Like Tree47Likes
 Old 02-02-2017, 10:19 AM   #1
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Shift weights can't really cause lockout. That's a function of geometry, parts conditions, and operating condition.
In general, if simple cable adjustment can't get your shifting to be consistent with a new part, take that part off. You shouldn't have to be playing with weights or fluids to make a part work as it is advertised to. If the problem persists, you may have other mechanical issues.
aackthpt likes this.
The Following User Says Thank You to Farhan@DM For This Useful Post:
aackthpt (02-03-2017)
 Old 02-02-2017, 11:56 AM   #2
Dennisms3's Avatar
Posts: 198   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
I understand the adjustment to the cable. Shifting into third is fine when driving normally. I only get lockout during wot occasionally with the clutch all the way pressed. So ill try the stock shift weight and see what happens. If the problem is still present then ill look into other things. Maybe the transmission.
Dennisms3 is offline   Reply With Quote
 Old 02-02-2017, 12:38 PM   #3
BrownBear
Farhan@DM's Avatar
Good motor mounts helps with that 3rd gear issue.
 Old 02-02-2017, 03:59 PM   #4
Dennisms3's Avatar
I have a torque solution rmm.
 Old 02-03-2017, 10:16 PM   #5
aackthpt's Avatar
Posts: 1,450   (View Stats)
...Good motor mounts help with that 3rd gear issue.
sharksinspace and iamareios like this.
2013 'speed3, silver
Stage Bro
The Following 2 Users Say Thank You to aackthpt For This Useful Post:
Mauro_Penguin (02-05-2017), sharksinspace (02-03-2017)
 Old 02-08-2017, 07:22 AM   #6
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
Removed my JBR ssp last night and got the damond plate in.
I'm running it currently with no weight to get a feel for things before adding weight. I only have a JBR shift weight as i lost my stock weight.
Currently:
-Damond ssp, 3 inch shift extension, jbr weighted knob, jbr shift bushings
I really like the feel of the DM ssp. There is a noticeable difference in ease of getting into gears while shifting. The notchiness is definitely gone when compared to the jbr plate. It just clicks nicely into the next gear. This was about the only thing i could not stand about my car. I didn't think switching plates would warrant any change, but yet again you guys made an awesome well thought out product. Slowly but surely all the JBR parts are being phased out with your motor mounts for the least NVH, and now this SSP. Good work guys!
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
The Following User Says Thank You to iamareios For This Useful Post:
Farhan@DM (02-13-2017)
 Old 02-14-2017, 11:57 PM   #7
iamareios's Avatar
Long story short, after trying many different combinations I settled on the damond plate with my JBR weighted knob, shift extension, and lighter than stock shift counter weight off eBay. In my opinion this setup suits me well and is refined but buttery smooth. The JBR counter weight was just too unbalanced. No weight was sloppy. Hope this helps!
 Old 02-15-2017, 10:54 AM   #8
aackthpt's Avatar
Sauce on eBay weight?
Stage Bro
 Old 02-15-2017, 11:46 AM   #9
iamareios's Avatar
Got this one in black. It's pretty light
NYPPD Short Shift Counter Weight Blue Mazdaspeed 3: 2007 08 09 10 11 12 13 & up | eBay
 Old 02-16-2017, 11:16 AM   #10
aackthpt's Avatar
Thank you. Did you weigh yours? I'd like to see its weight in grams. Based on other threads:
Stock: 580g
JBR: 354g
Cobb: 280g (? calculated, unconfirmed ?)
The listing claims "75% reduction", I don't really trust that but it would result in 135g. Since it's aluminum it would make sense that it would be quite light.
Stage Bro
 Old 02-16-2017, 02:43 PM   #11
iamareios's Avatar
I did not weigh it unfortunately. It looks similar to this torque solutions shift weight
TORQUE SOLUTION SHORT SHIFT WEIGHT FOR MAZDASPEED 3 2010+ | eBay
I'm sure you could contact the seller through ebay to find out.
 Old 03-14-2018, 03:11 PM   #12
MaxSpeed13's Avatar
Posts: 44   (View Stats)
MaxSpeed13 is a jewel in the roughMaxSpeed13 is a jewel in the roughMaxSpeed13 is a jewel in the roughMaxSpeed13 is a jewel in the rough
Bumping thread for review.
Ordered SSP from DM, shipped fast, and arrived to me fast also, which is a plus.
Install took around half an hour due to cold weather. You could easily install this in 10 minutes or less if you have all the tools in front of you.
The part itself is high quality, the only thing I would add to it would maybe a small laser engraved logo on it. I would have paid extra for that.
Initial feel:
Definite difference over stock, throws are shorter, and more precise, this is how the car should have came from factory. The shifter itself is also a little bit tighter. I am using the OEM weight and OEM shift knob. Next will be an aftermarket weighted shift knob as the leather on mine is wearing out and looks like shit.
For those TLDR; Fast shipping by seller, quick/easy install, noticeable improvement over stock, highly recommended.
MaxSpeed13 is offline   Reply With Quote
The Following User Says Thank You to MaxSpeed13 For This Useful Post:
Farhan@DM (03-20-2018)
 Old 03-20-2018, 09:28 AM   #13
BrownBear
Farhan@DM's Avatar
Initial feel:
Thanks for the review. I've gone back and forth with heavier and lighter weights and knobs. I haven't found a better setup for me than stock knob and weight with our SSP. Actually run that setup on my daily and both racecars.
 Old 03-20-2018, 02:26 PM   #14
MaxSpeed13's Avatar
You are welcome. I figured as much. I just don't want to get another leather wrapped shift knob that will wear out and look like shit after 2 years. I will try and look for a SS one that is roughly the same weight as OEM.
 Old 03-20-2018, 03:52 PM   #15
dix2003's Avatar
Posts: 2   (View Stats)
dix2003 will become famous soon enough
Tomei shift knob(70mm), Damond Motorsport SSP and Cobb shifter weight = very good setup
dix2003 is offline   Reply With Quote
 Old 03-22-2018, 06:54 AM   #16
pyrophelia's Avatar
Posts: 50   (View Stats)
pyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant futurepyrophelia has a brilliant future
I just ordered my SSP from you guys after reading all of the great reviews here. I will also be sure to leave one on your website after installation. Thank you all for the information and a special thanks to Damond for continuing to make high quality parts for our platform.
pyrophelia is offline   Reply With Quote
The Following User Says Thank You to pyrophelia For This Useful Post:
TruckHer (04-28-2018)
NEW!! JBR MAZDASPEED 3/6 Adjustable Short Shift Plates in Stock!! JBR JAMES BARONE RACING 58 03-30-2015 01:06 PM
JBarone Short Shift vs J-speed short Shift jallways 2010 MS3 - Engine, Transmission & Driveline 97 05-27-2011 11:33 AM
Page generated in 0.45507 seconds with 27 queries
