Like Tree20Likes
 Old 11-09-2011, 01:33 PM   #1
Atomic41's Avatar
Posts: 1,174   (View Stats)
Default Matt Damond Oil Catch can kit
Is he alive ...
I don't got any news from him about 1 month ?
I wrote a this email adress : mdmazdaspeed@gmail.com
Can someone help me with this please ?
Thanks a lot
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
The Following User Says Thank You to Atomic41 For This Useful Post:
MATT DAMOND (11-17-2011)
 Old 11-09-2011, 02:43 PM   #2
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
There's a pretty big thread about this... he's a busy guy, but trust worthy.
The Following 5 Users Say Thank You to breakfstincluded For This Useful Post:
Alpha (11-09-2011), chaser27 (09-06-2013), MATT DAMOND (11-17-2011), wolly6973 (11-09-2011), xhymer (11-14-2011)
 Old 11-09-2011, 03:11 PM   #3
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
@MATT DAMOND
The Following User Says Thank You to dougefresh_ For This Useful Post:
 Old 11-09-2011, 03:13 PM   #4
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
He will get back to you. The good thing is, when you order a kit, he doesn't fuck around. It took about 2 weeks after an email to hear back from him, but had my kit in hand 3 days after sending him a payment for it.
The Following User Says Thank You to G26 For This Useful Post:
 Old 11-09-2011, 03:15 PM   #5
Alpha's Avatar
Posts: 3,711   (View Stats)
Dude's legit... Just busy, but once he responds I'm sure you'll be taken care of quickly.
Great kits too!
 Old 11-09-2011, 03:28 PM   #6
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
Anybody heard of an OCC causing leaks? I searched the 'net and found a Vette site that said that was a possibility... not sure the spec of their cans or if that could be a universal thing for any FI car...
bzwyatt is offline   Reply With Quote
 Old 11-09-2011, 03:32 PM   #7
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Groaned at 27 Times in 21 Posts
I can shoot him a txt if he doesn't respond but I'm sure he will. Don't know if he frequents the forum like he used to, until he gets his MS5 going.
JLee1469 is offline   Reply With Quote
The Following 2 Users Say Thank You to JLee1469 For This Useful Post:
MATT DAMOND (11-17-2011), xhymer (11-14-2011)
 Old 11-09-2011, 03:32 PM   #8
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
It will leak if you don't tighten your clamps enough or leave your drain open. I don't know how else it would cause leaks. The can itself is rock solid.
 Old 11-09-2011, 03:34 PM   #9
JLee1469's Avatar
If you leave the drain valve open you will have a vacuum leak. Be sure the PCV is installed properly.
The Following User Says Thank You to JLee1469 For This Useful Post:
 Old 11-09-2011, 04:00 PM   #10
bzwyatt's Avatar
I meant oil leaks actually, sorry for ambiguous language. I heard from a tech that they can generate enough back-pressure to cause leaks in gaskets. Sounded like BS to me, but like I said, a couple other sources talked about it being an issue. Made me wonder and try to get more info...
The Following 2 Users Say Thank You to bzwyatt For This Useful Post:
Gray_speed3 (04-24-2014), MATT DAMOND (11-17-2011)
 Old 11-09-2011, 04:31 PM   #11
Shooter McGavin's Avatar
Posts: 168   (View Stats)
Shooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond reputeShooter McGavin has a reputation beyond repute
What do these go for? His are the Saikou Michi cans correct?
No regrets, that's my moto. That and everybody wang chung tonight.
Shooter McGavin is offline   Reply With Quote
The Following User Says Thank You to Shooter McGavin For This Useful Post:
AZSPEED3 (11-09-2011)
 Old 11-09-2011, 04:37 PM   #12
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
It took a couple weeks for Him to get back to me aswell.
It was well worth the wait!
MarineMazda is offline   Reply With Quote
The Following User Says Thank You to MarineMazda For This Useful Post:
 Old 11-09-2011, 05:52 PM   #13
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Yeah they are the saiko, they are 165 for a complete setup, more then worth the money. Matt includes a check valve so there is no way of it throwin pressure back in either direction. He is a real busy guy but he will get back to you. It took like 3 weeks for him to respond but I had my can in less then a week after sending the money
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
AZSPEED3 (11-09-2011), MATT DAMOND (11-17-2011)
 Old 11-09-2011, 08:46 PM   #14
I talked w/ him earlier, and he said he's gonna check that email soon... he's just been slammed. So hang tight OPers. He's a mad cool dude, and the kit has the hoses all cut to the exact length for where you want to mount it, includes a check valve, and CD w/ instructs.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
MATT DAMOND (11-17-2011), Vader (11-10-2011)
 Old 11-09-2011, 08:51 PM   #15
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
Yeah i just got an email from him so hes alive and prob working through his emails.
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
The Following User Says Thank You to kunfu For This Useful Post:
 Old 11-09-2011, 10:16 PM   #16
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
MATT DAMOND is a stand-up guy. He came to my commissioning ceremony in Chicago. We've hung out several times in the past. He is legit. You don't need to worry about being scammed.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
 Old 11-10-2011, 01:00 AM   #17
commissioner gordon?
 Old 11-10-2011, 07:58 AM   #18
Atomic41's Avatar
Thanks everyone for your answer !!!
I will waiting after his answer
 Old 11-10-2011, 08:53 AM   #19
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I've done vacuum and boost testing on the check valves he uses, and they seal perfectly and open at very light vacuum levels. Excellent quality.
Tapadatass
xhymer likes this.
MATT DAMOND (11-17-2011), rfinkle2 (09-07-2013)
 Old 11-14-2011, 06:37 AM   #20
Atomic41's Avatar
I don't receive any news one week after that post...
 Old 11-14-2011, 12:26 PM   #21
Try PM'ing Ben Affleck instead
The Following 4 Users Say Thank You to dougefresh_ For This Useful Post:
MATT DAMOND (11-17-2011), rfinkle2 (09-07-2013), silvapain (11-14-2011), SofaKingAwesome (11-14-2011)
 Old 11-14-2011, 01:17 PM   #22
Atomic41's Avatar
Someone find him ...
I search in the community list and in the search tool but I find nothing.
Thanks for your help
 Old 11-15-2011, 07:45 AM   #23
Atomic41's Avatar
 Old 11-15-2011, 08:38 AM   #24
silvapain's Avatar
Groans: 136
I'll send him a text that you're looking for him.
Tapadatass
 Old 11-15-2011, 08:49 AM   #25
speeed's Avatar
Posts: 2,999   (View Stats)
speeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the world
Groaned at 50 Times in 17 Posts
Try mdmazdaspeed@gmail.com
2012 LSM MS3
Some mods, No list, too much "zapos".
speeed is offline   Reply With Quote
The Following User Says Thank You to speeed For This Useful Post:
 Old 11-15-2011, 08:51 AM   #26
Atomic41's Avatar
Tapadatass
Originally Posted by speeed View Post
I already done this with any reply
Last edited by Atomic41; 11-15-2011 at 08:51 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-15-2011, 08:52 AM   #27
speeed's Avatar
New website too...
OCC KITS GEN2 MS3 - Performance Automotive Development LLC
rednofive likes this.
2012 LSM MS3
 Old 11-15-2011, 09:05 AM   #28
Atomic41's Avatar
Yep ! I already know it
 Old 11-15-2011, 09:13 AM   #29
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
Face it op
...He just doesn't like you...
j/k
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
 Old 11-17-2011, 07:51 AM   #30
Atomic41's Avatar
Any answer from either one ...
I want to order it before christmas PLEASE
 Old 11-17-2011, 08:00 AM   #31
If you donate $25. you will have access to the for sale section, where he has them listed.
 Old 11-17-2011, 12:50 PM   #32
bzwyatt's Avatar
I had P0401 (I think, the one for low flow through EGR) around 35k miles. It was off and on for a few hundred miles, then went away. I put my OCC on not long after. I took it off a couple weeks back for warranty work, and haven't put it back on. P0401 was on again for a day. The OCC being off wouldn't be related to it coming back, or the OCC wouldn't keep the EGR clean, would it?
The Following User Says Thank You to bzwyatt For This Useful Post:
 Old 11-17-2011, 01:00 PM   #33
If under warranty, go get a new one for free!
Should not be related, but I have found colder temps can get the EGR crap to gum up tighter, triggering CEL.
bzwyatt (11-17-2011), MATT DAMOND (11-17-2011)
 Old 11-17-2011, 02:37 PM   #34
bzwyatt's Avatar
Oh that makes sense maybe, winter and cooler weather are happening.
I just passed 60k, so no warranty (and is it 36 or 60 covered item?), I just need to take it off and clean it sometime. I meant to when the CEL was on before, but it went away and I got lazy. It's turned off again, but I'm going to try to make myself do it anyway. Maybe I'll notice a difference in idling smoothness like some others, although I don't feel any negative symptoms right now.
 Old 11-17-2011, 03:15 PM   #35
speeed's Avatar
He just answer to me, today...
2012 LSM MS3
 Old 11-17-2011, 03:25 PM   #36
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Is he alive ...
Thanks a lot
Sorry man for not getting back to you. I just shot you a pm on the forum, if you didn't get it LMK.
If you have a properly operating PCV valve, then the system shouldn't be allowed to be back pressurized. With my kit, I have the checkvalve, as a double measure against this, since the Mazda OEM PCV valve doesn't like high amounts of boost and doesn't seal well.
The OCC should not effect the EGR in any way. The EGR on these cars tends to get pretty gunked up with carbon deposits, and in most cases of the P0401 code, it can be taken care of by cleaning out the EGR valve and tube. @Raider has a great how to on cleaning the EGR valve IIRC.
Oh and thanks everyone for the kind words. I'm working hard now to get to emails more times a day, so y'all don't have to wait as long. I'm gonna be updating my site soon in the upcoming weeks, as to make ordering easier and faster.
Current Fail:
The Following 7 Users Say Thank You to MATT DAMOND For This Useful Post:
bzwyatt (11-17-2011), Cataphract_40 (11-17-2011), chaser27 (09-06-2013), Nliiitend1 (11-20-2011), Raider (11-17-2011), rfinkle2 (09-07-2013), Whiteboy (11-20-2011)
 Old 11-17-2011, 03:41 PM   #37
bzwyatt's Avatar
Thanks for the response.
For the record, I got Damond's kit also and +1 that it's great quality and the kit came quick and everything is cool. Double plus that there's a check valve. I knew it was part of the kit, but didn't know why. Now I know, and it's another sign his kits are good. Rep to Damond.
 Old 11-17-2011, 03:52 PM   #38
Emissions warranty is 80K, and those that got it replaced, got it snick in under that.
 Old 11-20-2011, 01:06 PM   #39
meciboy's Avatar
Posts: 28   (View Stats)
meciboy is a glorious beacon of lightmeciboy is a glorious beacon of lightmeciboy is a glorious beacon of lightmeciboy is a glorious beacon of lightmeciboy is a glorious beacon of lightmeciboy is a glorious beacon of light
Hey Thanks again Matt.
He contacted me Thurs. the 17th and the kit came Sat. morning the 19th, really nice turnaround. Installed it over the weekend and its very nice quality and easy to install. Replaced my PCV valve, took off my intake manifold and cleaned my valves while i was at it. Deleted my EGR a little while ago.. Hope this adds some life to the engine, my valves were REALLY bad---2 of them were'n't sealing and i'm only coming up on 58K.
meciboy is offline   Reply With Quote
 Old 11-20-2011, 01:50 PM   #40
I had butt secks with @MATT DAMOND in Aruba.
breakfstincluded (11-20-2011)
Page generated in 0.58311 seconds with 39 queries
