> Mazdaspeed 3/6 Hardparts (2006-2013)
Like Tree7Likes
  • 2 Post By zenit
  • 1 Post By Turbo_Steve
  • 1 Post By gmoney542
  • 1 Post By JBR
  • 1 Post By leo766
 Old 02-09-2015, 09:55 PM   #1
zenit's Avatar
Posts: 1,364   (View Stats)
Default 3D Printer Role Call
Curious to see who else has gotten into 3d printing.
Finally pulled the trigger on a cheap printer over Christmas, XYZ Da Vinci.
So far I've hacked the cartridge and using Slic3r to print ABS, and I've been reasonably impressed with the printing capabilities. Mostly I use it to prototype parts that would take time to turn or mill.
These are a couple of versions of an alignment tool I'm working on, printed in white and natural ABS.
xfeejayx and Mauro_Penguin like this.
The Following 10 Users Say Thank You to zenit For This Useful Post:
Code Monkey (02-09-2015), Enki (02-09-2015), Mattyhawk1 (02-10-2015), Mauro_Penguin (02-17-2015), Nliiitend1 (02-10-2015), phate (02-12-2015), Roddiy (02-10-2015), TiGraySpeed6 (02-10-2015), WetzMS3 (02-10-2015), xfeejayx (02-10-2015)
 Old 02-10-2015, 07:40 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
There's a guy on M6C that's turning out ignition switch covers for the Speed6 GT
File Type: jpg Screenshot - 2_10_2015 Tue , 9_35_06 AM.jpg (147.9 KB, 50 views)
340hp / 371tq
zenit (02-10-2015)
 Old 02-10-2015, 07:44 AM   #3
zenit's Avatar
@Turbo_Steve;
-feejay
-wetzel
Turbo_Steve (02-10-2015)
 Old 02-10-2015, 08:12 AM   #4
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Nice, Always wanted to get into 3D, still haven't done it.
Now I know who to call for printing projects, thanks zenit!
BTW: Did you buy it for a specific project?
Mattyhawk1 is offline   Reply With Quote
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
zenit (02-10-2015)
 Old 02-10-2015, 09:48 AM   #5
Turbo_Steve's Avatar
Posts: 944   (View Stats)
I'm currently printing an entire intake manifold prototype. I have to do it in sections and glue it together, but it will let me confirm fitment before having expensive aluminum parts made.
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following 10 Users Say Thank You to Turbo_Steve For This Useful Post:
BLKSTIG (02-10-2015), Enki (02-10-2015), helmetface (02-10-2015), Mattyhawk1 (02-10-2015), SofaKingAwesome (02-21-2016), TiGraySpeed6 (02-10-2015), udntknw (02-15-2015), WetzMS3 (02-10-2015), xfeejayx (02-10-2015), zenit (02-10-2015)
 Old 02-10-2015, 01:19 PM   #6
zenit's Avatar
That's what I was planning on doing, except with my dirtbike!
Good thread on miataturbo about that.
Here it is:
http://www.miataturbo.net/engine-per...-miatas-76193/
-feejay
-wetzel
 Old 02-10-2015, 07:51 PM   #7
zenit's Avatar
Nope, just general small projects.
It's convinced me that I need a CNC mill eventually. It's being able to be close while the machine works but focus my attention on something else while it works.
Usually I use sketchup to make STL's, but I hope to graduate to solidworks for FEA analysis soon. That and the STL i've seen generated by solidworks are much nicer renderings. Need to fork over the money and learn a new program.
 Old 02-10-2015, 08:25 PM   #8
Mattyhawk1's Avatar
Is it really worth getting your own CNC machine? it seems you would have to do A LOT of projects to make it worth it over just having a shop do it.
I only ask because I would love to also get one.
And as someone who has not used solidworks, wouldnt freeCAD serve your needs in the interim?
zenit (02-10-2015)
 Old 02-10-2015, 08:36 PM   #9
zenit's Avatar
Thanks on the lead for freeCAD, I'll look into it. I haven't seen a free and good FEA analysis program yet.
That's kind of how I felt about CNC before the printer. Now with the printer, I can model something on the bus ride home, plug into the printer when I get home (7:30-8) and have at least a small print done by the time I'm ready to pass out in the evening. In the mean time, I can clean up the house, drink beer, and do whatever- just keeping an eye on the printer.
 Old 02-15-2015, 08:48 PM   #10
I am in the process of getting a cnc mill setup. I am going with a grizzly g0704 mill. You can 3d print a basic cnc conversion for it with the stock lead screws. It is then accurate enough to mill a ball screw cnc conversion kit out of aluminum to replace the printed stuff with. Just need to order some ballscrews and nuts, etc, etc.
The g0704 is big enough to do intake manifold flanges and such on it. Total cost should be about 2,200.
zenit likes this.
Soon to come.
The Following User Says Thank You to Turbo_Steve For This Useful Post:
zenit (02-15-2015)
 Old 02-15-2015, 08:54 PM   #11
kylejenson's Avatar
Posts: 140   (View Stats)
kylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant futurekylejenson has a brilliant future
How similar is 3D printing to CNC milling? I'm an aerospace mill machinist/programmet and would LOVE to make anything and everything at home but obviously a good mill is VERY expensive. Especially with a 4th axis.
kylejenson is offline   Reply With Quote
 Old 02-16-2015, 06:32 AM   #12
zenit's Avatar
I don't know about the cnc side of things, but I don't think it would be hard with your background.
People seem to struggle with measurement and squaring the print bed, which is really easy if you've ever had to square something on a mill bed before.
Other than that, learning the basic settings has a bit of a learning curve, but there's a huge wealth of community based info out there.
3d printing is getting cheap. Next year there will be a $300 small printer by xyz printing and printrbot, and I can get 1 kg of abs filament for $12.
-feejay
-wetzel
 Old 02-22-2015, 12:25 PM   #13
Just some intake manifold parts.
Basically building an entire manifold. Will test fit it this spring in my car - If all fits well i can start having parts machined, or re-design as needed.
zenit likes this.
Soon to come.
The Following 9 Users Say Thank You to Turbo_Steve For This Useful Post:
BigBoostMS3 (02-22-2015), CWP_MS3 (08-05-2015), Enki (02-22-2015), littleloogy (08-05-2015), Mattyhawk1 (02-23-2015), Mazdazilla6 (04-23-2015), speed3 britz (12-02-2015), wwpms6 (04-24-2015), zenit (02-22-2015)
 Old 04-23-2015, 02:53 PM   #14
I just found out a couple of weeks ago that my school has its own 3D printers and they even make their own polymers to put in them, only school in the country with an elastomer center that can do it.
There's been talk of creating a section in one of the engineering buildings for students to use 3D printers and CNCs whenever they'd like. I'm keeping my fingers crossed it actually happens.
ItsNox (04-30-2015)
 Old 08-05-2015, 05:29 AM   #15
zenit's Avatar
linking for 3d printed intake:
Attention & Science Deficit Thread
 Old 08-05-2015, 06:25 AM   #16
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
This thread is win. Wish I had the shit to print my own parts.
For the guys that have finished work ( @zenit) what kind of money do you have into your parts? Like the cost to print those runners or turbo inlet pipe.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
zenit (08-05-2015)
 Old 08-05-2015, 09:14 PM   #17
zenit's Avatar
Almost nothing for the plastic.
Microcenter (local store in midwest, like Fry's) sell 1 kg rolls of ABS for ~$15, which is about 3-4 intakes worth, or a shit ton of small parts.
Also another metric: My printer has run close to a month of print time, and I've gone through 7-8 rolls.
I have broken things on my printer though, heated glass bed, screwed up some wires on the heating element, broken a bearing mount. All were replaced cheaply (<10$), although it took some effort to figure out how to fix.
 Old 08-06-2015, 01:03 AM   #18
theurgy's Avatar
Posts: 2,580   (View Stats)
Subbing this thread, I have recently been fascinated with 3d printing, particularly with the MarkForged printers which can print carbon fiber, fibreglass and even kevlar.
This whole world seems like a completely uncharted new territory and could quite possibly change the face of car tuning.
 Old 11-03-2015, 08:58 PM   #19
Balthazar's Avatar
Posts: 168   (View Stats)
Balthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the world
For the manifold wondering if you could get some thermoset plastic that would tolerate the heat. Not great looking but plenty of cars have them. Plus would let you dyno the intake and make adjustments before having a final part made.
We have a large one at work i'll ask. We were also one of the first non millitary to have one of those Arcam A2X - Arcam AB.
It prints in TiAl4V!!! I wish the powders weren't so incredibly expensive, my Datsun project needs ITB's... I'm pretty sure my boss would notice :-(
Balthazar is offline   Reply With Quote
The Following User Says Thank You to Balthazar For This Useful Post:
zenit (12-01-2015)
 Old 12-01-2015, 02:35 PM   #20
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
I just ordered a Flashforge Creator Pro on Amazon as a Christmas present for myself.
zenit likes this.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 12-02-2015, 11:22 AM   #21
We've been using 3D printing technology in house over the last year for rapid prototyping. It's a very handy, time saving tool.
Let's see some prints!
-Mike
Cheapspeed likes this.
Enki (12-02-2015)
 Old 12-02-2015, 11:25 AM   #22
Djohns's Avatar
Posts: 3,944   (View Stats)
This is pretty sweet! Any of you guys know how to print a catback exhaust flange? If so, I can post up a WTB thread and we can work something out. Jackass shop I brought it to during last winter to get the exhaust lined up warped my flange.
2010 black mica speed3
Soon:built motor
 Old 12-02-2015, 06:19 PM   #23
zenit's Avatar
If you give me more specs and/or a CAD design, I can probably help out. I've got a couple things lined up first. No money involved. Let me know.
-feejay
-wetzel
Djohns (12-02-2015)
 Old 12-02-2015, 08:12 PM   #24
Djohns's Avatar
Sounds good man! Thank you so much! I'll PM you the specs of my cat-back and downpipe later this evening.
Soon:built motor
 Old 02-20-2016, 11:33 PM   #25
leo766's Avatar
Posts: 300   (View Stats)
Default 2 cents on 3d printing engine bay parts
as a fellow 3d printer owner as of last august(markerfarm Prusa i3v 12x12x12") and i am glad someone else sees the sweet potential in this tech, i can't wait to build a box to containt the ABS fumes for mine so i can print 24/7 and not give my room mates lung cancer....
as I am about to begin experimenting with trying to 3d print that bumper insert for our car that has the mazda emblem, but not pay more than 1$ for the materials to construct it, instead of 300$ for one(if they are even available for sale anymore)
on the exhaust flange.... not sure what you are refferring to, so forgive me if this is a dumb comment, but you do realize 3d printing basically is a digitally controlled glue gun right?
by that I mean its basically melting plastic to build parts.... which is pretty sweet... until you need temp resistant parts, exhaust temps sounds naively wishful to me in terms of any material i know of to print with
the thing i am concerned about even more tho, is how these parts will stand up to warping in the summer, the engine bay gets got, and the TIP pipe that was 3d printed and the inlet adapted to smooth the flow, look to me like they will deform SIGNIFICANTLY the first day of summer, in fact I am surprised it didn't already show signs of slow warping.... this is the reason i have not tried this on my speed6, and yea buying a 3d printer teaches you 1 thing.... that you also need a CNC mill if you intend to build more than mock up prototypes for fitment and maybe airflow testing purposes(not on a hot running motor tho)....
but hey i am the first to admit i don't know a lot about 3d printing yet.... besides having to build the printer i am still in the phase where i am learning what it takes to design parts.... which is thinking ahead, about conditions that can degrade 3d prints and make them fail in spectacular ways.... which is why i quickly realized that without a cnc, you are totally limited to making objects that experinace no thermal strain.... which in engineering terms is a fancy way of saying "only good for prototype design" because real world applications either get hot, or require durability levels that simply can't be produced yet with glue guns on steroids
i hate being a party pooping wet blanket, so I do have a suggestion.... for parts that need to withstand heat, 3d printing is actually the perfect tool to use to make fiberglass/carbon fiber lay up pieces to use as molds and then use the fiberglass/carbon shells from the molds as the parts that you need that are going to be near hot things.... just a thought as a way to still use 3d printing to make life a breeze but overcome the hurdle that basically what keeps 3d print pieces solid is the fact that they are at room temp mostly
btw i lied, 3d printing teaches you 1.1 things.... and the .1 is that u can so easily build your own auger screw attached to a heating coil and PID controlled motor to basically make your own 3d printing filament out of any combination of meltable plastic powders, its the next evolution in printing, being able to create and control the exact composition of the filament you then use to make parts with properties you choose, instead of being forced into buying reels from microcenter(i admit i bought a few, but mostly when i need a color)
Bexar likes this.
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
Bad MAF Role Call Nitr0EngiE MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 05-30-2011 09:26 AM
MS3 ACT streetdisc role call ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 2 06-10-2009 12:17 AM
Dell Small Business Printer Sale (Dell 926 Color Inkjet Multifunction Printer $49 Free Shipping) Haltech Hot Deals Section 0 04-06-2008 07:11 PM
Dell Small Business Printer Sale (Dell 926 Color Inkjet Multifunction Printer $49 Free Shipping) Haltech Hot Deals Section 0 03-29-2008 07:40 PM
Page generated in 0.46761 seconds with 33 queries
