be WIN.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following 3 Users Say Thank You to mrmonk7663 For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score Went back to stock (sortaPMM on a daily driver?) PMM today, the drone from the CS PMM was much more noticeable and when I took it off I found the rear bushing had failed. Can't wait to see how this pans out but short term I've used hose clamps as inserts on the stocker...rear view works again and I get vibes only pushed hard and somewhat at 2k-3k but no cabin noise. But it isn't respectable. It's mildly terrifying. And that actually makes it quite appealing. - Mazda 3 MPS review, Matthew Jones, Top Gear.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() | | #44 | ![]() |
| Not Ranked : 0 score ImageUploadedByTapatalk1415251755.337291.jpg After trying jbr, corksport, and cpe...I went to this today. 1/4" aluminum on one side, 1/8 epdm rubber on opposite side. My car has the balance shaft deleted. With the pmm setup like all the vibes associated with the other mounts are gone. The mods limit the movement of the pmm, which will keep it working longer without exploding and minimize wheel hop.
| The Following 4 Users Say Thank You to mrmonk7663 For This Useful Post: | Addikted To Boost (11-09-2014), free_refil (02-08-2015), Mauro_Penguin (11-06-2014), mr_mazda329 (12-03-2014) |
![]() | | #45 | ![]() |
| Not Ranked : 0 score how did you secure the rubber @mrmonk7663;
![]() | | #46 | ![]() |
| Not Ranked : 0 score It was a very tight fit...I had to leverage the mount and push it in there, then pull it through with pliers. That should secure it enough. But above and beyond that, I punched some holes in the rubber with an awl and used 2 small zipties to fasten it together just in case.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN | |
![]() | | #47 | ![]() |
| Banned ![]() Join Date: Nov 2011 Location: McGuire AFB NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score I miss the stock pmm but i cant complain about how much less movement there is |
![]() | | #48 | ![]() |
![]() Join Date: Dec 2013 Location: Mountain House, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 596
| Not Ranked : 0 score Any updates on this?
__________________ 2013 Mazdaspeed3 Crystal White Pearl [Damond Motorsports RMM & SSP] [Maisonvi Grooved Dessert Beagle Knob] [COBB AP V3] [CorkSport HPFP Internals, SRI, TIP, TMIC & LEDs] [Sure M3 TP] [cp-e Triton CBE] [GFB BOV] [91 Octane Purple Drank Tuned - 260whp/290wtq - VDyno] Parts to Install: [JBR 3" TRU-3" Intake & Solid Shifter Bushings] [DDM HID Kit] |
![]() | | #49 | ![]() |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
| Not Ranked : 0 score On schedule more or less. Check in this weekend, I'll have more for you then.
__________________ |
| The Following 2 Users Say Thank You to Farhan@DM For This Useful Post: | my2k13speed3 (11-25-2014), WetzMS3 (11-26-2014) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score I'm going to go ahead and call this the weekend starting now due to the holiday, i'll take an update now.......
![]() | | #51 | ![]() |
https://cdn.shopify.com/s/files/1/04.../pmm1.jpg?1334 The first tester is on and running. The rest of the test parts ship out Monday. Wait till you guys see who we have lined up to test these.
__________________ | |
| The Following 5 Users Say Thank You to Farhan@DM For This Useful Post: | Chuthor (11-29-2014), djrich26 (11-28-2014), Mauro_Penguin (12-04-2014), my2k13speed3 (11-28-2014), WetzMS3 (11-28-2014) |
![]() | | #52 | ![]() |
![]() Join Date: Dec 2013 Location: Victoria, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score I could do the southern hemisphere testing for you if you ship one out
![]() | | #53 | ![]() |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
| Not Ranked : 0 score That sounds like a really bad innuendo.
__________________ "I apologize for nothing!" - Hedonismbot ![]() |
| The Following User Says Thank You to aromig For This Useful Post: | Matt@DamondMotorsports (11-29-2014) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score If your a sick minded person I suppose it does lol. We are all sick here I guess.
| The Following 2 Users Say Thank You to 1cms1 For This Useful Post: | aromig (11-28-2014), Matt@DamondMotorsports (11-29-2014) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Can't wait to read some reviews from the testers, I love my DM RMM would love to have a matching PMM!
| The Following 3 Users Say Thank You to my2k13speed3 For This Useful Post: |
![]() | | #56 | ![]() |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
Any testers with a balance shaft delete, Sent from my iPhone using sausage fingers
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals | |
| The Following 3 Users Say Thank You to macdiesel For This Useful Post: |
![]() | | #57 | ![]() |
We'll see if vibes on ours are low enough for him to leave ours on where others were removed.
| The Following 8 Users Say Thank You to Farhan@DM For This Useful Post: | aackthpt (12-01-2014), Easter Bunny (12-01-2014), England15j (11-30-2014), Justin@Freektune (12-03-2014), macdiesel (11-30-2014), Mauro_Penguin (12-04-2014), mr_mazda329 (12-03-2014), WetzMS3 (11-30-2014) |
![]() | | #58 | ![]() |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score We already have our testers set. But we will be sure to do plenty of upside-down driving and launching testing to ensure that the mount will work on Aussie MPS3's. We appreciate all our customers down under, and we do what we can to meet our customer's needs. Here's our site specifically for the Australian market: click here |
| The Following 6 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | 1cms1 (12-01-2014), ArmanRus (12-04-2014), Easter Bunny (12-01-2014), Farhan@DM (12-02-2014), free_refil (02-08-2015), mr_mazda329 (12-03-2014) |
![]() | | #59 | ![]() |
![]() Join Date: Sep 2012 Location: Los Angeles, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score love my rmm can't wait
__________________ Black Vue Dash Cam- Cobb AP V3 (Stratified tune 4 gal E85 mix) - M2 Downpipe - Swift Springs - HKS SSQV4 - Sure V2 SRI - JBR TIP - ACDelco Rear Camber Arms - West-End Custom Alignment - White Line Bump Steer - KMD Internals - Hankook Evo V12 245-40-17 - |
![]() | | #60 | ![]() |
![]() | | #61 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
| Not Ranked : 0 score Niiiice.
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() | | #62 | ![]() |
![]() Join Date: Jan 2009 Location: Tucson/Vegas
Rep Power: 789 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,252
Groans: 55
| Not Ranked : 0 score these testers need to start giving feedback. like now. lol
__________________ 09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals 97 Miata Daily Driver 04' Mazdaspeed Miata Track Car Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing |
| The Following 2 Users Say Thank You to mr_mazda329 For This Useful Post: | Cataphract_40 (12-14-2014), Farhan@DM (12-04-2014) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score Fo reals! Sent from my iPad using my stinky fingers
![]() | | #64 | ![]() |
| Not Ranked : 0 score So since you guys are testing the PMM, does that mean you guys are working on a TMM?
![]() | | #65 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
| The Following User Says Thank You to btstarcher For This Useful Post: | jdmage_mx5 (12-04-2014) |
![]() | | #66 | ![]() |
| Not Ranked : 0 score No I'm on the CPE stage 2 RMM but I'm curious to hear the reviews on the MD PMM.
![]() | | #67 | ![]() |
| Not Ranked : 0 score I fucken need this more then ever. My pmm just took a massive shit. Please sell asap. Lol
![]() | | #68 | ![]() |
![]() Join Date: Mar 2013 Location: Fort Campbell, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score Subbed Sent from my iPhone using Tapatalk |
![]() | | #69 | ![]() |
Groans: 55
| Not Ranked : 0 score Damn it. Here I go checking for updates and this guy just subs to the post. Use the thread tools to subscribe. You don't have to post in the thread.
| The Following 7 Users Say Thank You to mr_mazda329 For This Useful Post: | Addikted To Boost (12-09-2014), ArmanRus (12-08-2014), aromig (12-07-2014), cshunter (12-07-2014), magicka (12-07-2014), Mauro_Penguin (12-11-2014), Raider (12-08-2014) |
![]() | | #70 | ![]() |
![]() Join Date: Jul 2014
I see a broken Ingalls ETD mount? No? Looks like the stock passenger mount is fine.
__________________ "This is your life. And it's ending one minute at a time." | |
| The Following User Says Thank You to WFO! For This Useful Post: | Koke382 (12-10-2014) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score Ingals broke, studs broke motor went side ways, car is parked in my garage till the weekend when i have time to fix it.
![]() | | #72 | ![]() |
![]() Join Date: Jan 2010 Location: Lake Villa, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,503
| Not Ranked : 0 score Are you supporting the motor on the pass side? If not you're probably putting some stress on that trans mount if it's still stock.
__________________ Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah 4/15/12 dynojet results: 305whp / 355 tq |
| The Following User Says Thank You to JTMS3 For This Useful Post: | Koke382 (12-10-2014) |
![]() | | #73 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score Man I'd like to see an update on this....who the EFF is testing this? I need to know if I should sell my JBR 80 or not (if the vibes are reduced and it is track proven, I will support the shit out of this!).
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post: | JTMS3 (12-10-2014), Mauro_Penguin (12-11-2014) |
![]() | | #74 | ![]() |
I know a couple people just received them and are installing them.
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit Last edited by Koke382; 12-10-2014 at 08:05 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Koke382 For This Useful Post: | JTMS3 (12-10-2014) |
![]() | | #75 | ![]() |
| Not Ranked : 0 score I will be testing the PMM next week. My car has the Balance Shaft Deleted. I will post a full review of this mount vs Corksport vs JBR vs CPe vs modified stocker when I am done testing.
| The Following 12 Users Say Thank You to mrmonk7663 For This Useful Post: | aackthpt (12-10-2014), atvfreek (12-10-2014), cshunter (12-11-2014), Easter Bunny (12-10-2014), England15j (12-10-2014), Farhan@DM (12-10-2014), Koke382 (12-10-2014), macdiesel (12-10-2014), magicka (12-10-2014), Matt@DamondMotorsports (12-10-2014), Mauro_Penguin (12-11-2014), SparkySparks (12-10-2014) |
![]() | | #76 | ![]() |
| Not Ranked : 0 score Tight. I need this for sure to make my decision; BSD will be engaged on my car in the spring.
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | Koke382 (12-10-2014) |
![]() | | #77 | ![]() |
| Not Ranked : 0 score I can tell you right now without reviewing the DM mount that I would advise AGAINST JBR or Corksport with BSD delete. CP-E is acceptable, but vibes a descent amount, and much more so in the cold.
| The Following 6 Users Say Thank You to mrmonk7663 For This Useful Post: | atvfreek (12-10-2014), Easter Bunny (12-10-2014), HawkeyeGeoff (12-10-2014), JTMS3 (12-10-2014), Koke382 (12-10-2014), Mauro_Penguin (12-11-2014) |
![]() | | #78 | ![]() |
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD | |
![]() | | #79 | ![]() |
![]() Join Date: Jan 2012 Location: Watertucky, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
It's like a massage every time I drive it! I actually don't mind the vibes anymore Step 1: tapa Step 2: ... Step 3: Profit
__________________ moles do it dirty in the dark... ![]() ![]() Performance: AP V2 // GFB Respons Dual Port BOV // JBR 80 Duro PMM/TMM // JBR 88 Duro RMM // JBR RSB // JBR TIGs for Intake Mani and Throttle Body // HTP 3" TIP and SRI // JBR Shift Weight // JBR EGR Block Off Kit // SonicTuning Coilovers (S3) // TWM STS and a weighted shift knob // BNR S3 V2 // UR catted DP // CS TP // Guardian Angel // 3 port EBCS // NGK LTR7IX-11 plugs // FREEK Tune // | |
| The Following User Says Thank You to mole For This Useful Post: | HawkeyeGeoff (12-10-2014) |
![]() | | #80 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score @Nano91; will be installing these tomorrow. Not sure if live pics have been posted yet but here it is.10850058_10204264364942895_2192871380553019610_n.jpg
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
| The Following 11 Users Say Thank You to specvspeedfreak For This Useful Post: | aromig (12-10-2014), covelife1016 (12-11-2014), Easter Bunny (12-10-2014), Etipp98 (12-11-2014), LatinKraze (12-12-2014), Matt@DamondMotorsports (12-10-2014), Mauro_Penguin (12-11-2014), my2k13speed3 (12-10-2014), neganox (12-10-2014), WetzMS3 (12-11-2014), xfeejayx (12-10-2014) |
| Display Modes | |
| Introducing the all new Damond Motorsports OCC | Matt@DamondMotorsports | Damond Motorsports | 85 | 08-10-2015 07:24 PM |
| Damond Motorsports OCC V1 review | Justus | Damond Motorsports | 5 | 10-15-2013 07:02 PM |
| Welcome Damond Motorsports | Haltech | Damond Motorsports | 46 | 08-25-2013 09:56 AM |
