Like Tree120Likes
 Old 05-26-2016, 01:42 PM   #1
Boost_creep's Avatar
Posts: 829   (View Stats)
THere's a thread on this very forum that says it shouldnt be.
"Shouldnt be."
An In Depth Analysis of The MZR DISI Head
Damn you, lol. It's on my reading list!
The Following User Says Thank You to Boost_creep For This Useful Post:
Voltwings (05-26-2016)
 Old 05-26-2016, 10:49 AM   #2
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
Originally Posted by Boost_creep View Post
After looking at the pictures of this manifold, I notice that each cylinder is a single runner, as opposed to the DISI with two runners per cylinder. That is going to be an issue for anyone still running the stock (unported) head.
Interestingly the ST head has twin ports like the MZR, and the facia is machined flat (also like the MZR)
This is the Focus ST head:
Here's how the ST and MZR manifolds compare: (pictures courtesy of theschrum)
Throttle body pattern is very similar (but it points downwards)
Port for the "sound symposer":
Port for the MAP sensor (same map sensor as MZR). There is no provision for Exhaust Gas Recirculation (EGR).
As you can see the intake ports don't quite line up (hence Damon Motorsports designing an adaptor)
The ST manifold clearly wont seal due the port alignment but it does physically bolt to the MZR block on it's own:
2008 Gen1 MS3
Self tuned on E85
The Following 18 Users Say Thank You to Spectrix For This Useful Post:
Boost_creep (05-26-2016), Code Monkey (05-26-2016), derp_ms6 (05-31-2016), ericrapp0507@gmail.com (05-30-2016), Funkster777 (05-27-2016), impossible (05-31-2016), JSmith (06-01-2016), Liquidsilver (05-27-2016), Mauro_Penguin (05-28-2016), MD1032 (05-26-2016), monkey.bones.007 (05-27-2016), r3d (05-27-2016), SpeedRebirth (05-27-2016), Tifosi42 (05-27-2016), Tomas (06-30-2016), Voltwings (05-26-2016), wes3id (05-26-2016), Yamahafreak (05-27-2016)
 Old 05-26-2016, 11:08 AM   #3
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Should probably wait to see what damond and friends have made before finding problems. Obviously the setup works without issue so give em a few more days to esssplain.
Sent from my SAMSUNG-SM-G935A using Tapatalk
TiGraySpeed6 likes this.
Mods: stock
 Old 05-26-2016, 11:26 AM   #4
Djohns's Avatar
Posts: 3,944   (View Stats)
Well great. Now I need even more money to finish up this damn build of mine.
2010 black mica speed3
Soon:built motor
 Old 05-26-2016, 11:48 AM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
tee-hee....
He used the "F" word....
ain't never finished
340hp / 371tq
KiwiFlavor (05-26-2016)
 Old 05-30-2016, 02:43 PM   #6
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
tee-hee....
FACT
ericrapp0507@gmail.com is offline   Reply With Quote
The Following User Says Thank You to ericrapp0507@gmail.com For This Useful Post:
TiGraySpeed6 (05-30-2016)
 Old 05-26-2016, 11:49 AM   #7
faeker's Avatar
Groans: 731
There's a legend about an ms3 owner who "finished" his build. Word is he suffered a fatal heart attack the very......next.......day
Yamahafreak likes this.
Mods: stock
The Following 7 Users Say Thank You to faeker For This Useful Post:
alexwlwsn (05-27-2016), Djohns (05-27-2016), Gerbilo (05-26-2016), impossible (05-31-2016), KiwiFlavor (05-26-2016), monkey.bones.007 (05-27-2016), WetzMS3 (05-31-2016)
 Old 05-26-2016, 03:07 PM   #8
faeker's Avatar
Groans: 731
Hey farhan, I dunno if I was speaking to you or matt via fb messenger but I'm up for fitting up cold pipe solutions for my setup. I won't need PI but I do use meth. If there's anyway I can find out some more info not listed here let me know. I need a summer project.
Mods: stock
 Old 05-26-2016, 03:37 PM   #9
ToyCop's Avatar
Posts: 237   (View Stats)
ToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond repute
If a TMIC solution is developed I'm in like Flynn.
2011 Mazdaspeed 3 VRM W/Tech
CorkSport: 3" Power Series SRI, BPV & hose, Boost tubes, Battery box, HPFP internals, Short shifter and bushings.
ETS TMIC, Ultimate Racing test pipe, Damond dual OCCs, Damond TMM, CP-E S2 RMM, COBB APv3, Freektune OTS+ 93 Oct.
Rice: RallyArmor, Morimoto XB LED Fogs, VLeds Triton Reverse Lights, Redline boots and armrest cover, Maisonvi shift knob.
Audio: Pioneer AVIC-7100NEX
ToyCop is offline   Reply With Quote
The Following 6 Users Say Thank You to ToyCop For This Useful Post:
5doorsoffury (05-27-2016), KiwiFlavor (05-26-2016), MD1032 (05-26-2016), MS3Shadow (05-26-2016), sharksinspace (05-30-2016), Voltwings (05-26-2016)
 Old 05-26-2016, 03:41 PM   #10
I'm not typically a fanboi, but consider me standing in line tapping my foot impatiently.....
Much Want. First batch, don't need PI....
Do need better & more balanced air flow.
Curious tho- will ya'll be doing a kit of parts & bring your own ST mani or all inclusive? The ST mani's are, frankly, dirt cheap, readily available virgin new for under $50.
If I follow your blog post correctly you're offering a bring your own mani kit- which I think is perfect. I run a custom FMIC, and am totally able to tweak the pipe routing to fit the ST mani. I'm more wanting the mani-to head flange and other bits to make a classy install like the throttle body wiring adapter & oil dipstick mount. I already run your OCC, so that's gravy!
340hp / 371tq
 Old 05-26-2016, 08:45 PM   #11
Totally wouldn't mind a all-in-one kit for an TMIC setup.
sent from my Nexus 6P
KiwiFlavor (05-27-2016), Yatta (05-27-2016)
 Old 05-26-2016, 08:48 PM   #12
faeker's Avatar
Groans: 731
Having a manifold in hand, I think it'd be a pain to make it tmic compatible and thus make the price higher than needed. This manifold really is free of frills.
Mods: stock
 Old 05-27-2016, 05:18 AM   #13
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Ya know they could just offer it as an option...
2007 Mazdaspeed3 GT
 Old 05-27-2016, 06:36 AM   #14
faeker's Avatar
Groans: 731
Not really. There's no mounting points for the 2 holes on a tmic. You'd have to jb weld something and that wouldn't be something I'd want to use.
Mods: stock
 Old 05-27-2016, 02:06 PM   #15
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
not having access to any of this considered, you could more than likely use one or two IM to head bolt locations to add an AL bracket mount point. bring that forward then down to the dipstick tube mount point and create a bracket for the TMIC. not sure what sized bolt they will be using there but I gotta believe there might be something to tie into.
Or a bracket from the IM back to the VC. Get creative people
I have made many a bracket out of the AL stock at HD or Lowes.
again, have not seen this in person to know about clearances.
The Following 5 Users Say Thank You to Dano For This Useful Post:
MS3Shadow (05-27-2016), rob ms6gt (05-31-2016), Thepedigree13 (05-27-2016), TiGraySpeed6 (05-31-2016), Yatta (05-28-2016)
 Old 05-27-2016, 06:59 AM   #16
Seems like with a bit of creativity and some aluminum flat stock of the 3'x3/4"x1/8" variety you could fab up a couple of brackets pretty easily.
Less than $5 from your local lowes - Shop The Hillman Group 3-ft x 3/4-in Aluminum Metal Flat Bar at Lowes.com
or possibly free from the local metal shop scrap pile...
MS3Shadow likes this.
340hp / 371tq
 Old 05-27-2016, 11:34 AM   #17
Yatta's Avatar
Posts: 1,862   (View Stats)
If a aluminum spacer is being used, there might be enough metal there to attach such a bracket... Ford had issues with the earlier plastic manifolds cracking so attaching to it would likely not be good; if you are using the FoST manifold the sim poser port might give another brace point.
AwAfrican likes this.
The Following 6 Users Say Thank You to Yatta For This Useful Post:
KiwiFlavor (05-27-2016), MS3Shadow (05-27-2016), sharksinspace (05-30-2016), Thepedigree13 (05-27-2016), Voltwings (05-29-2016), WetzMS3 (05-27-2016)
 Old 05-27-2016, 07:00 AM   #18
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
its going to be impossible to sell this JM manifold.... lol
865ms3, WetzMS3 and InkedInspector like this.
860whp/677wtq
2.7 V6 Ecoboost
The Following 9 Users Say Thank You to PapaSmurf For This Useful Post:
865ms3 (05-27-2016), DingoDave (05-28-2016), InkedInspector (05-27-2016), Mauro_Penguin (05-31-2016), Mazdazilla6 (05-27-2016), MS3Shadow (05-27-2016), nindoja (05-27-2016), Thepedigree13 (05-27-2016), WetzMS3 (05-27-2016)
 Old 05-27-2016, 07:54 AM   #19
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
So since some people call the Focus ST "FoST", and we are adopting their manifold, can we call this set up the "FoSTer Child Mani"?
Or maybe just FoSTer Mani?
nindoja, OverBoosted and ryguy 3 like this.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
The Following 7 Users Say Thank You to Thepedigree13 For This Useful Post:
Gerbilo (05-27-2016), InkedInspector (05-27-2016), Mauro_Penguin (05-31-2016), MS3Shadow (05-27-2016), mxlplx71 (05-27-2016), OverBoosted (06-02-2016), Spectrix (05-27-2016)
 Old 05-27-2016, 08:12 AM   #20
Spectrix's Avatar
^ This. Look out for 'FoSTer Mani' listed in sigs.
2008 Gen1 MS3
Self tuned on E85
 Old 05-28-2016, 05:40 AM   #21
Spectrix's Avatar
Mazda are clearly following Damond's lead for the new 2.5 Turbo Skyactive Engine:
also, they added cup holders.
2008 Gen1 MS3
Self tuned on E85
The Following 6 Users Say Thank You to Spectrix For This Useful Post:
ericrapp0507@gmail.com (05-30-2016), KiwiFlavor (05-28-2016), Liquidsilver (05-28-2016), MD1032 (05-28-2016), Thepedigree13 (05-28-2016), Tomas (06-30-2016)
 Old 05-30-2016, 03:01 PM   #22
faeker's Avatar
Groans: 731
needs more info and product in hand.
Mods: stock
 Old 05-31-2016, 11:04 AM   #23
faeker's Avatar
Groans: 731
I'll make my hotside work as is. I have some info on how I'm gonna do my cold pipe. all I need now is the kit from damonds crew. HURRY UP FARHAN!!!!! FAEKER IS IMPATIENT!!!!
TiGraySpeed6 and AwAfrican like this.
Mods: stock
AwAfrican (05-31-2016), MS3Shadow (05-31-2016)
 Old 05-31-2016, 11:17 AM   #24
MD1032's Avatar
Groans: 143
Why so impatient? Even if this manifold offers some kind of significant measurable horsepower gain for those of us on BNR S3's with stock exhaust manifolds (which I doubt it will), it's not even going to be useful because everyone knows the stock ringlands are sketchy above 400 whp, sometimes even less.
2007 Mazdaspeed3 GT
 Old 05-31-2016, 11:18 AM   #25
dunno bout anybody else, I'm just interested in the balanced air flow between cylinders.
faeker, Mazdazilla6 and MS3Shadow like this.
340hp / 371tq
Mazdazilla6 (05-31-2016)
 Old 05-31-2016, 11:25 AM   #26
MD1032's Avatar
Groans: 143
In that case you should probably look into upgrading the exhaust manifold as well, and possibly doing some work to the cylinder head...considering those two in combination probably have way more of an influence on the overall flow balance.
If we can't even observe differences in horsepower from porting the stock intake manifold, what makes you think we'll see anything from switching to a slightly different manifold design?
2007 Mazdaspeed3 GT
 Old 05-31-2016, 11:29 AM   #27
pwdunmore's Avatar
Posts: 368   (View Stats)
Agreed, there would be a huge benefit to a balanced flow on both sides.
Balancing the intake without touching the exhaust seems like it would only benefit so much because overall flow would still be influenced by the unbalanced OEM exhaust manifold.
My car thread:
 Old 05-31-2016, 11:37 AM   #28
nindoja's Avatar
Posts: 2,395   (View Stats)
Who says they didn't do testing with an EM hooked up?
Also, where's the evidence that a ported IM makes no more HP? I remember a thread from @dale_gribble;, but he already had an aftermarket EM on the car, so I'm not sure his tests are conclusive for those with stock EMs. I'd have to go pull up my logs, but I seem to remember ~20g/s difference when I installed my PnP IM on my k04.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 05-31-2016, 11:31 AM   #29
So, what makes you think I haven't? I'm already easily able to exceed the block limits- I'm looking for other improvements, not power.
I presume you've seen the airflow comparisons between the FoST and the Mazda IM? From 30%+ difference between cyinders to ~2% difference is way more than enough reason. And this is a majorly different design that the stock Mazda IM. About the only things in common are one throttle body feeding four cylinders....
340hp / 371tq
Mazdazilla6 (05-31-2016), nindoja (05-31-2016), WetzMS3 (05-31-2016)
 Old 05-31-2016, 11:46 AM   #30
MD1032's Avatar
Groans: 143
Yes. Those numbers are bench tests. An intake manifold attached to a cylinder head sitting on a bench doesn't necessarily correlate to the real world where the manifold is attached to a running engine, especially one with a restrictive unequal length exhaust manifold. Everyone assumes the flow imbalance on our engines is caused by the intake manifold but forgets that Clint's EGT data was taken on a bone stock intake manifold.
If the stock intake manifold does not cause any flow restriction at our stock-ish power levels (already established), it doesn't matter how fancy you get with the flow balance on it. You can't just put bigger and bigger funnels above a pipe and expect the pipe to flow more.
Their measurements are taken at different valve lifts.
Let me google that for you...
Dales k04 ported and polished (PNP) Intake Manifold results
If he had an aftermarket manifold at the time, that actually improves his chances of seeing a difference in power. He didn't anyway.
Hit me with some data. You'd be like the 2nd person in the entire world that actually took before/after logs of their PnP IM and posted actual hard data proving horsepower gains. Because guess what, 99.9% of people upgrade/port manifolds because they want it to be a pretty color or giggle at racecar sounds when they turn their car on.
2007 Mazdaspeed3 GT
 Old 05-31-2016, 11:33 AM   #31
faeker's Avatar
Groans: 731
to answer my reasoning; I just want something to work on and this fits that bill. secondly, our exhaust manifold is known to be one of the least restrictive parts sub 450 hp. while porting the head will offer a more reliable change in flow in conjunction with a manifold swap, I'm not able to afford that side of it yet. I'll take the increase in flow efficiency this manifold brings us even if it's just a quality of life change and has no effect on my power. cylinder 4 will no longer be the red headed stepchild of the block.
Mods: stock
 Old 05-31-2016, 11:53 AM   #32
faeker's Avatar
Groans: 731
we do know it causes issues with cylinder 4 though. this will more than likely eliminate that
quick add on since I had to walk for a min. this part will not be a k04 dream maker. The testing done was on cars utilizing either bigger turbos or PI. I believe that that's the main target and not the sorta bt/k04 guys.
Mods: stock
Last edited by faeker; 05-31-2016 at 11:53 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-31-2016, 12:00 PM   #33
Well it's a good thing I'm not trying to flow /more/ air, rather just more evenly balance out what's already there between the cylinders. I think there's more than enough engine failure data available, things like failed ring lands & such, that taking steps to balance air flow is a wise idea.
Question, is it really your argument that the stock mani, on a running engine, provides an equal quantity of air to all four cylinders during WOT operation? Cause, honestly, that's what I'm seeing you type, and I'm not sure I follow that logic.
340hp / 371tq
 Old 05-31-2016, 12:02 PM   #34
MD1032's Avatar
Groans: 143
No, I'm saying that the stock intake manifold has no impact at all on what quantity of air goes into which cylinder, because the rest of the system (engine and exhaust manifold) is what determines that. That's how you end up with results like those shown in Clint's thread that I referenced above.
2007 Mazdaspeed3 GT
 Old 05-31-2016, 12:13 PM   #35
nindoja's Avatar
I would say that the head and exhaust manifold are part of the equation, but I'm not sure I agree that they are solely responsible for determining flow balance. @Mazdazilla6; thoughts on this?
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
 Old 05-31-2016, 12:34 PM   #36
Wrong.
Gas in = gas out. I've taken multiple classes on engine design theory, engine airflow, dyno classes, camshaft design, etc. One of the top rules is that intake tuning ALWAYS takes priority over exhaust tuning.
A quick glance at Clint's EGT thread shows that cyl 1 was running the hottest. Makes sense given the design of the exhaust mani, but temperature doesn't tell you flow numbers. Cyl 1 has the furthest to travel to make it to the collector. It is the most likely to succumb to reversion versus the rest of the cylinders which have a shorter path to make it to the collector.
The Following 6 Users Say Thank You to Mazdazilla6 For This Useful Post:
Code Monkey (05-31-2016), MS3Shadow (05-31-2016), nindoja (05-31-2016), Nliiitend1 (05-31-2016), pharaoh313 (05-31-2016), WetzMS3 (05-31-2016)
 Old 05-31-2016, 01:59 PM   #37
MD1032's Avatar
Groans: 143
Wrong.
Killing me man. Mind elaborating on your response here?
Yes, but...in vivo > in vitro testing...always. There is no data showing that PnP IM's offer increased flow balance and increased overall flow on the car in its typical configuration (stock cyl head + EM), or that the FoST manifold does either, although your flow testing data indicates that it could. I just don't trust bench tests at all because lots of people strap JMF's on their car thinking the flow balance and increased flow potential is going to improve their power production and then ultimately make their cars less useful (response + torque) in the low RPM's where racers and street drivers alike have to live a lot of the time.
I was hoping this would be ignored, however you are correct. This is a two-edged sword, of course, because if this is happening to this degree, it is also impacting total flow through the cylinder. Clint's experiment also disregards potential fueling imbalance which I think makes even more of a difference and I hope to address with future experiments of my own.
Dyno data with logs would go a long way to improving the situation here. I'm looking forward to seeing more data from Damond showing whether my guess is correct or not.
2007 Mazdaspeed3 GT
 Old 06-30-2016, 07:44 PM   #38
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Please explain this.
I believe you have it the other way around.
Mauro_Penguin (06-30-2016)
 Old 05-31-2016, 06:30 PM   #39
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Please stop derailing this nice DM adapter kit thread with your damn petty arguements.
There is more than one way to skin a cat, I mean blow up an MZR engine. We can all agree on that.
Back on topic please.
K
Thanks
Bye
AwAfrican and drozdo like this.
The Following 2 Users Say Thank You to Mauro_Penguin For This Useful Post:
davychronic (05-31-2016), KiwiFlavor (05-31-2016)
 Old 05-31-2016, 07:06 PM   #40
K
Thanks
Bye
Edit:
The Following 11 Users Say Thank You to Mazdazilla6 For This Useful Post:
AwAfrican (05-31-2016), Dano (06-01-2016), DingoDave (06-04-2016), KiwiFlavor (06-01-2016), Liquidsilver (06-03-2016), Matt@DamondMotorsports (06-02-2016), Mauro_Penguin (05-31-2016), monkey.bones.007 (06-30-2016), thrisnospork (05-31-2016), WetzMS3 (05-31-2016), Yatta (08-08-2016)
MS6 - LCD display not working, stereo not working Kalandoss MazdaSpeed 3/6 - Car Audio & Electronics 1 05-20-2015 11:24 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Page generated in 0.73726 seconds with 38 queries
