Like Tree6Likes
  • 6 Post By Matt@DamondMotorsports
 Old 06-30-2016, 01:57 PM   #1
Name is longer than yours
Posts: 209   (View Stats)
Default Mazdaspeed ST Manifold Adapter Kits now available!
Check out our site here for more info or to purchase the kit:
https://damondmotorsports.com/collec...nt=21148830340
This first run it pretty limited, but we should have more to go in less than 2 weeks.
The Following 9 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Castillo817 (06-30-2016), g00s3y (07-01-2016), Hush (06-30-2016), Mauro_Penguin (07-01-2016), Mazdazilla6 (06-30-2016), MS3Shadow (06-30-2016), NC-MS3Rob (06-30-2016), SofaKingAwesome (07-01-2016), wes3id (06-30-2016)
 Old 06-30-2016, 02:02 PM   #2
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
I call dibbs on one from first batch for speed6!!
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 06-30-2016, 02:11 PM   #3
i'll get this once TMIC is compatible
 Old 06-30-2016, 02:13 PM   #4
Finished product looks fantastic guys! Another great part from DM! Now for that FMM
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Farhan@DM (06-30-2016), MS3Shadow (06-30-2016), WetzMS3 (07-01-2016)
 Old 06-30-2016, 03:29 PM   #5
NC-MS3Rob's Avatar
Posts: 87   (View Stats)
NC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant future
x2
AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip
"The mind is like a parachute, it only works when open"
NC-MS3Rob is offline   Reply With Quote
 Old 07-01-2016, 07:59 AM   #6
Yatta's Avatar
Posts: 1,862   (View Stats)
Originally Posted by NC-MS3Rob View Post
x2
xxx
 Old 07-01-2016, 08:04 AM   #7
Y'all need to invest in some front mounts.
Vansquish (07-01-2016)
 Old 07-01-2016, 08:15 AM   #8
Police - Grammarhead
Vansquish's Avatar
I'm sure it's possible to run with a TMIC, but given the position of the ST's TB, it would take a long and pretty convoluted (read 180º) piece of hard pipe or silicone to meet up with the TB from the TMIC.
While I'd like to run the ST mani as well, I think that if I go that route, it's going to mean switching to a FMIC to make life a little more straightforward. That said, I'm thinking about FMIC pipe routing for a vertical-flow intercooler, something like this:
Given the location of the TB, it might work pretty well.
 Old 07-01-2016, 08:36 AM   #9
NC-MS3Rob's Avatar
Just like you said, using a 180º bend would put the piping relatively in the same position that the cold pipe currently sits. I think the issue is not piping. Rather, it's the mounting bolt that's on the stock IM.
The radiator would still be in the way, no? You'd have to go around that.
The Following User Says Thank You to NC-MS3Rob For This Useful Post:
 Old 07-01-2016, 08:41 AM   #10
Vansquish's Avatar
The mounting bolt(s) wouldn't necessarily be a big deal, I don't think. I doubt it'd take much time to fab up a mounting bracket that stretches across the top of the manifold and has a couple of bolts/studs sticking up from it.
You are correct sir. I haven't had my coffee yet.
 Old 07-01-2016, 08:46 AM   #11
NC-MS3Rob's Avatar
Hahahaha no worries. It's 10:45 on the east coast. I'm on like cup #3 . I agree, the mounting probably wouldn't take much engineering. I trust the guys at DM are woking on it though, they'll fab up something with top-notch quality!! (he said with high hopes of being a test subject....)
Farhan@DM (07-01-2016)
 Old 07-01-2016, 10:58 AM   #12
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
In for working with my tmic. New manifolds, retune and I'm done on stock block setup.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
 Old 07-01-2016, 11:05 AM   #13
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
waiting for genone port injection
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-02-2016, 10:13 AM   #14
dealerjohn1's Avatar
Posts: 268   (View Stats)
dealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the world
I am in if the TMIC can work as well. the 100 degree heat in SoCal means I wont be blocking my radiator anytime soon. But props go out to Matt for thinking outside the box and giving us more options for the platform.
dealerjohn1 is offline   Reply With Quote
 Old 08-15-2016, 09:35 AM   #15
aviator79's Avatar
Posts: 3,934   (View Stats)
So OEM gasket is used to seal the adapter flange to the head I assume. Or is there an o-ring channel grove where ST IM o-rings are used?
Just looked at the machining in the 3rd pic. Assuming that OEM gasket is used, are people cutting centers of gasket out where it would sit in front of the split?
Awesome product. I want one but cant justify spending $300 now, but I already have an ST mani so hopefully some day will get one.
I assume I can figure out cold pipe routing and hopefully fitting Synapse and routing recerc tube wont be too hard.
Damond Motorsports Mazdaspeed ST Manifold Adapter Kit Atomic41 Mazdaspeed3/6 General Discussion 9 06-20-2016 10:39 AM
Mazdaspeed 6 FMIC Kits CorkSport CorkSport 45 03-18-2016 07:23 PM
2010 Mazdaspeed 3 Hub Adapter Als996 Mazdaspeed3/6 General Discussion 2 01-10-2014 06:11 AM
Page generated in 0.35481 seconds with 31 queries
