| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() | | #41 | ![]() |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 301
| The Following User Says NO Thank You to roguemazda For This Un-useful Post: | joeyspeed3 (08-19-2014) |
![]() | | #42 | ![]() |
| Enter the 36 Chambers ![]() Join Date: May 2009 Location: Beverly Hills, FL
Rep Power: 1632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,746
| Not Ranked : 0 score I'm not seeing an option for just the occ drain valve. I need 1 because i had to replace the original 1 with another valve and the opening is too small to let the crud thru and it clogs as I try to drain it. Which creates a major headache as i try to un clog it and slidge just runs down my arm once i do lol.
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45 SP63 Longblock Head= Mild bowl work as well as mild porting on intake/exhaust. Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings | |
![]() | | #43 | ![]() |
![]() Join Date: Apr 2014 Location: The Netherlands
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 512
| Not Ranked : 0 score Knowing that I am from the Netherlands, and i got it pretty fast, I'm sure the uk will also be no problem
__________________ MazdaSpeed3 GT '07 CP-e Xcel Nano 3" Air Intake - CP-e Nviscid 3" TIP - CP-e HPFP - CP-e DeltaCore FMIC - CP-e Stage 1 RMM - ACT clutch kit - ATP Race Pipe - SU DualPort Turbosmart BPV - COBB anti swaybars - COBB Sport Springs - Goodridge Brakelines - Whiteline Swaybar endlinks - JBR SSP - Damond Motorsport OCC AccessPort V2 Self tuned |
| The Following User Says Thank You to Snip For This Useful Post: | Matt@DamondMotorsports (08-19-2014) |
![]() | | #44 | ![]() |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score Always! Shipping cost are already figured into the site, so you can order at anytime, and pick which ever shipping you'd prefer.
| The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post: | NoRegrets (08-26-2014) |
![]() | | #45 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score Waiting....
__________________ ![]() [SIGPIC][/SIGPIC] |
![]() | | #46 | ![]() |
![]() Join Date: Apr 2014 Location: Melbourne OZ
| Not Ranked : 0 score under 900kms and decided to empty the MD occ, and go this much jizz. Definately a good investment
__________________ Gen2 | SU Tip+Sri | Autotech | Ghetto TP | ITV22 | CobbAP Stage2 | JBR Trill 80 | MD OCC V1 |
| The Following User Says Thank You to creole For This Useful Post: | Chuthor (08-24-2014) |
![]() | | #47 | ![]() |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score No lime?
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following User Says Thank You to macdiesel For This Useful Post: | Farhan@DM (08-24-2014) |
![]() | | #48 | ![]() |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
It's hard to justify cutting up a piece that many people are waiting for, so it will likely be pics top and bottom.
__________________ | |
![]() | | #49 | ![]() |
![]() | | #50 | ![]() |
| The Following 4 Users Say Thank You to Farhan@DM For This Useful Post: | hnda etr (09-05-2014), macdiesel (10-26-2014), Matt@DamondMotorsports (09-05-2014), WetzMS3 (09-05-2014) |
![]() | | #51 | ![]() |
| Not Ranked : 0 score very nice. Respect for showing us the good stuff ![]() I'm always curious as to how every part on my car looks like inside and out and how it works
| The Following User Says Thank You to Snip For This Useful Post: | Matt@DamondMotorsports (09-05-2014) |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Thanks, I ended up buying dm occ anyway and installed already. Never occurred to me to look inside. Sent from my iPhone using sausage fingers
| The Following 3 Users Say Thank You to macdiesel For This Useful Post: |
![]() | | #53 | ![]() |
![]() Join Date: Dec 2012 Location: Richmond, TX
Groaned at 31 Times in 14 Posts
| Not Ranked : 0 score ordered won on 10/10
__________________ ΜΟΛΩΝ ΛΑΒΕ 2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's 2015 F150 Platinum 2012 MS3 Liquid Silver Autotech HPFP Cobb AP & CBE Corksport FTB Enkei Raijin 18x8 et45 JBR 3.0WP, RSB, RMM & SSP II Stratified Tune TrackMasters hood prop and ecu reloc. TurboSmart BOV |
![]() | | #54 | ![]() |
![]() Join Date: Oct 2012 Location: Concord, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Anyone else having issues installing the new occ with the new drain valve hitting the skid plate?? Had to take off the barb fitting and drain hose to put the skid plate back on. I'm gonna have to cut a hole in the skid plate inorder for it to fit. Not a big deal, just courious if anyone else had this issue. On genpu |
![]() | | #55 | ![]() |
![]() Join Date: Jan 2012 Location: Prince George, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,068
| Not Ranked : 0 score You always have to cut a hole to drain it. Are you talking about the hose or the actual metal valve? I didn't have an issue with mine. It is close but it doesn't hit. Maybe you can move the bracket up a hair if you loosen it up?
__________________ Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed. [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to jeopardy98 For This Useful Post: | Matt@DamondMotorsports (11-14-2014) |
![]() | | #56 | ![]() |
| Not Ranked : 0 score I'm talking about the barb fitting that screws into the drain valve. There's no wiggle room in the backets. The only way I could see it to fit without cutting the hole is to mount the bracket cockeyed. I already have a hole in the skid plate from the previous occ setup. All I have to do is enlarge the hole a bit. Not a big deal, if you have to cut a hole, I would just add it to the instructions. Thinking about it now it's possible I might of mounted the bracket at angle and that why it's not fitting. I'll check in the morning and report back. That hose to the pcv valve kicked my ass tonight. |
![]() | | #57 | ![]() |
| Not Ranked : 0 score I had a lift so I had no issues at all with that hose. I'm hoping the bracket is the issue. I don't have the barb valve though. I only have the drain valve.
![]() | | #58 | ![]() |
| The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post: | jeopardy98 (11-14-2014) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score Just what I wanted to know. I thought I was losing my mind for a little bit. Btw really nice kit you guys offer looking forward to see how much crud this thing collects. |
| The Following 2 Users Say Thank You to SaveMelMac For This Useful Post: | Farhan@DM (11-15-2014), Matt@DamondMotorsports (11-17-2014) |
![]() | | #60 | ![]() |
Groans: 438
| Not Ranked : 0 score Just purchased mine, can't wait to get it. Need this and some injector seals and I can get all this done along with installing my new PNP IM.
| The Following User Says Thank You to g00s3y For This Useful Post: | Matt@DamondMotorsports (11-17-2014) |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Does anyone have any idea how much fluid the catch can can hold? I just drained about 10oz's. Sent from my iPhone using sausage fingers
![]() | | #62 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Not enough for the wintertime...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() | | #63 | ![]() |
![]() Join Date: Aug 2013 Location: Colorado Springs, Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 404
| Not Ranked : 0 score Must get, need more funds, I'll be ordering soon!
![]() | | #64 | ![]() |
![]() Join Date: Jan 2014 Location: Kissimmee FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 191
| Not Ranked : 0 score @Matt@DamondMotorsports; @Farhan@DM; Im intersted in the ver3 that goes on the transmission, can I ise the vta option and have zero issues mounting or servicing? I have cxracing piping and HTP3.5" full intake. Thanks Last edited by Nel Mazdaspeed; 02-04-2015 at 10:45 AM. |
![]() | | #65 | ![]() |
| Not Ranked : 0 score does someone have a pic of how it actually mounts/looks on the transmission? Last edited by Nel Mazdaspeed; 02-04-2015 at 10:19 AM. |
![]() | | #66 | ![]() |
Thx | |
![]() | | #67 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just got to your email from this morning! LMK if you have any more questions. |
| The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post: | Nel Mazdaspeed (02-04-2015) |
![]() | | #68 | ![]() |
![]() | | #69 | ![]() |
![]() | | #70 | ![]() |
![]() Join Date: May 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score On your VTA application, what are you considering high boost? I will hopefully be ordering a DM OCC soon! |
| The Following User Says Thank You to RedDevil13 For This Useful Post: | Matt@DamondMotorsports (02-05-2015) |
![]() | | #71 | ![]() |
(Thread Starter) | Not Ranked : 0 score Pretty much from 23-30psi I recommend the VTA add on. |
![]() | | #72 | ![]() |
![]() Join Date: Jun 2011 Location: Tacoma Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,346
| Not Ranked : 0 score But what if your running more boost? Will this be an issue?
__________________ Blacked Out 2010 Black Mica MazdaSpeed 3 Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel, eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles, |
| The Following 2 Users Say Thank You to England15j For This Useful Post: | BLKSTIG (02-04-2015), Matt@DamondMotorsports (02-05-2015) |
![]() | | #73 | ![]() |
(Thread Starter) | Not Ranked : 0 score I tend to recommend custom dual set-ups past 30psi, to relieve crankcase pressure as much as possible. I'm going to be testing a dual set-up I have in mind and I've been wanting to test, hopefully once the weather warms up a bit here. |
![]() | | #74 | ![]() |
| Not Ranked : 0 score I will be heavily interested in a dual can setup. I know a while back I saw a dual can creation from you all but have yet to see it on the website. I have a perm plate on the way and a forged build in progress. I'm very OCD so since I need to add another can to my current setup its either get JBR VTA can (not my favorite due to the plumbing store parts) or find a clean dual can setup from another vendor aka MD. Keep us posted Matt.
| The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post: | Matt@DamondMotorsports (02-05-2015), Wholegrain (11-24-2015) |
![]() | | #75 | ![]() |
| The Following 4 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: |
![]() | | #76 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
__________________ 2013 CWP and Stock | |
![]() | | #77 | ![]() |
![]() Join Date: Feb 2012 Location: Jacksonville NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
| Not Ranked : 0 score I've been running a dual can set up from matt for a few months now an will vouch that they are top notch and fitment is perfect
| The Following User Says Thank You to chd_wtkns For This Useful Post: | Farhan@DM (02-10-2015) |
![]() | | #78 | ![]() |
| Not Ranked : 0 score I got my setup earlier this week.. Looks amazing, thanks for the blazing fast shipping and quality product! @Matt@DamondMotorsports; |
| The Following 2 Users Say Thank You to Nel Mazdaspeed For This Useful Post: | Farhan@DM (02-11-2015), Matt@DamondMotorsports (02-11-2015) |
![]() | | #79 | ![]() |
| Not Ranked : 0 score Ordered my kit Monday. Can't wait to get it installed! |
| The Following User Says Thank You to RedDevil13 For This Useful Post: | Matt@DamondMotorsports (02-11-2015) |
![]() | | #80 | ![]() |
| Not Ranked : 0 score @Matt@DamondMotorsports; @Farhan@DM; Is the installation on the V1 on the GenOne you have on your site the same for the VTA kit? Am I routing the hoses the same way as a sealed can install and bracket location is the same? I'm looking at the pic in the instructions and there doesn't look like there's room for the filter on top. plz correct me if I'm wrong Thanks in advance. |
| Damond Motorsports OCC V1 review | Justus | Damond Motorsports | 5 | 10-15-2013 07:02 PM |
| Welcome Damond Motorsports | Haltech | Damond Motorsports | 46 | 08-25-2013 09:56 AM |
