Like Tree31Likes
 Old 01-27-2016, 12:44 PM   #1
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
I still do not know which fitting it is, @Farhan@DM; do you have the part number?
XRP 989110 -10 Flare to -10 ORB 90 Degree Fitting.
The Following User Says Thank You to Farhan@DM For This Useful Post:
Micha (01-29-2016)
 Old 01-27-2016, 01:04 PM   #2
Sorry, I meant the push-lock that bolts onto the fitting, thanks.
 Old 01-27-2016, 03:18 PM   #3
BrownBear
Farhan@DM's Avatar
It does not have to be a push lock hose fitting, that's just the example I picked up.
The end you are mating to is just a -10 AN male. You could put any -10 AN female fitting you want, including one with an angle on it. That would allow you to get all sorts of creative with hose placement/routing. I think you already have a few of those fittings to fit on there.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (01-27-2016), speedtoz (01-31-2016)
MS6 -- possible oil drain line solution? Code Monkey Mazdaspeed3/6 General Discussion 15 01-29-2015 07:50 PM
bt oil drain line for MS6 ryein7 MazdaSpeed 3/6 - Turbo Induction 17 03-14-2012 10:42 AM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Page generated in 0.26827 seconds with 23 queries
