Like Tree97Likes
 Old 08-14-2015, 08:36 AM   #81
Will you post video from a speed3 on idle, idle with AC, WOT etc to see the noise, vibes and vibration from the interior of a speed3 with your 3 mounts ???
It will be nice
Which one of us?
Stock motor with balance shaft?
There is a wide range of testers with varying mods because NVH can vary quite a bit.
Enki (08-14-2015)
 Old 08-14-2015, 09:05 AM   #82
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I want stock motor with balance shaft deleted.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 08-14-2015, 09:17 AM   #83
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Which one of us?
Hell the road and tires you are on can make a big difference in NVH.
These reviews are all somewhat subjective too. So many factors and so many different opinions on what is "too much" NVH
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
Farhan@DM (08-15-2015), Mauro_Penguin (08-14-2015), WetzMS3 (08-14-2015)
 Old 08-14-2015, 09:47 AM   #84
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
It will be nice
I'll get that today sometime. I'm stock motor with the balance shaft intact.
tapatalk, it sucks
monkey.bones.007 is online now   Reply With Quote
 Old 08-14-2015, 11:40 AM   #85
Gunslinger's Avatar
Posts: 38   (View Stats)
Gunslinger is a splendid one to beholdGunslinger is a splendid one to beholdGunslinger is a splendid one to beholdGunslinger is a splendid one to beholdGunslinger is a splendid one to beholdGunslinger is a splendid one to beholdGunslinger is a splendid one to behold
Hnnnngrh! I need this mount! Mine is getting worse by the day.
Gunslinger is offline   Reply With Quote
 Old 08-14-2015, 12:17 PM   #86
aackthpt's Avatar
Posts: 1,450   (View Stats)
Agreed, and this is one of the problems with the beta test groups, they are usually coming from jbr 88 trilogies. Telling me it's a lot better than that does me no good when I want to go from stock mounts to DM threesome, or in my case having DM RMM and adding PMM then do I go insert or full threesome. Particularly when I specifically don't want racecar noise... Except I'm sure I want the shifting improvement LOL.
Tapnstalk
2013 'speed3, silver
Stage Bro
 Old 08-14-2015, 12:23 PM   #87
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
The Following 7 Users Say Thank You to Enki For This Useful Post:
Farhan@DM (08-15-2015), maisonvi (08-14-2015), Matt@DamondMotorsports (08-17-2015), Mauro_Penguin (08-14-2015), mrmonk7663 (08-14-2015), rolanblack (08-15-2015), WetzMS3 (08-14-2015)
 Old 08-14-2015, 01:19 PM   #88
Tapnstalk
I did not have the JBR mounts on my car. I went from DM RMM/PMM and OEM TMM to the full threesome. As I mentioned in my review, NVH did not increase in any notable way.
Prior to the DM PMM, I had a DM RMM and CS PMM. My review and comparison on the NVH between the two are in the reviews thread for the PMM. At that point, I was still on a stock block with balance shaft.
aackthpt likes this.
 Old 08-14-2015, 01:39 PM   #89
aackthpt's Avatar
Thanks. I may have missed it before, that does definitely give me a useful data point. And says there's no reason I shouldn't go all the way if I'm OK with the PMM/RMM.
Tapnstalk
Stage Bro
The Following User Says Thank You to aackthpt For This Useful Post:
 Old 08-14-2015, 01:42 PM   #90
Tapnstalk
Precisely. I expected a drastic change adding the TMM. Instead, the only drastic change was in shifting, and what an awesome change that was.
 Old 08-14-2015, 02:35 PM   #91
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
My videos were not imbedding so that the YouTube player would play here on MSF.
Raider PM'd me and showed me how to fix that.
So now the videos are there to play. You may have missed them as only being a text link.
DM TMM testing and reviews diary
www.tunedbynishan.com
Mauro_Penguin (08-15-2015), monkey.bones.007 (08-17-2015), WetzMS3 (08-14-2015)
 Old 08-14-2015, 08:20 PM   #92
mrmonk7663's Avatar
Thank you Enki. This is exactly what I needed. Looks like there is a TMM in my future after all
The Following 5 Users Say Thank You to mrmonk7663 For This Useful Post:
Enki (08-14-2015), macdiesel (08-14-2015), Mauro_Penguin (08-15-2015), MD1032 (08-14-2015), WetzMS3 (08-14-2015)
 Old 08-17-2015, 07:10 AM   #93
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Ok so lets start this off by saying my car is my DD. i drive 25 miles every day around 60% highway 40% city. My engine is stock with the BSD and makes 500whp.
My mount setup previous to this was Cp-e Stage 2 RMM, DM PMM, and Gen Pu TMM with the CS insert. This setup was great and did well, but i still knew i had some slop being caused by the TMM. I could feel the engine shifting when i turned the car off(which no longer happens with the new TMM) as well when i would try and powershift 3-4.
After what seemed like "2 weeks" worth of waiting Farhan finally hit me up and told me the TMM's were ready to go. The install it self was very straight forward. Remove old mount, unbolt shift cables, and put new mount in. The biggest problem for me like all of the Beta testers was lining the top plate up with the bushing. Really though that wasn't even bad.
So now that everything is in i'm preparing my self for JBR 88 duro type savagery where my dash wants to jump out of the car, and my rear view mirror is shaking violently asking me wtf have i done. To my surprise when i started up the car for the first time i actually had LESS NVH than my stock TMM with the cs insert. This is on a cold start as well. So i wait for the rpms to come down and the ONLY spot where i saw my rear view shake was in the 1700-1400 rpm range. The review also shakes with the A/C, but really thats something i expected.
I have a HTP 4" with a 1000rpm idle and this thing is seriously smooth. I have no seat vibrations at all. I have some vibes that i feel transmitted through the steering wheel at idle but that's it. There is some additional vibration during take off in that 1400-1700 range on my car where i can see the rear view mirror shake. That is the only negative i've found to this mount so far. Driving around there are really 0 added vibes at least in my car from the TMM. i will update this post if that changes.
As far as clutch chatter goes i've had a ACT 6 puck since i purchase the car. So i've always had the chatter. i don't find it to be any louder with the new TMM. One thing that is a little bit louder is gear noise when decelerating but i had to be driving with the radio off to actually notice it.
As far as WOT operation goes this thing functions flawlessly. dialed up 28psi in 3rd and power shifted to 4th and no problems what so ever. Engine stayed in place and the shift engagement was noticeably smoother. I'm doing my best not to be biased in this review, but this TMM really is a good product.
TLDR; TMM is fantastic. The only place of serious vibration is 1400-1700rpm or at idle with the A/C on.
The Following 8 Users Say Thank You to 2.0t03speed For This Useful Post:
Farhan@DM (08-17-2015), macdiesel (08-17-2015), Matt@DamondMotorsports (08-17-2015), Mauro_Penguin (08-17-2015), monkey.bones.007 (08-17-2015), mrmonk7663 (08-17-2015), MS3Shadow (08-17-2015), WetzMS3 (08-17-2015)
 Old 08-17-2015, 01:36 PM   #94
HoodieWeather's Avatar
Posts: 4   (View Stats)
HoodieWeather has a little shameless behaviour in the past
Very with what I got from Purple Drank, car is fast and I love it. <3 It's like a freight train right now. w00t
HoodieWeather is offline   Reply With Quote
 Old 08-17-2015, 01:42 PM   #95
Easter Bunny (08-24-2015), Mauro_Penguin (08-17-2015), monkey.bones.007 (08-17-2015), MS3Shadow (08-17-2015)
 Old 08-17-2015, 02:12 PM   #96
aackthpt's Avatar
Maybe remove the hoodie during the hot weather.
Tapnstalk
Stage Bro
 Old 08-20-2015, 12:10 PM   #97
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Just placed my order for the threesome. Currently mounted with CP-e, but loved all the things I heard about these. More daily driver feel, while still holding it steady like a racecar, sounds like perfection.
The Following 4 Users Say Thank You to g00s3y For This Useful Post:
Matt@DamondMotorsports (08-20-2015), Mauro_Penguin (08-20-2015), neganox (08-20-2015), WetzMS3 (09-02-2015)
 Old 08-20-2015, 01:29 PM   #98
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Coupon isn't working for me, anyone else having issues with it?
The Following 2 Users Say Thank You to mr.speedy3 For This Useful Post:
Matt@DamondMotorsports (08-20-2015), WetzMS3 (09-02-2015)
 Old 08-20-2015, 08:51 PM   #99
macdiesel's Avatar
Posts: 825   (View Stats)
No problems here. Just ordered the TMM to complete the Damond Dynasty.
The Following 2 Users Say Thank You to macdiesel For This Useful Post:
Matt@DamondMotorsports (08-20-2015), MS3Shadow (08-20-2015)
 Old 08-20-2015, 09:13 PM   #100
Name is longer than yours
Posts: 209   (View Stats)
PM'ed, I had one other guy have issues.
The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post:
mr.speedy3 (08-21-2015)
 Old 08-20-2015, 10:16 PM   #101
mrmonk7663's Avatar
What is the coupon code and when does it expire? I must have missed it as I can't find it or don't know where to look.
Thanks!
 Old 08-20-2015, 10:35 PM   #102
I would like to know about this coupon code as well. Looking to get the TMM & PMM or all Three.
Sent from my HTC M9
 Old 08-21-2015, 07:00 AM   #103
Sent from my HTC M9
Just get all three. Don't be a...... giant pussy. YEEEAAHHHHH
WetzMS3 likes this.
adamizme (08-21-2015), WetzMS3 (09-02-2015), zenit (08-29-2015)
 Old 08-21-2015, 07:12 AM   #104
Well I already have the CPE Stage 2 RMM.
Sent from my HTC M9
 Old 08-21-2015, 07:19 AM   #105
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Sent from my HTC M9
I upgraded from that one to Damond. And I do mean upgraded.
2007 Mazdaspeed3 GT
 Old 08-21-2015, 07:22 AM   #106
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Sent from my HTC M9
Coupon code was for those that have previously bought other mounts. Side mounts package is available from the website.
 Old 08-21-2015, 08:09 AM   #107
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Nicely done guys! I will probably be changing my JBR mounts to these VERY soon!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 08-21-2015, 08:17 AM   #108
dinoxor's Avatar
Posts: 346   (View Stats)
dinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the world
I have a feeling we're going to see an influx of used TMM in the for sale section fairly soon...
But these reviews were very helpful and I will place an order for one fair soon!
Black Mica 2008.5
CS SRI+TIP • AT HPFP • TP
dinoxor is offline   Reply With Quote
 Old 08-21-2015, 10:28 AM   #109
adamizme's Avatar
Posts: 183   (View Stats)
adamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the world
I switched from DM RMM to CPE s2 RMM and didn't view it as downgrading. It seemed to hold the motor just as well with less NHV. That being said, I am keeping my DM RMM in the garage because I have reservations about trusting the rubber on the CPE to last forever. Also, I have the DM PMM and plan to get the TMM before too long. Their mounts are just plain awesome.
2012 Mazdaspeed 3 w/ tech package
CS LED Kit & Fogs - *painted* CF hood - VG Sharkfin antenna - CS TMM insert - DM PMM - CPe S2 RMM - Cobb AP - JBR True 3" intake - Autotech FP Internals - JBR RSB - CS Racepipe - CS SSB - JBR Short Shifter - CS SSP & weight - Motocraft tranny fluid - CS TMIC - NGK plugs - modified CS Cold Air Box - JBR EGR delete - CS OCC - DO WMI kit w/ d05 - DM TB spacer - CS BPV - KW v1 Coilovers - Whiteline adjustable endlinks - SPC camber arms - tons of GTSpec braces - Whiteline bump steer kit - Wilwood 6 pot front calipers w/ Wilwood slotted rotors - mz5 rear slotted rotors & brackets - front & rear SS brake lines - Freek tune
adamizme is offline   Reply With Quote
 Old 08-26-2015, 01:06 PM   #110
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Hey did you guys ship these babies yet? Paid for mine on the 20th...
09 MGM MS3
 Old 08-26-2015, 02:16 PM   #111
We had a bit more of a delay added on, but they should be going out tomorrow! Everyone who ordered is or has been emailed.
monkey.bones.007 likes this.
macdiesel (08-26-2015)
 Old 08-29-2015, 09:05 AM   #112
macdiesel's Avatar
Holy fast shipping. TMM arrived this morning and looks amazing. Will the website guide section be updated with an install guide?
The Following 3 Users Say Thank You to macdiesel For This Useful Post:
JgamB (08-29-2015), knocturnal (08-29-2015), Mauro_Penguin (08-29-2015)
 Old 08-31-2015, 10:15 AM   #113
nindoja's Avatar
Posts: 2,395   (View Stats)
I would imagine so. @Matt@Damond Motorsports; took pictures with the mount on my car last weekend, I presume for the install guide.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
macdiesel (08-31-2015)
 Old 08-31-2015, 06:14 PM   #114
g00s3y's Avatar
Groans: 438
Came home to much goodness, such amaze...
Will be going in tomorrow, unless this bitch ass storm decides to be a bitch...
The Following 7 Users Say Thank You to g00s3y For This Useful Post:
Farhan@DM (08-31-2015), JgamB (08-31-2015), macdiesel (08-31-2015), maisonvi (09-01-2015), Matt@DamondMotorsports (09-01-2015), Mauro_Penguin (08-31-2015), MS3Shadow (08-31-2015)
 Old 09-01-2015, 06:16 PM   #115
BrownBear
Farhan@DM's Avatar
Uploaded
Guides - Damond Motorsports
The Following 5 Users Say Thank You to Farhan@DM For This Useful Post:
Enki (09-01-2015), JgamB (09-01-2015), Matt@DamondMotorsports (09-02-2015), Mauro_Penguin (09-01-2015), WetzMS3 (09-02-2015)
 Old 09-01-2015, 06:25 PM   #116
Finally, i would know how to install the PMM/TMM correctly when mine is comes in.
Sent from my HTC M9
 Old 09-01-2015, 06:33 PM   #117
For those of you who've ordered all 3 mounts or the side mounts, I'd recommend doing them in the order of:
RMM
TMM
PMM
The Following 8 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Enki (09-02-2015), Farhan@DM (09-01-2015), g00s3y (09-01-2015), JgamB (09-01-2015), Mauro_Penguin (09-01-2015), monkey.bones.007 (09-01-2015), MS3Shadow (09-01-2015), WetzMS3 (09-02-2015)
 Old 10-05-2015, 10:30 PM   #118
Nevershallifall's Avatar
Posts: 134   (View Stats)
I ordered the duo and am very impressed with the quality of the parts so far as far as looks are concerned. I just installed the tmm tonight and tomorrow I will be doing the pmm. I only had time for a 20 mile ride so I didn't get a ton of time in but my first impressions was that it was so much quieter than I expected it to be on first start up. The only difference I noticed was a little bit if transmission noise. I didn't detect any extra NVH then I had with just my cp-e stage 2 mount. This is my first aftermarket tmm and pmm so I can't give alot of comparison. I will have some updates once I get to install the pmm! Taking my good old time the tmm took about 2.5 hours so the pmm should be half that since there is not much you need to remove. Looks like I won't have to drive a big read vibrator all over.
Blox - Gold type R shift knob
Cobb - AP V3
Cp-e - Catted DP, Stage 2 RMM
DDM - High, Low, Fog 6k hids
OBX - Catback with res delete
Turbosmart - 50/50 BOV
Treadstone - TR8
The Following 3 Users Say Thank You to Nevershallifall For This Useful Post:
Farhan@DM (10-06-2015), Mauro_Penguin (10-06-2015), mrmonk7663 (10-06-2015)
 Old 10-07-2015, 10:55 AM   #119
Zoom66's Avatar
Posts: 281   (View Stats)
Just ordered me one of these to replace another vendors TMM. Already switched to Damond's PMM from the same vendor and the change in NVH was significant. Hoping this one will further enhance that experience. Mods in signature.
 Old 10-09-2015, 09:16 PM   #120
Nishan
Just a small update now that I have gotten a couple thousand miles on my DM TMM & PMM.
The car feels great. The vibrations have lessened even further.
Transmission noise has become more apparent now after breaking in the mount. I expected this. I think it is because the vibrations have lessened therefore allowing me to hear/distinguish the difference in cabin vibes vs. transmission noise.
The car in general feels amazing. Very well planted and shifts are perfect. I was having some issues finding 3rd gear when shifting hard from 2nd gear at redline, but have not found myself cursing up a storm since.
One thing I do remember when using other manufacturers mounts is that during the colder months of the year, the vibes became much more harsh most likely due to the colder ambient temperatures making the bushings harder.
It is starting to get pretty cold here in NJ. Not in the 40's yet but low 50's and I have experienced no difference in cabin comfort. That is one thing I am extremely happy about.
The cold weather vibrations & cabin shakes drove me nuts.
The Following 6 Users Say Thank You to ms3blackmica For This Useful Post:
Easter Bunny (10-11-2015), Franky-5-Fingaz (11-06-2016), King Scumbag (10-10-2015), Mauro_Penguin (10-10-2015), MD1032 (10-09-2015), MS3Shadow (10-10-2015)
Bag's 6 build diary rtabagaboy MazdaSpeed 3/6 - Build Diaries 16 09-17-2016 02:04 AM
Dear diary... udntknw MazdaSpeed 3/6 - Build Diaries 11 09-09-2015 07:36 PM
Diary Testing sgtiger2 2010 MS3 - Build Diaries 2 07-08-2012 06:21 PM
Page generated in 0.60062 seconds with 45 queries
