Like Tree12Likes
 Old 03-24-2013, 12:06 AM   #1
Name is longer than yours
Posts: 209   (View Stats)
Default OCC and crankcase pressure testing diaries
Here at Damond Motorsports, I like to test the hell out of my products, to insure their performance, quality, and reliability. This post is about oil catch can kits and crankcase pressures, and the testing I’ve preformed on different Mazdaspeed set-ups.
First off, what is an OCC, and how does it work? An oil catch can/tank/reservoir is a device that captures oil/gases mist caused by blow-by, by putting it in-line of a PCV connection. In turn, the oil/gas gets captured by the OCC, and does not make its way into the intake system. Well, unless you never drain the OCC.
Some OCCs, like the ones I use in my kits, have an internal filter material. This media acts to not only prevent oil from making it back up into the intake system, but helps to condense crankcase oils/gasses mist, so they can drip to the bottom of the OCC.
Crankcase pressure in a high boost application is generally caused by blow-by from the compression chamber. Also, if your rings or cylinder walls are worn, you’ll get more blow-by past the piston, in turn more crankcase pressure. The OEM PCV valve is known to leak a bit, allowing boost to get into the crankcase. High boost applications see higher crankcase pressure, because there is more pressurized air going into the cylinder, which results in more blow-by. This pressure in the crankcase has to be relieved somehow and somewhere, and that is why you commonly see the dip-stick popping out of the tube. The dip-stick is the path of least resistance, however many seals can start to leak with excess crankcase pressure. Oil pan, timing cover, breather cover, oil cooler, valve cover, rear main seal, etc.
Here are some pretty simple paint drawings of all the set-ups tested, how the PCV set-ups flow under different conditions, the results of the vacuum/pressures measured, and my conclusions. Some set-ups were tested on a couple stock turbo MS3’s at 20psi of boost, as well as a BT GTX3071R MS3 at 28psi of boost. Some set-ups were not tested between the stock turbo and BT cars, due to the set-up being not an efficient way to evacuate crankcase pressure on a ST car, so there would be more pressure on a BT car, and time for testing being a factor. For that, I have some estimated readings, according to what data was observed and gathered between the cars tested.
Cars with various intakes were tested as well, to see how much of a vacuum was pulled from the intake. The air rushing through the intake pulls a slight vacuum from the valve cover port, due to the Venturi Effect. Generally, out of the intakes tested, ones were the PCV connection port is closer to the turbo pull a stronger vacuum.
Gauge readings came from various PCV set-up connections.
First let’s look at the OEM set-up:
Under engine vacuum, a vacuum is pulled on the crankcase, from the PCV valve via intake manifold port. The PCV valve is pretty restrictive, but there is enough vacuum in the crankcase, to where it will pull a vacuum from the intake, via the valve cover port.
Under boost, the air rushing through the intake pulls a slight vacuum from the valve cover port, due to the Venturi Effect. Boost going through the manifold is blocked from going into the crankcase via the PCV valve(though some boost can leak in).
Stock turbo:
At engine idle 20-21in/Hg: 1 to 3in/Hg
At full boost WOT 20psi: 2 to 4psi(depending on intake)
Big turbo: ESTIMATED
At full boost WOT 28psi: 3 to 5psi(depending on intake)
Conclusions: This works well for most stock cars running at stock boost levels. There will still be blow-by and oils will enter the intake system, without an OCC in place. Under high boost applications, boost can seep past the PCV valve into the crankcase, leading to higher pressure.
Here’s the OCC set-up I use for my kits:
Under vacuum and boost, the conditions are the same as OEM, though the check valve included in my kits is in place to prevent boost from entering the crankcase, via the prone to leaking OEM PCV valve.
Stock turbo:
At full boost WOT 20psi: 1 to 3psi(depending on intake)
Big turbo:
At full boost WOT 28psi: 2 to 3psi
Conclusions: This set-up works well, mainly on stock turbo cars. For higher boost cars, there is a bit of pressure in the crankcase, since it can only be evacuated via the VC breather port into the intake. There is a vacuum on the crankcase, under most conditions, though under full boost there can be excess pressures.
Here’s an OCC set-up, where both PCV ports are routed to the OCC, and the system relies only on intake Venturi vacuum, as the vacuum source:
Stock turbo:
At engine idle 20-21in/Hg: 0 to .5psi(depending on intake)
At full boost WOT 28psi: 2 to 4psi(depending on intake)
Conclusions: I was quite surprised to see this set-up works fairly decently. It omits a CV, since one is not needed. Under engine vacuum, there is a slight pressure on the crankcase, though it’s so low, it’s hard to read or feel. Under stock turbo boost the intake does a good job at evacuating most pressures, via the vacuum being pulled from the intake. On a BT car, I estimate the PCV valve becoming a restriction. The main thing I don’t like about this set-up, is that the crankcase is always under pressure, even though it’s very minimal at idle, it’s still pressurized. So under most engine driving conditions(engine vacuum… unless racecar), there’s always a slight pressure in the crankcase.
Here’s a total VTA set-up, where both PCV ports are connected to a VTA OCC, no vacuum is used to evacuate crankcase pressures.
Stock turbo:
At engine idle 20-21in/Hg: 0 to 1psi
At full boost WOT 20psi: 2 to 3psi
Big turbo:
At full boost WOT 28psi: 3 to 4psi
Conclusions: the fully VTA set-up has a lot of restrictions to overcome, in order to relieve crankcase pressure. Under boost, the blow-by pressurizes the crankcase, since the pressure has to come out of the restrictive PCV valve, or all the way up to the valve cover breather port. The pressure escapes mostly via the VC port, due to it being the path of least resistance. If the PCV valve were to be “ported” where it’s guts were removed, the pressures would be a bit lower. With a full VTA set-up the crankcase is always under pressure, even at idle where my gauges read zero, you can feel very slight air pressure coming out of the OCC vented port or the dipstick tube(with the dipstick removed).
Here is the set-up we found to work best on both the stock and big turbo MS3’s. It uses my current kit set-up with an additional check valve in-line that VTA’s under pressure.
Stock turbo:
At full boost WOT 20psi: .5 to 1psi(depending on intake)
Big turbo:
At full boost WOT 28psi: .5 to 1psi
Conclusions: this set-up worked the best to evacuate extra pressures on both the ST and BT cars. The slight pressures seen are due to the cracking pressure of the VTA CV and the PCV valve being a restriction. The intake is still in place to pull a vacuum and help to keep pressures down. I believe this to be the best way to relieve excess crankcase pressures on speeds up to 30psi of boost.
I will have add-ons soon to include a VTA CV with my kits(different CVs are being tested at the moment). I will also be able to supply all prior customers with these components, for very little money, so you can add this to your current set-up, if you deem necessary. For potential customers, I am working on an OCC with an incorporated VTA CV, to relieve excess crankcase pressure.
Beyond 30psi of boost, I have a couple set-ups in mind using Dustin’s PCV plate, or similar, as well as an additional vented OCC. This way, there is an additional port on the breather box, with no PCV valve restriction to overcome, during times where there would be excess crankcase pressure. I'll diagram the set-ups I'll be testing for this soon.
Any questions, comments, concerns, please post up.
@djuosnteisn
@burn813
@silvapain
@atvfreek
@phate
@Alpha
@JLee1469
others I forgot to mention
The Following 69 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
09TrueRedGTX (11-26-2014), 8.5MS3 (01-25-2014), Alpha (03-24-2013), alphasaur (03-26-2013), atvfreek (03-24-2013), big angry bird (07-19-2013), Blk_pu (08-01-2014), BlueStreak (03-27-2013), bob^3 (06-20-2013), breakfstincluded (03-26-2013), burn813 (03-25-2013), Celestspeed3 (04-01-2013), chaser27 (03-18-2014), Cheapspeed (12-21-2014), chris323 (09-21-2016), Code Monkey (03-27-2013), CosmicArkie (03-24-2013), crazyspeed6 (03-25-2013), cshunter (08-28-2013), daafisch (03-28-2013), Dano (03-26-2013), djuosnteisn (03-27-2013), Downmented (04-09-2013), Easter Bunny (03-26-2013), faeker (03-26-2013), fretburnr (01-20-2014), Funkster777 (02-05-2014), Gladcow (03-26-2013), goHAMM (09-05-2014), himurax13 (01-22-2014), Hush (03-24-2013), IMASA (03-24-2013), J.Dy (03-25-2013), JLee1469 (03-24-2013), Keko (03-26-2013), Koke382 (01-22-2014), kritz (03-27-2013), Kyle Undefined (03-26-2013), Lex (12-12-2013), Manny (03-25-2013), meelo88 (06-03-2013), mike w (03-24-2013), mrmonk7663 (06-19-2013), naoandlater (03-24-2013), Nliiitend1 (03-24-2013), nybe0010 (05-07-2013), phate (03-24-2013), Pointless (03-26-2013), psychophyr (03-24-2013), qkrthnu2 (02-04-2015), rdguindon (12-19-2013), redboat (02-05-2014), Redline143 (03-24-2013), Rokusek (03-31-2013), SarcasticOne (03-27-2013), SeeMeGovan (01-18-2014), sidekick (03-28-2013), skeeter149 (03-24-2013), Snappy (01-02-2016), spals (03-27-2013), SparkySparks (03-27-2013), Swinger13 (02-25-2014), TiGraySpeed6 (03-24-2013), Tokay444 (03-26-2013), torquemaniac (02-20-2016), trancehead (05-15-2013), ttgeoff (08-12-2014), twincitySPEED6 (01-21-2014), Voltwings (06-19-2013)
 Old 03-24-2013, 12:16 PM   #2
Alpha's Avatar
Posts: 3,711   (View Stats)
Awesome testing man! Looking forward to rockin your stuff with my PERM plate!
Once, my car doesn't overheat, of course lol
The Following 2 Users Say Thank You to Alpha For This Useful Post:
djuosnteisn (03-27-2013), Matt@DamondMotorsports (03-27-2013)
 Old 03-24-2013, 04:30 PM   #3
mike w's Avatar
Posts: 138   (View Stats)
mike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond repute
Awesome info! Thanks.
mike w is offline   Reply With Quote
The Following User Says Thank You to mike w For This Useful Post:
 Old 03-26-2013, 05:35 PM   #4
Alpha's Avatar
Bump for this!
 Old 03-26-2013, 06:05 PM   #5
IamJamen's Avatar
Posts: 789   (View Stats)
I was planning on doing some similar testing but you beat me to it. Thanks for saving me from all that work.
The Following User Says Thank You to IamJamen For This Useful Post:
 Old 03-26-2013, 06:11 PM   #6
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
I need a catch can, god speed.
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following User Says Thank You to alphasaur For This Useful Post:
 Old 03-26-2013, 06:17 PM   #7
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
take my money!
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
Matt@DamondMotorsports (03-27-2013), rfinkle2 (03-28-2013)
 Old 03-26-2013, 06:32 PM   #8
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Good deal! I am testing some stuff out right now as well!
 Old 03-27-2013, 02:14 AM   #9
Awesome dude, feel free to post up in here what you test. I'd be glad to see the results of someone else testing pressures/vacuum.
Now that I have a MS6, I'm going to do some more crankcase testing soon... with more gauges at different locations on the crankcase.
Originally Posted by helmetface View Post
Awesome diagrams Matt, really helps put this into perspective.
For the record, while I was commanding anywhere from 22 to 26psi on the gtx3071- I was running your standard single can setup pcv > occ > cv > im - with a breather on the vc. I had zero issues running this way, I know some people would experience a decent amount of oil spitting out their vc vent- however this was not the case with me.
The occ still filled regularly and vacuum levels were to be expected.
I was going to test the set-up where there's a standard OCC on the mani-pcv valve side, with a filter on the VC breather. However, you have to tune the car for un-metered air flow, and under boost/pressure, it has to travel all the way up to the VC to vent. I like the idea of the intake, or and exhaust venturi slash cut, providing vacuum under boost conditions, with a CV to VTA when there is pressure. Also, I've heard back from customers that have had issues with excessive blow-by oil out of the VC with the vent, as well as dip-stick popping issues.
FWIW...your MS Paint depictions are much better than the ones from that other guy
hahaha, I was gonna draw everything up in SolidWorks, but that would take me like a day, since I'm not as proficient at SW as I used to be... so I did this all in paint in like 30min.
Plus, drawing in paint is soooo much more fun.
Chuthor likes this.
The Following 5 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
djuosnteisn (03-27-2013), helmetface (03-27-2013), SarcasticOne (03-27-2013), Speed_j23 (03-27-2013), TiGraySpeed6 (03-27-2013)
 Old 03-27-2013, 10:43 AM   #10
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Not sure if i'm that "other guy" or not, lol. But i did spend a bit more time with the drawings on the perm site's PCV tech article.
Matt, very good write up and analysis. The TIP vacuum at wot definitely seems to have quite an effect. I bet there's typically 1-2 psi of vacuum at that point (depending on how dirty or restrictive the air filter is)... which is definitely in line with what your data shows.
I still need to send you plate for testing. I'll do that this week.
Thanks for taking the time to do some thorough testing. It's obvious when a manufacturer has a solid understanding of the system he's making parts for. Kudos to you
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 9 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (03-27-2013), atvfreek (03-27-2013), BlueStreak (03-27-2013), Dano (03-27-2013), HTP (03-29-2013), Matt@DamondMotorsports (03-28-2013), phate (03-28-2013), rfinkle2 (03-28-2013), Speed_j23 (03-27-2013)
 Old 03-27-2013, 10:45 AM   #11
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
what?...um...no...not you
but seriously I was just hacking on ya...I like both of your MS Paint depictions.
The Following 6 Users Say Thank You to Dano For This Useful Post:
BlueStreak (03-27-2013), djuosnteisn (03-27-2013), Matt@DamondMotorsports (03-28-2013), phate (03-28-2013), rfinkle2 (03-28-2013), Speed_j23 (03-27-2013)
 Old 03-26-2013, 07:08 PM   #12
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
The Following 3 Users Say Thank You to helmetface For This Useful Post:
Alpha (03-26-2013), breakfstincluded (03-26-2013), Matt@DamondMotorsports (03-27-2013)
 Old 03-26-2013, 07:23 PM   #13
Trail of Fail
Dano's Avatar
BlueStreak (03-27-2013), djuosnteisn (03-27-2013), Matt@DamondMotorsports (03-27-2013), phate (03-28-2013), rfinkle2 (03-28-2013), SarcasticOne (03-27-2013)
 Old 03-27-2013, 10:53 AM   #14
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Matt, immma let you finish but Dustin had the ms-paint ever
2008 MS3 gt
470hp/463tq on GT35r at 29psi
The Following 2 Users Say Thank You to burn813 For This Useful Post:
 Old 03-27-2013, 06:48 PM   #15
atvfreek's Avatar
Posts: 7,787   (View Stats)
I was originally running your option1 until I cranked boost up to 27psi seeing what this bnr was made of, when my dipstick decided it would rather hang out in my hood scoop and spray oil everywhere. Lol. (Actually wasn't that funny because it sucked to clean up)
At that time I decided I would try option 2, in which cs runs a similar method. That worked great at keeping my dipstick at bay, but I started to get an oil leak at my turbo oil return line. Seems these cars definitely like vacuum on the cc whenever possible to help with oil control issues.
So on a mission I tried option3 (mind you I've been messing with this since before Xmas). This is what I came up with to run inline with the hose to the IM from the occ
I had it long enough so that when cc vapor would escape through my little filter it would sort of get sucked in through my air filter and keep the odor at a minimum. Here is the installed pic
I ran that setup with great success for a couple months. However I wanted to add an occ inline with my vc port. When thinking of a plan, I decided it would be best to run a traditional can like option 1, then add a second vc port to allow additional vapor to find its way out of my cc with ease. So I ordered this from matt. It's a dual occ setup and I now run a fully closed system. This has been working flawlessly with my 2 vc ports going to one can and routed back to the tip. Then the other can is setup like option 1. No dipstick flying out, no odor after hard wot runs, no oil leaks. Happy car!!!
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 19 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (03-27-2013), Alpha (03-27-2013), BlueStreak (03-27-2013), chaser27 (03-18-2014), daafisch (03-28-2013), Dano (03-28-2013), djuosnteisn (03-27-2013), goHAMM (08-22-2014), Matt@DamondMotorsports (03-28-2013), Micha (03-27-2013), Nliiitend1 (03-28-2013), nybe0010 (05-07-2013), Pointless (03-28-2013), redboat (02-05-2014), rfinkle2 (03-28-2013), SeeMeGovan (01-18-2014), TiGraySpeed6 (03-27-2013), Tomas (01-07-2016), Voltwings (06-20-2013)
 Old 01-24-2014, 01:44 PM   #16
KevinK2's Avatar
Posts: 907   (View Stats)
KevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the world
Groaned at 79 Times in 52 Posts
How much oil/krap from the two VC vents get caught in the OCC, that exits to the TIP ?
From Delaware
Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident
Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo
KevinK2 is offline   Reply With Quote
 Old 02-11-2014, 12:28 PM   #17
KevinK2's Avatar
ATVfreek has a great closed set-up. I think the extra can for the CC vent, and an added cc vent path to this can and on to the TIP allows low cc pressure at high boost. He used the vc for adding a 2nd cc port, but a line off the PCV valve box should also work (like Tokay444?).
For the extra new cc/vc port, it should have some baffeling to reduce the liquid flow.
From Delaware
The Following User Says Thank You to KevinK2 For This Useful Post:
atvfreek (02-11-2014)
 Old 03-27-2013, 07:45 PM   #18
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
@atvfreek; pics of valve cover please!
and this wouldn't be MSF without paint drawings
'08 CWP MS3 w/ T3 3071r
The Following 4 Users Say Thank You to 802MS3 For This Useful Post:
atvfreek (03-27-2013), Matt@DamondMotorsports (03-28-2013), rfinkle2 (03-28-2013), Tomas (01-07-2016)
 Old 03-27-2013, 07:48 PM   #19
atvfreek's Avatar
I suck at ms paint. Lol. But I will grab a new pic tomorrow sir.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 03-28-2013, 11:53 AM   #20
atvfreek's Avatar
Here is a pic of the engine bay. You can see the additional port and braided hose going over the hotpipe
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (03-28-2013), BlueStreak (03-28-2013), djuosnteisn (03-28-2013), Matt@DamondMotorsports (03-28-2013)
 Old 03-28-2013, 12:15 PM   #21
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
I went vta on the valve cover and plug the hole in the intake. Been looking for a good cc to vent the crankcase that doesn't cost $300 like the SSP one. Hope you get this worked out.
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
The Following User Says Thank You to Andjo For This Useful Post:
 Old 03-28-2013, 01:06 PM   #22
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
any interest in testing a mechanical vacuum pump?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 03-28-2013, 01:14 PM   #23
Alpha's Avatar
▲ Racecar shit! Ha
 Old 03-28-2013, 01:40 PM   #24
Captain
If your hot pipe coupler blows off, it'll take that line with it. You should probably route it under the hot pipe.
Engine bay looks good though
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
atvfreek (03-28-2013), Matt@DamondMotorsports (03-28-2013), Nliiitend1 (03-28-2013), rfinkle2 (03-28-2013)
 Old 03-28-2013, 02:14 PM   #25
Awesome to see what you did with that dual OCC Justin. I've tested a few closed loop systems with the dual OCCs before, but mainly with the stock ports. @Ckmazdaspeed3 ; is running a dual set-up with an extra port on the breather box. IIRC he hasn't really captured much oil with the second OCC, but the hoses are routed to where it will more than likely drain back to the breather box.
Yeah, I'm working on a whole new designed OCC that will incorporate a VTA checkvalve. I'm also pretty set on the components I want to use for existing customers kits, so they can adapt the new set-up. For people running really high boost set-ups, I think the best route is going to be adding an additional port, for a less restrictive flowing system. Like what atvfreak did with his VC, or with Dustin's plate.
Possibly, I've looked into a couple electrical vac pumps in the past. Are you thinking of a belt driven pump or electrical pump?
Alpha (03-28-2013), atvfreek (03-28-2013), BlueStreak (03-28-2013), Celestspeed3 (04-01-2013), djuosnteisn (03-28-2013)
 Old 08-22-2013, 09:25 PM   #26
seshomaru7's Avatar
Posts: 182   (View Stats)
seshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to all
What about this? The crankcase and valve cover breather hose...teed into the OCC, then a check valve for the manifold vacuum source teed into the TIP vacuum? I could see that this may pull air from the TIP through the hose to the manifold if the manifold vacuum is greater than the vacuum in the TIP. Could another check valve be added to not allow backflow of air from the TIP back to the OCC then? Or am I just making this more complicated than it has to be?
Need a way to mount your Devil's Own methanol kit? Find my F/S thread for a custom made mount kit with all hardware included!
seshomaru7 is offline   Reply With Quote
 Old 12-19-2013, 07:43 PM   #27
rdguindon's Avatar
Posts: 37   (View Stats)
rdguindon has a spectacular aura aboutrdguindon has a spectacular aura aboutrdguindon has a spectacular aura about
just came across this article and wanted to say thanks for the info
im a little confused about what your numbers mean:
"At engine idle 20-21in/Hg: 1 to 3in/Hg"
is the first number the vacuum at the PCV valve, and the second number the pressure in the crank case?
Also how are your OCC's put together? Are the top, bottom, ports welded or glued onto the can? What type of filter media do you use.
thanks
2013 MazdaSpeed 3
COBB AP/ COBB RMM
JBR 3.5" Whale PeePee
AutoTech HPFP Internals
"I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises."
rdguindon is offline   Reply With Quote
The Following User Says Thank You to rdguindon For This Useful Post:
Matt@DamondMotorsports (12-23-2013)
 Old 12-23-2013, 12:24 AM   #28
thanks
The first number is the vacuum reading from the manifold at idle, so basically prior to the PCV valve. The second is vacuum at the crankcase, past the PCV valve.
The Saikou Michi OCCs I use in the kits are of a complete welded aluminum structure, with baffling in the top portion and inlet tube of the can. The baffling is a 3 layer mesh, I believe made of stainless steel, it could be aluminum though.
The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
atvfreek (12-23-2013), silvapain (01-20-2014)
 Old 01-18-2014, 11:47 AM   #29
KevinK2's Avatar
Originally Posted by Damond Motorsports View Post
The first number is the vacuum reading from the manifold at idle, so basically prior to the PCV valve. The second is vacuum at the crankcase, past the PCV valve.....
Nice work Matt. I've done similar testing on the Rx7 that I tracked. I used a Dwyer differential pressure gauge to check the intake for pressure drops. After porting the IC inlet, and mofifying the air filter box inlet, I could run at max boost and not see any vacuum in the inlet pipe/tube, where the hose to the "VC" connected.
Have you done any intake measurments to see if there really is a vacuum? With most MS3's and MS6's in this crowd having CAI's and open filters, I thought it would be unlikely for an intake vacuum to exist to help pull out crankcase vapors.
From Delaware
Matt@DamondMotorsports (01-20-2014)
 Old 12-19-2013, 07:56 PM   #30
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Im running MD dual occ setup....Works flawless! One sealed and one vented!
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
 Old 12-31-2013, 09:13 PM   #31
hgunther's Avatar
Posts: 39   (View Stats)
hgunther will become famous soon enough
So, JBR do you recommend doing a combination of your listed above best option and perms recommended one with the PVC plate?
Performance:
CS TB, Sure shortcut + Shifter Bushings, Cobb V3 AP, NGK Plugs, HKS BPV, CS RMM, Autotech HPFP, CS SRI & TIP, Snail Tuned E85, CS SB, CS RDM, CS FMIC, AWR Mounts, CPE Seals, SSP VTA OCC, JBR Gaskets and Coolant Delete, JBR Stage II OCC, Sonic Tuning Coilovers, SPC Balljoints
Look Good:
CS Mudflaps, F4D LED Taillights, F4D Rear Reflector LEDs, Quad HID Lights w/100w ballasts, Shark Fin Antenna, SU grill, CS LED, Anarchy Coated
hgunther is offline   Reply With Quote
 Old 12-31-2013, 10:59 PM   #32
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
This isn't JBR. This is Damond Motorsports, the original!!
Edit: IT'S 2014!!!!!!!!!!!!!!!11
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 5 Users Say Thank You to phate For This Useful Post:
chaser27 (03-18-2014), Matt@DamondMotorsports (01-20-2014), Micha (01-01-2014), sidekick (01-21-2014), silvapain (01-20-2014)
 Old 12-31-2013, 11:02 PM   #33
hgunther's Avatar
My bad!!! I meant no disrespect!!! I was reading two threads at once and not thinking while typing. What is your recommendation for BT occ setups. My precision 6266 will be pushing 45 psi when I'm done.
Performance:
Look Good:
 Old 01-18-2014, 12:54 PM   #34
btstarcher's Avatar
Posts: 4,852   (View Stats)
According to the original post, he measured between 1 and 3 in/Hg at idle and 2 to 4 psi at full boost with the stock K04. Big turbo he estimated between 3 and 5 psi at full boost. I don't know if I agree; most big turbo cars also have a larger diameter intake setup, thereby reducing the velocity of the air. So less Venturi effect.
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
chaser27 (03-18-2014), Matt@DamondMotorsports (01-20-2014), silvapain (01-20-2014)
 Old 01-18-2014, 01:13 PM   #35
KevinK2's Avatar
Those measurements represent the crankcase pressure, measured where the PCV valve is fitted. I guess his guess is just a guess .....
I am interested if Matt measured any significant vacuum in the intake pipe/tube.
A ventury effect calls for a necking down of a bore to increase local velocity and decrease pressure. This intake connection simply relies on a pressure drop caused by a restriction at points upstream of the flow, like at the MAF or filter & Housing. Adding a big intake and MAF sensor could eliminate this vacuum.
From Delaware
 Old 01-18-2014, 01:19 PM   #36
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
put the outlet of the vent right at the compressor housing.
as boost increases, so will vacuum on that vent.
"Exclusivity" - CP-enis
Demodded.
The Seals
redboat (03-14-2014)
 Old 01-18-2014, 01:57 PM   #37
KevinK2's Avatar
deleted
From Delaware
 Old 01-18-2014, 03:11 PM   #38
KevinK2's Avatar
deleted
From Delaware
makarik (01-31-2015)
 Old 01-18-2014, 01:25 PM   #39
btstarcher's Avatar
I was under the impression that he actually took measurements at the VC; however after reading it again I can see your point. Clarification please @MATT DAMOND; or @Damond Motorsports;
 Old 01-18-2014, 02:02 PM   #40
Tokay444's Avatar
Groans: 793
i never mentioned that port anywhere in anything i've posted.
you can't read, and I'M the one with no technical spheres.
Demodded.
The Seals
Last edited by Tokay444; 01-18-2014 at 02:02 PM. Reason: MSF Database - Automerged Doublepost
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/occ-crankcase-pressure-testing-diaries-141095/
Crank Case Ventilation fully explained. (Turbocharged edition.) This thread Refback 06-18-2014 11:19 AM
oil catch This thread Refback 06-13-2014 06:24 AM
The Project Pad ? View topic - Darin's 80tq...484whp... This thread Refback 06-05-2014 09:35 AM
Crankcase Ventilation Options - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-26-2014 07:21 AM
$5 OCC with Gatorade bottle - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-15-2014 06:56 PM
PCV and Excessive crank case pressure This thread Refback 12-31-2013 04:53 PM
oil catch can - Mazda 3 Quebec This thread Refback 11-19-2013 05:32 AM
Oil catch can et l'hiver - Mazda 3 Quebec This thread Refback 11-06-2013 03:31 PM
Need Help 1UZ TT not running smooth - Lextreme: Lexus-Toyota V8 Forum This thread Refback 10-18-2013 04:50 AM
Crank Case Ventilation fully explained. (Turbocharged edition.) - Page 4 Post #1 Pingback 06-21-2013 02:33 PM
Pressure testing a silicone TIP? Todd98SE MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 03-13-2013 03:07 PM
Crankcase relief jpshotya 2010 MS3 - Engine, Transmission & Driveline 3 10-18-2012 05:40 AM
Gen 1 MS3/6 Build/Diaries Haltech MazdaSpeed 3/6 - Build Diaries 6 04-07-2011 12:47 AM
GenPu Build Diaries Haltech 2010 MS3 - Build Diaries 1 03-21-2011 04:31 AM
Negative Crankcase Pressure kore2000 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-16-2010 07:56 AM
Page generated in 0.73550 seconds with 43 queries
