> Mazdaspeed 3/6 Hardparts (2006-2013)
Like Tree10Likes
  • 3 Post By chapy18
  • 2 Post By Spectrix
  • 4 Post By WetzMS3
  • 1 Post By anavrinIV
 Old 06-29-2016, 12:35 AM   #1
chapy18's Avatar
Posts: 159   (View Stats)
chapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the world
Default Ducks Garden Diffuser
Excited. Fresh off the boat.
Sent from my SM-G925V using Tapatalk
Dareman, SPDFoxxx and ItsNox like this.
2006 Black MS6 GT
For POWER!!!! - Cobb AP V3///HTP 3.5" Intake///Sure Test Pipe//Magnaflow CBE///Freek Tune///CS HPFP
For Looks - CS Shift Noob, Aftermarket Steering Wheel, CS LED Interior Light kit, 15% window tint all around, 70% window tint on windshield
For Handling - CS Front Upper Control Arms, CS rear Camber Arms, CS Sprtings, Whiteline Rear Sway Bar, AWR End links, JBR Trilogy Mounts, CPE rear diff mount, Turbine Tech Front Diff mount, Konig Backbone 18X8.
Big Build in the Works
chapy18 is offline   Reply With Quote
The Following 6 Users Say Thank You to chapy18 For This Useful Post:
Fonsi (07-11-2016), ItsNox (07-08-2016), SPDFoxxx (06-29-2016), SpeedRebirth (06-29-2016), TiGraySpeed6 (06-29-2016), WetzMS3 (06-29-2016)
 Old 06-29-2016, 06:00 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Well that's not something you see everyday!
Curious to learn if it lives up to the hype. How much did you end up paying for it, and what color you going to go with?
340hp / 371tq
 Old 06-29-2016, 07:23 AM   #3
chapy18's Avatar
I costed me $650 total. Getting it paint matched black mica same with the Nextmod lip kit I have.
2006 Black MS6 GT
The Following 2 Users Say Thank You to chapy18 For This Useful Post:
ericrapp0507@gmail.com (06-29-2016), TiGraySpeed6 (06-29-2016)
 Old 06-29-2016, 07:27 AM   #4
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
looking forward to pics after install !
ericrapp0507@gmail.com is offline   Reply With Quote
 Old 06-29-2016, 08:11 AM   #5
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Also looking forward to seeing how it looks. Just checked out what else they had, Wish I had seen there vented hood years ago before I bought my fiber images hood
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 06-29-2016, 10:01 AM   #6
chapy18's Avatar
Your hood have the scoop or oem style?
2006 Black MS6 GT
 Old 06-29-2016, 10:17 AM   #7
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
In case anyone else is as confused as me, it turns out a ducks garden diffuser is this:
Rather than this:
2008 Gen1 MS3
Self tuned on E85
The Following 8 Users Say Thank You to Spectrix For This Useful Post:
ItsNox (07-08-2016), JSmith (06-30-2016), KiwiFlavor (06-29-2016), MS3Shadow (06-29-2016), r3d (06-30-2016), sharksinspace (06-29-2016), Thepedigree13 (06-29-2016), WetzMS3 (06-29-2016)
 Old 06-29-2016, 11:00 AM   #8
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Those ducks don't look very diffuse though
MSP6 (06-29-2016)
 Old 06-29-2016, 11:34 AM   #9
wes3id's Avatar
it has a scoop, but its not as sleek looking as the ducks garden one.
 Old 06-29-2016, 12:14 PM   #10
I got you bruh.
g00s3y (07-03-2016), KiwiFlavor (07-01-2016), kolosok17 (06-29-2016), monkey.bones.007 (07-01-2016), MS3Shadow (06-29-2016), Spectrix (06-29-2016), Thepedigree13 (06-29-2016), TiGraySpeed6 (06-29-2016)
 Old 06-29-2016, 02:53 PM   #11
Enki's Avatar
Well now they look douchey but are still too close together to be considered diffuse.
 Old 06-30-2016, 05:05 PM   #12
Rather than this:
even if it does not function, it does look tight.
The diffuser, not the ducks. Thats fucking gross you guys for even thinking it
2/07 build date. 5/07 arrival date
88750. tracked before broken in.
Broken and broken again. been hit 4 times
235/40 fr 225/40 rear. Direzza / NT 555 /Tenzo dc-5 br 18x8.5 / DBA 4000xs/ EBC Reds /Goodridge SS lines /motul rbf/Moog control arms / axles upgraded/ Hotchkis sway fr / Whiteline adj links and tower brace/ REAR -mazdaspeed camber arms/ Tripoint anti sway/ Laura's GTspec trunk cage brace./ KSport RR. w/front camber plate w/ nasty spring rate/TopSpeed PMM Solid RMM/ sure TMM/Corksport parts =TBE w/RP or hf cat depending-Turbo- Injector seals -Fuel pump internals-Pulleys / PG v2 exh mani /HTP 3.5/ bosch 3 bar map/ new injectors/ Grimmspeed ebcs/ JMF intake /Perm Tuned vent plate/Damond Motorsports full EGR delete/DM dual CC/ Forge BPV/CP-e FMIC/Cobb v3
Samco preformed rad hose/ + Mishimoto and goodyear hoses/lines/ Braille 17/ custom tray/
Koyo Rad filled w/ Mishimoto Chill/ RPurple motor blood
 Old 07-01-2016, 05:46 AM   #13
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
It won't function. It's a (very) expensive style piece
Blue Pu.
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
ericrapp0507@gmail.com (07-01-2016), Vansquish (07-01-2016), WetzMS3 (07-01-2016)
 Old 07-01-2016, 06:20 AM   #14
Police - Grammarhead
Vansquish's Avatar
Not only that, but in order to make it look semi-cohesive with the rest of the car, you would need deeper side skirts to match the fact that it extends so far below the OEM bumper cover, and a front splitter would probably be necessary too.
anavrinIV (07-01-2016), WetzMS3 (07-01-2016)
 Old 07-03-2016, 11:36 AM   #15
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I want something like that for the ms3.
 Old 07-04-2016, 10:36 AM   #16
Spectrix's Avatar
I still maintain that it looks like dingle-berries hanging off a sheep's ass.
2008 Gen1 MS3
Self tuned on E85
 Old 07-05-2016, 02:03 PM   #17
well i have never liked the MS3's rear end. To far off the ground
Surely it creates pockets of turbulence just in front of the bumper.
At some point I am going to cut some ports in it, when i find a tasteful way to do it.
Some race teams must have done some aero aids for the under side of our cars ?
The Following User Says NO Thank You to ericrapp0507@gmail.com For This Un-useful Post:
getemslough (08-30-2016)
 Old 07-07-2016, 03:07 AM   #18
Spectrix's Avatar
Pretty sure this stuff isn't designed in a wind tunnel. Even if it was, it's doubtful it would make any measurable difference unless approaching mach 1.
DG Motorsports had a pretty neat looking diffuser for the Gen1.
2008 Gen1 MS3
Self tuned on E85
The Following User Says Thank You to Spectrix For This Useful Post:
ericrapp0507@gmail.com (07-07-2016)
 Old 07-07-2016, 08:14 AM   #19
chapy18's Avatar
Correct it is a cosmetic upgrade.
Sent from my SPH-L720T using Tapatalk
2006 Black MS6 GT
 Old 07-11-2016, 05:55 AM   #20
anavrinIV's Avatar
Groans: 63
It's not. And LOL at mach 1....functional aero works at realistic speeds. The things that hit mach 1 do so in a straight line only....or in the air. And typically they have jet engines....and often guns and bombs.
A functional diffuser is only one piece in a set of panels used to minimize the pressure differentials around the car. Specifically the diffuser is used in conjunction with a splitter, flat under body, and functional wing or spoiler in the rear of the car. The splitter in front is combined with an air dam and does what it says...splits the air. Air on top of the splitter hits the air dam and stagnates causing an area of high pressure at the front of the car that pushes the nose down. The air traveling beneath the splitter is sped up and creates an area of low pressure, helping to pull the front of the car down. This is called downforce.
The flat undertray gives a smooth area to minimize turbulence under the center of the car, again creating an area of relatively low pressure pulling the car down to the road surface.
The diffuser works in cobination with a car body (in racing, road cars typically aren't optimized here) or spoiler or wing (these are not interchangeable terms, they are are each specific aerodynamic components) to combine the air streams above and below the car as smoothly as possible behind the car, and as far away as possible to keep a minimal pressure differential between the front and rear of the car.
All of these pieces must be attached rigidly to the chassis of the vehicle and made of sufficiently stiff materials as not to deflect more than their worth under aerodynamic loads.
All that to say, anyone who thinks a 6" piece of plastic attached to your bumper can act as a functional diffuser has no understanding of functional aerodynamics. OP clearly does not fall into this category and understands what he bought. Does it look cool? Yeah. But that's where it ends
Blue Pu.
The Following 6 Users Say Thank You to anavrinIV For This Useful Post:
Enki (07-11-2016), ericrapp0507@gmail.com (07-11-2016), MS3Shadow (07-11-2016), Nitr0EngiE (07-28-2016), Vansquish (07-11-2016), WetzMS3 (07-11-2016)
 Old 07-11-2016, 09:47 AM   #21
One of the thing that drives me nuts on the speed 3 is the big pocket in front of the rear bumper. Seems like there should be some under tray. I mean the car is pretty stable at speed, but there must be all kinds of turbulence under and around the gas tank.
 Old 07-11-2016, 10:47 AM   #22
anavrinIV's Avatar
Groans: 63
We'd need to run detailed CFD with a highly accurate model to know.
There's a good chance, I think, that at speed the pocket of air will be "capped off" by air moving under the car, essentially creating a near stagnant pocket that isn't causing much additional drag at high speed.
Case in point, truck beds. there's an assumption among the general public that an open truck bed creates a lot of drag when air hits the tailgate so they leave the gate down. At slower speeds this is true, but due to low velocity the force of drag is minimal. At higher speeds the air moving over the cab traps the pocket of air in the bed and the stream never hits the tail gate. An open tail gate at speed allows the top and bottom air streams join together sooner than a raised tail gate, lowering the pressure directly behind the vehicle, increasing the pressure differential from front to back, causing higher overall drag.
I think the same thing may happen at least to some degree with our rear bumpers. Yes it would be more effective to cap off the rear of the car but there's so much going on with the rear subframe and suspension it's not feasible to do so from the manufacturer's perspective. A race team will figure it out but that's a minute, highly specialized and customized application where any tiny advantage is nearly priceless.
@mize13;
Blue Pu.
 Old 07-11-2016, 10:59 AM   #23
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
I work with Ansys. I can CFD. That being said, seems like a waste of computational resources, per @anavrinIV;s earlier comments.
Running a steady-state simulation wouldn't take long....But who's gonna model the underside of the car?? LOL
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
 Old 07-11-2016, 11:43 AM   #24
chapy18's Avatar
Correct I have the nextmod front and side lips that will be going on with this.
2006 Black MS6 GT
 Old 07-12-2016, 06:03 AM   #25
I appreciate the comments on the technical aspect. I had to assume car that is speed limited to OEM 154.5 would have thought this out to some degree !
Good call on the pocket.
I wish I understood as much as you guys. Even though I read plenty casually about aero
But nice to have some educated resources.
Looking forward to the upcoming pictures
 Old 07-12-2016, 09:34 AM   #26
anavrinIV's Avatar
Groans: 63
4 years in engineering school and years of personal reading on chassis and suspension design and aerodynamics. It all amounted to that short rambling.
Blue Pu.
 Old 07-13-2016, 11:28 AM   #27
Well it seems you have a gained a friend too !
Cheers !
Czornobaj found guilty of two motorists' deaths after stopping car to save ducks [w/video] Haltech Automotive News 0 06-20-2014 03:10 PM
New i-Road concept scoots, ducks, weaves in Toyota booth Haltech Automotive News 0 03-06-2013 03:20 PM
Video: Watch a paddle of 5,000 ducks disrupt Chinese traffic Haltech Automotive News 0 06-19-2012 06:10 PM
Page generated in 0.47454 seconds with 31 queries
