| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
The timing cover is the same as the Mazdaspeed 3, the only variable is the anchor points on the chassis
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement | |
| How-to: Install JBR Passenger Side Motor Mount | RallySportDirect | 2010 MS3 - How-To's | 13 | 08-18-2014 08:17 PM |
| Passenger side motor mount cracked | bf360 | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 10-27-2008 12:41 AM |
