> Mazdaspeed 3/6 Hardparts (2006-2013)
  • 1 Post By Bludypoo
 Old 06-24-2015, 08:11 PM   #1
Stupid Little Cunt
Stansms3's Avatar
Posts: 58   (View Stats)
Stansms3 can only hope to improve
Groaned at 35 Times in 19 Posts
Default Help
Do the inercooler vacuum holes were the bov fits is the same as newer gens . Will it fit on newer jens and older gens
I ordered the one for newer gen when I have the older gen .
Last edited by Stansms3; 06-24-2015 at 08:11 PM. Reason: MSF Database - Automerged Doublepost
Stansms3 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Stansms3 For This Un-useful Post:
Enki (06-24-2015), speedfreak44 (06-24-2015), WetzMS3 (06-25-2015)
 Old 06-24-2015, 08:22 PM   #2
I have no idea what you are asking. BPV is the same.
 Old 06-24-2015, 09:04 PM   #3
Stupid Little Cunt
Stansms3's Avatar
The part were the bov connects to
No screw can go in that hole so I ordered the part but I ordered the one for the 2012 ms3 can it still fit mine it's called the vacuum hose
Cant*
Last edited by Stansms3; 06-24-2015 at 09:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-25-2015, 04:04 AM   #4
Sounds like a bolt is broken inside it.
The cold pipe off the TMIC is the same for gen1 and pu.
 Old 06-25-2015, 06:42 AM   #5
Stupid Little Cunt
Stansms3's Avatar
Yea the no bolt can go in that hole so now I have a boost leak cause theirs only one screw in . Next I ordered the part for the 2013 ms3 when I have the 2008 ms3 can the part that I ordered still fit?
The parts were the bov connects to
Last edited by Stansms3; 06-25-2015 at 06:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-25-2015, 06:54 AM   #6
Going to guess English is not your first language.
And yes it will work.
 Old 06-25-2015, 08:31 AM   #7
Stupid Little Cunt
Stansms3's Avatar
Thanjs
 Old 06-25-2015, 10:27 AM   #8
Bludypoo's Avatar
Posts: 287   (View Stats)
Bludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the world
pictures are worth a thousand poorly put together words. Just an FYI
Raider likes this.
Bludypoo is offline   Reply With Quote
The Following User Says Thank You to Bludypoo For This Useful Post:
Raider (06-25-2015)
Page generated in 0.31511 seconds with 21 queries
