> Mazdaspeed 3/6 Hardparts (2006-2013)
 Old 06-20-2019, 12:18 PM   #1
drive_sideways's Avatar
Posts: 120   (View Stats)
drive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nice
Default Searching for a new head for a 07 Speed6
Hi all, looking for new/used head for my Speed6, all the valves are bent in mine. If anyone has one for sale PM me or post on here. Thanks.
drive_sideways is offline   Reply With Quote
 Old 06-20-2019, 05:05 PM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Selling in PMs is frowned upon 'round these parts.
The Following User Says Thank You to JSmith For This Useful Post:
Vansquish (06-20-2019)
 Old 06-20-2019, 08:54 PM   #3
Ok..... didn’t seem to be a issue when I was more active a while ago.
Does anyone know of a reputable place to buy a used or refurbished head then? Trying to weigh options of either rebuilding mine, or buying one.
For rebuilding, does anyone recommend anything beefier then OEM spec? Not looking to build a full blown race car, but parts that can handle more abuse aren’t a bad thing...
 Old 06-20-2019, 09:25 PM   #4
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You can buy a reman head from rock auto.
Just about any reputable machine shop should be able to rebuild your head if its just bent valves.
 Old 06-21-2019, 05:27 AM   #5
What valves/springs do you recommend from the aftermarket field? While I’m I there I don’t see why it would hurt the put aftermarket parts in...
 Old 06-21-2019, 03:58 PM   #6
Groans: 60
I think most people go with the supertech springs. There are lots of threads with build info for upgraded heads, just search around.
 Old 06-21-2019, 05:30 PM   #7
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
If you are keeping stock cams and just want to rev higher, the Supertech 55lb kit seems to be the jam.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 06-24-2019, 07:31 AM   #8
Thanks for the replies, I’m going to look into that 55lb kit, I currently have no intention to build this thing into a 500+ whp monster, 300-350 whp is my ideal range as it is a daily driver.
 Old 06-24-2019, 11:38 AM   #9
Fstrnyou's Avatar
If you aren't revving higher than stock, using stock cams, and running under 30ish psi, the stock springs are fine.
If your springs are old and you want to replace them for peace of mind, there's little harm in that. The actual seat pressure of the Crower 65lb springs falls somewhere between stock and the supertech 55lb kit which may be a better option.
Other rides:
History:
Video: Motor Trend goes head-to-head-to-head in Cadillac ATS 3.6, BMW 335i and Mercedes C350 Sport Haltech Automotive News 1 11-25-2012 04:13 AM
NAV/DVD Head unit for '06 Speed6 ActAlive MazdaSpeed 3/6 - Car Audio & Electronics 8 06-15-2012 01:26 PM
Head flow / Cam Specs for Speed6 buddhabum MazdaSpeed 6 - Engine, Transmission & Driveline 11 09-22-2008 08:10 PM
Page generated in 0.28453 seconds with 23 queries
