Like Tree31Likes
 Old 01-27-2016, 01:04 PM   #41
Originally Posted by Farhan@DM View Post
XRP 989110 -10 Flare to -10 ORB 90 Degree Fitting.
Sorry, I meant the push-lock that bolts onto the fitting, thanks.
 Old 01-27-2016, 03:18 PM   #42
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
It does not have to be a push lock hose fitting, that's just the example I picked up.
The end you are mating to is just a -10 AN male. You could put any -10 AN female fitting you want, including one with an angle on it. That would allow you to get all sorts of creative with hose placement/routing. I think you already have a few of those fittings to fit on there.
The Following 2 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (01-27-2016), speedtoz (01-31-2016)
 Old 01-31-2016, 09:03 PM   #43
Stryker125's Avatar
Posts: 386   (View Stats)
Stryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the worldStryker125 is the leader of the world
Any more progress made on this?
-2006 Speed6-
PTE5862 Tial 44mm ewg
Cpe exhaust mani, Relentless PnP Intake mani
Fmic w/ tr8
+All the things
Tuned by: Will Dawson @Purple Drank
Stryker125 is offline   Reply With Quote
 Old 01-31-2016, 09:08 PM   #44
Test fitting later this week, I hope, if not, early next week.
Stryker125 (01-31-2016), WetzMS3 (02-01-2016)
 Old 01-31-2016, 10:11 PM   #45
Stryker125's Avatar
Excellent, I'm eager for this to be figured out! I appreciate all of the trial and error and research you have put into this so far @Code Monkey; !
-2006 Speed6-
Fmic w/ tr8
+All the things
The Following User Says Thank You to Stryker125 For This Useful Post:
Code Monkey (02-01-2016)
 Old 02-02-2016, 02:35 PM   #46
batmsp3's Avatar
Posts: 153   (View Stats)
batmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond reputebatmsp3 has a reputation beyond repute
Take my money!
"Looks like Travis Stephens"
batmsp3 is offline   Reply With Quote
 Old 02-02-2016, 04:14 PM   #47
BrownBear
Farhan@DM's Avatar
It's en route. I forget delivery day, but it's this week.
The Following 4 Users Say Thank You to Farhan@DM For This Useful Post:
Easter Bunny (02-04-2016), Mazdazilla6 (02-02-2016), ms6mil (02-03-2016), Stryker125 (02-02-2016)
 Old 02-02-2016, 07:56 PM   #48
First batch or are you talking about sending it for fitment?
 Old 02-02-2016, 08:03 PM   #49
I will be test fitting it on my spare block and TC (and BNR).
The Following 7 Users Say Thank You to Code Monkey For This Useful Post:
Easter Bunny (02-04-2016), ESA (02-04-2016), Mauro_Penguin (02-05-2016), Mazdazilla6 (02-02-2016), Omega (02-03-2016), Stryker125 (02-02-2016), WetzMS3 (02-03-2016)
 Old 02-05-2016, 07:07 PM   #50
Just so it is easier to keep everything in one place:
--> review of flange with banjo fitting
--> review of flange with elbow fitting
Poohster (02-05-2016)
 Old 02-05-2016, 07:23 PM   #51
BrownBear
Farhan@DM's Avatar
I can't be in that thread with a vendor ID, so posting here.
The elbow IS a swivel. Turn the nut that is on the flange side, and it will seat the oring.
Not very comfortable taking more material out. I'll grab a stock bolt and check clearances to see what can be done, but likely will need the Allen.
Will wait for the check with the t/c Monday.
The Following 3 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (02-05-2016), Mauro_Penguin (02-05-2016), Mazdazilla6 (02-06-2016)
 Old 02-05-2016, 07:29 PM   #52
My bad, will adjust that nut Monday! Since the banjo fitting clears the TC, I am pretty sure the elbow fitting will as well.
 Old 02-09-2016, 05:41 PM   #53
@Farhan@DM; this is the finished line, I am attaching one picture here as well that shows plenty of clearance.
IMO, the flange is good to go although it would be super nice if a tiniest amount of material could be taken off as per the yellow line in a previous picture.
Thanks a lot for all the work, I will be taking two more flanges once you start a group buy!
nindoja, DingoDave, ms6mil and 1 others like this.
The Following 9 Users Say Thank You to Code Monkey For This Useful Post:
DingoDave (02-13-2016), Easter Bunny (02-09-2016), Farhan@DM (02-09-2016), Mauro_Penguin (02-10-2016), Mazdazilla6 (02-10-2016), ms6mil (02-09-2016), rob ms6gt (02-09-2016), torquemaniac (02-10-2016), WetzMS3 (02-10-2016)
 Old 02-10-2016, 07:01 AM   #54
MSP611's Avatar
Posts: 2,291   (View Stats)
@Farhan@DM; so can we order yet??? i need this in my life pronto.
In progress:
thehead (03-05-2016)
 Old 02-10-2016, 08:20 AM   #55
ESA
ESA's Avatar
Posts: 120   (View Stats)
ESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond repute
@Farhan@DM; So this will be nearly impossible to install just by doing a turbo swap?
It's more recommended for people doing an engine build, just for the clearance when the TC isn't attached to the engine?
[B]06 Speed6
Prosport Boost,Oil Tem.,Oil Press Gauge/Corksport DP/Corksport Catless RP/ITV22/Autotech Internals/Cobb AP/Corksport SRI (Stage 2)/JBR RMM/TWM stage2/CPE Safe Seal.
GT3071 EWG Kit on stand by.... Waiting for more funds for suporting mod...
ESA is offline   Reply With Quote
 Old 02-10-2016, 08:48 AM   #56
Should be doable but a total bitch.
If you can reuse the stock line, do it. If you can't, or you crack the stock line, grind your teeth and go with the flange!
Easter Bunny (02-11-2016), ESA (02-10-2016)
 Old 02-10-2016, 10:11 AM   #57
BrownBear
Farhan@DM's Avatar
Pretty much everything having to do with this line on an MS6 is difficult when it's in the car. Even the stock line is difficult to bolt on.
I'm sure it won't be long until someone figures out the line lengths for the common turbos, and it does become a "bolt on, tighten swivels" setup.
The Following 5 Users Say Thank You to Farhan@DM For This Useful Post:
Code Monkey (02-10-2016), Easter Bunny (02-11-2016), ESA (02-10-2016), Mauro_Penguin (02-10-2016), WetzMS3 (02-10-2016)
 Old 02-11-2016, 11:09 PM   #58
Name is longer than yours
Posts: 209   (View Stats)
link to pre-buy Oil Drain Line Flange pre-buy
The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post:
Code Monkey (02-12-2016)
 Old 02-12-2016, 12:00 AM   #59
MSP611's Avatar
If pre-bought when will they ship?
Sent from my Nexus 7 using Tapatalk
In progress:
MS6 -- possible oil drain line solution? Code Monkey Mazdaspeed3/6 General Discussion 15 01-29-2015 07:50 PM
bt oil drain line for MS6 ryein7 MazdaSpeed 3/6 - Turbo Induction 17 03-14-2012 10:42 AM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Page generated in 0.42110 seconds with 28 queries
