  • 1 Post By Justus
 Old 10-14-2013, 11:39 PM   #1
Justus's Avatar
Posts: 14   (View Stats)
Justus is a splendid one to beholdJustus is a splendid one to beholdJustus is a splendid one to beholdJustus is a splendid one to beholdJustus is a splendid one to beholdJustus is a splendid one to beholdJustus is a splendid one to behold
Default Damond Motorsports OCC V1 review
So I went and split this up as most of this part of my writeup is geared towards feedback. I posted results of the kit after a 3400 mile oil change here:
As it has already been mentioned in a few other threads, the time frame in getting this can be delayed. I believe it took a little over two months from when I first placed my order until I actually had the kit, but Matt did email me a few times over that period to tell me it was continuing to be delayed (albeit was usually prompted by me asking what the status was).
He did continuously offer a refund in all of the correspondence, so I knew I could rely on him being good for the transaction regardless.
In the end, Matt offered me a discount on the kit to make up for the delay.
On to the installation:
I used Matt's installation guide on the website for the kit I had bought (Version 1). Everything was pretty straight forward with a couple minor nuances. The biggest being no mention was made of the hose coupler.
After removing the stock Z rubber section, I went to install the kit supplied tubing on the PCV nipple and found that the diameter and pliability of the hose made it extremely difficult to manipulate. So much so that I had to zip tie a bend on to the hose to keep the angle I needed to get it on the nipple. That one portion probably took me 2 hours and series of cuts on the hands to get in back on the PCV nipple.
After I got it on, I took a break and went through everything again and found a hose elbow coupler. It immediately dawned on me that there was no apparent reason to remove the PCV side of the stock hose as this coupler was probably supposed to be used to mate the stock hose to the kit hose (which would save a ridiculous amount of time).
Unfortunately neither the kit invoice (contents list) nor do the website instructions make mention of this coupler. And the instructions very much tell you to remove the stock hose...so either way I was going down that path.
Being that I had already monkeyed the thicker tubing onto the PCV, I decided not to touch it any further.
Here it is installed:
My results are link up at the top and it is a pretty significant amount of oil being collected.
Big props to Matt for designing a great kit and please incorporate my feedback into your website instructions so no one else makes the same mistake I did
08 Mazdaspeed 3 (Daily) -Cobb SRI, Turbosmart BOV, SU rear mount, Damond V1 OCC, More coming soon!!
'12 F-150 Ecoboost Screw XLT HD Tow (Daily) - CarShow NAV, Ford Autostart, Airaid intake
97 TT 6spd Supra (Garage) - 3.4L Titan Stroker, Garrett GTX 4294, 857 RWHP @ 30PSI
My Youtube vids-> http://www.youtube.com/user/justusS1
Justus is offline   Reply With Quote
The Following 2 Users Say Thank You to Justus For This Useful Post:
Matt@DamondMotorsports (12-27-2013), SeeMeGovan (02-15-2014)
 Old 10-14-2013, 11:51 PM   #2
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
what is your profile picture of at psi
 Old 10-15-2013, 12:00 AM   #3
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
Groans: 31
The beast supra in his sig?
kby is offline   Reply With Quote
 Old 10-15-2013, 12:03 AM   #4
Justus's Avatar
Correct
Newest build is going to be even more crazy...new manifold, quick-spool valve, little more boost. Hit 901 at 30psi before running out of room on the MAP sensor.
Battling a new issue now on that car
The Following User Says Thank You to Justus For This Useful Post:
kby (10-15-2013)
 Old 10-15-2013, 10:45 AM   #5
Are you located in portland then?
you weren't at harborf reight tools yesterday were you lol
 Old 10-15-2013, 07:02 PM   #6
Justus's Avatar
Negative, I'm in WA...car is still there at PSI though.
Welcome Damond Motorsports Haltech Damond Motorsports 46 08-25-2013 09:56 AM
Page generated in 0.28041 seconds with 22 queries
