 Old 04-17-2015, 10:39 AM   #1
speed3black87's Avatar
Posts: 75   (View Stats)
speed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud of
Groaned at 8 Times in 3 Posts
Default Damond OCC Gen2 speed 3 version1
How the shit do you get the the clamps on the PCV valve, I have bigger then average hands but even with needle nose pliers its crazy tight... I was under my car for 2 hours trying to just get my hands on it. The IM part no problem but the PCV is near impossible. Suggestions?? Is there another angle I could use to get to it, something I can remove to make room?
2012 MAZDASPEED 3 BLACK MICA -COBB SRI - COBB TIP - STEBRO CBE -ULTIMATE RACING CATLESS DOWNPIPE- STREET UNIT TEST PIPE -AUTOTECH INTERNALS - STREET UNIT TMIC - CORKSPORT TRUNK BRACE- STREET UNIT RMM (BROKE) JBR 88A RMM - CPE PASSENGER MOUNT - CPE TRANSMISSION MOUNT -COBB ACCESSPORT -SNOW PERFORMANCE STAGE 2 BOOST METH INJECTION KIT- DAMOND OCC -XXR 531 18X9 HYPER SILVER 235/40/18 GFORCE TIRES- PIRRELI PZERO RACING SLICKS ON OEM RX8 R3 RIMS- KSPORT SPEC AR COILOVERS - TURBO SMART BPV-DENSO ITV22'S
STRATIFIED TUNE BY LEX
speed3black87 is offline   Reply With Quote
 Old 04-17-2015, 11:46 AM   #2
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
I'm assuming you're doing this without removing the intake manifold. It's just a pia. I cut my hands up pretty bad trying to do it without removing the manifold. You just have to work at it.
tapatalk, it sucks for free.
acousticdefbot (04-18-2015)
 Old 04-17-2015, 12:14 PM   #3
IMASA's Avatar
Posts: 209   (View Stats)
Use long, long needle nose pliers, get a set which have ones that are straight, 45 and 90 degree bends.
Soak the hose in hot water for a few minutes, which allows them to be more flexible
I bent one end of the hose at a 45/90 angle and held it in place with a zip tie. It made it easier to slip on the PCV valve.
The Following User Says Thank You to IMASA For This Useful Post:
monkey.bones.007 (04-17-2015)
 Old 04-17-2015, 03:38 PM   #4
good idea's for sure. zip ties, duh. I will take another shot at it this weekend. thanks fellas
 Old 04-17-2015, 08:30 PM   #5
5/8" barbed brass fitting. Remove from intake manifold and connect the two. Careful yanking on hose. Broken PCV is common. And many dealers do not stock and is not something you can get at a parts store.
shaneski (04-25-2015)
 Old 04-18-2015, 12:27 AM   #6
acousticdefbot's Avatar
Posts: 319   (View Stats)
acousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the world
the pcv valve hose without removing the intake manifold is a motherless motherfucker. it's possible, but you're asking for punishment on your hands. once you get the stock hose off, you can rotate the valve into a better position to slide it all the way on. a touch of oil helps. what really helped me was a pair of miniature pliers.
those things saved me from a random act of violence. beyond that it's just a matter of leverage. make sure you exercise persistence and foul language. that helps as well.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
 Old 04-18-2015, 12:46 AM   #7
Rorok's Avatar
Posts: 140   (View Stats)
Rorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond reputeRorok has a reputation beyond repute
Removing the dipstick gave me some room to work with. Using really long pliers worked as well. I picked them up at harbor freight for like 10 bucks. Really good investment.
2011 MS3 - Molestial Blue / JBR Trilogy / AP V3 / HTP 3'' Intake / Autotech FP Internals / Cobb XLE BPV / Grimmspeed EBCS / Cp-E Triton / UR testpipe / EGR Delete / MD OCC / Freektuned
Rorok is offline   Reply With Quote
 Old 04-18-2015, 10:10 AM   #8
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
So happy I decided to install mine when I took my IM off to clean the valves.
 Old 04-18-2015, 01:29 PM   #9
well, is removing the intake manifold something easy? I plan on doing it tomorrow as its half done already ( everything is mounted just need to connect the hoses )
 Old 04-18-2015, 02:19 PM   #10
Rorok's Avatar
Why not try to remove the dipstick, it'll save you some time. There's a guide on here on how to remove the intake manifold
Here's to save you from searching.
How-To: Injector & Intake Manifold Removal
The Following 2 Users Say Thank You to Rorok For This Useful Post:
monkey.bones.007 (04-18-2015), speed3black87 (04-20-2015)
 Old 04-20-2015, 05:12 AM   #11
g00s3y's Avatar
Groans: 438
IMO, yes it's easy. Follow that how-to posted above, and clean out your intake valves while you are at it, it's worth it.
 Old 04-25-2015, 08:05 PM   #12
akira4978's Avatar
Posts: 23   (View Stats)
akira4978 has a spectacular aura aboutakira4978 has a spectacular aura about
I installed an OCC from another manufacturer, same issue, clamp on PVC is facing UP. Couldn't get it off, like Raider said, 5/8" brass barb from home depot, splice PVC hose to new OCC hose. MUCH easier and time saving.
2008 Mazdaspeed 3 - Mods: Spin on Filter Conversion | ETS 3.25" TMIC | CPE CAI w/ Amsoil Air Filter | JBR EGR Delete | JBR Stage 2 OCC | JBR Boost Tubes and Silicone Hoses | JBR Round Shift Knob | JBR TB TIG & Coolant BP | JBR Reverse Lockout Guide | Autotech HPFP | Cobb AP v.3 | Cobb RMM | Cobb TIH | Cobb Shift Weight | Corksport BPV | Corksport STS l Corksport Shifter Bushings | Matt Damond PMM | Bosch 3 BAR Sensor
akira4978 is offline   Reply With Quote
 Old 04-25-2015, 08:56 PM   #13
castrocastro's Avatar
Posts: 437   (View Stats)
castrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the worldcastrocastro is the leader of the world
Installed the OCC today as well. Removed the intake manifold to check out the valves.
It was really simple removing the hose from the PCV and intake manifold.
I would highly suggest removing the IM for installing a OCC
castrocastro is offline   Reply With Quote
 Old 04-28-2015, 04:28 PM   #14
One of these mofo's?? Makes total sense!
 Old 04-28-2015, 06:10 PM   #15
akira4978's Avatar
That's what I used, and made sure the pcv hose had 'support', and not bearing the full weight of the fitting and the hose.. basically finding a tie off point, just do what looks right to you.
The Following User Says Thank You to akira4978 For This Useful Post:
speed3black87 (04-29-2015)
 Old 04-29-2015, 05:28 AM   #16
GCPhotographers's Avatar
Posts: 1,198   (View Stats)
@kritz; was telling me about this not too long ago. now it makes sense but does it have to be brass (weight reason) or can it be plastic. Just curious.
2012 Black MazdaSpeed3
Fuel: 91 & 93 Octane /
COMING SOON
 Old 04-29-2015, 08:09 AM   #17
I wish I could thank you 10 more times, this makes install about 100 billion times easier.
The Following User Says Thank You to speed3black87 For This Useful Post:
akira4978 (05-01-2015)
 Old 05-01-2015, 06:02 PM   #18
akira4978's Avatar
No problem man, trust me, I made several attempts to get that top clamp off on the PVC, I know the frustration, and I finally the idea of splicing hit me. And yeah, it made the install painless...
How to: Install a speed perf6rmanc3 PI Kit on your gen2 PapaSmurf 2010 MS3 - How-To's 9 09-13-2015 03:28 PM
Page generated in 0.35427 seconds with 30 queries
