Like Tree13Likes
  • 7 Post By Justin@Freektune
  • 1 Post By maisonvi
  • 2 Post By Justin@Freektune
  • 1 Post By 802MS3
  • 1 Post By 865ms3
  • 1 Post By Justin@Freektune
 Old 04-01-2015, 06:27 AM   #1
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Default AEM failsafe configuration
Had some time to tinker with and get this failsafe configured and tested. Cheap insurance for all the big power cars running a lot of meth or PI systems.
Freektune - Configuring AEM Wideband failsafe
Freektune - AEM wideband failsafe
https://www.extremepsi.com/store/pro...roductid=24381
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 19 Users Say Thank You to Justin@Freektune For This Useful Post:
08cosmic3 (04-01-2015), 865ms3 (04-01-2015), Amnesiac (04-01-2015), ArmanRus (04-02-2015), cshunter (04-02-2015), Dano (04-05-2015), helmetface (04-05-2015), hermz (12-14-2015), Lakespeed6 (04-01-2015), Mauro_Penguin (04-02-2015), ms6mil (04-01-2015), mxlplx71 (04-06-2015), NCspecV81 (04-05-2015), PhillyCheese (04-01-2015), shaneski (04-02-2015), Snyeed (06-21-2015), taf0422 (04-02-2015), Tokay444 (04-05-2015), WetzMS3 (04-01-2015)
 Old 04-01-2015, 12:08 PM   #2
865ms3's Avatar
Posts: 2,602   (View Stats)
installed this on one of our nator tn/ky member's car. ive got one sitting on the shelf at the house ready to go in. dumb to spend all this money on builds and not have something like this. to justin once again!
ive been trying to find some time to fab up a mounting bracket to make the addition EBCS and Hobbs switch look nice. havent had time with all the prep for ENM@MDC. i zip tied them all to the brake lines behind the battery box. still can access the hobbs switch and if you take your time can make it look pretty nice.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
Justin@Freektune (04-01-2015)
 Old 04-01-2015, 12:28 PM   #3
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
how would something like this play with/compare to a guardian angel?
Justin@Freektune likes this.
 Old 04-01-2015, 01:51 PM   #4
If you already have a guardian angel, that has an input signal wire. You simply attach the aem signal wire to that and you dont need the 3port.
PTE 6062
633HP/523TQ
maisonvi (04-01-2015), Mauro_Penguin (04-02-2015)
 Old 04-01-2015, 02:26 PM   #5
Check yo title *configuration
865ms3 (04-01-2015)
 Old 04-01-2015, 07:44 PM   #6
Edit: figured it out and fixed
PTE 6062
633HP/523TQ
 Old 04-02-2015, 06:46 AM   #7
See you should let me be customer service.
Justin@Freektune (04-02-2015)
 Old 04-01-2015, 07:46 PM   #8
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
For anyone else interesting in this gauge. I hooked it up using a 24V 20A SPST NC relay. Spliced the relay into the EBCS so when the failsafe is triggered it opens the wastegates.
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 3 Users Say Thank You to Lakespeed6 For This Useful Post:
jdmage_mx5 (04-01-2015), Justin@Freektune (04-07-2015), Mauro_Penguin (04-02-2015)
 Old 04-01-2015, 09:48 PM   #9
Polish_Eagle's Avatar
Posts: 408   (View Stats)
It's a good idea to use the relay, but I'd personally recommend the use of a solid state relay as opposed to a mechanical relay. The reason I recommend the solid state relay over the mechanical relay is because the EBCS is controlled via a PWM signal and this will wear out the relay fast as it's turning on and off at such high rates.
 Old 04-02-2015, 04:44 AM   #10
shaneski's Avatar
Posts: 505   (View Stats)
This thing is fucking brilliant, especially for this platform that needs Aux fueling to haul ass.
The Following User Says Thank You to shaneski For This Useful Post:
 Old 04-02-2015, 05:51 AM   #11
I decided against the relay for simplicity. The mac 3port is only .45 amp draw, and the AEM can be used up to 1.5 amp. This thing will not be triggering frequently, and only in an emergency situation, so there should be no harm by running without a relay, or even a mechanical relay.
You can add a variable hobbs switch all the way to 120psi if desired. So sky is the limit with over boost
New pic of the setup thanks to a friend
Lakespeed6 and mr.speedy3 like this.
PTE 6062
633HP/523TQ
 Old 04-02-2015, 06:12 AM   #12
shaneski's Avatar
Does the Gauge itself need a boost source hooked up for it's display/reading
 Old 04-02-2015, 06:17 AM   #13
Yes it does. Sorry, forgot to add that to the drawing
Edit: I already had a boost gauge and my meth controller in the car, so I just tee'd right off that line in the cabin for the AEM.
PTE 6062
633HP/523TQ
 Old 04-02-2015, 06:37 AM   #14
shaneski's Avatar
I have my BPV line tee'd off for 3port ebcs and another one along the line for meth controller, i think i may have to tap the silicone joiner of the FMIC hot side and re-route some shit or i will get mixed up what the fuck is going to where lol
 Old 04-02-2015, 07:43 AM   #15
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
sounds like you would be a good candidate for using a vac/boost distribution block
Amazon.com: Vibrant 2691 Black Anodized Aluminum Vacuum Manifold: AutomotiveAmazon.com: Vibrant 2691 Black Anodized Aluminum Vacuum Manifold: Automotive
'08 CWP MS3 w/ T3 3071r
The Following 4 Users Say Thank You to 802MS3 For This Useful Post:
Justin@Freektune (04-02-2015), Mauro_Penguin (04-02-2015), shaneski (04-02-2015), taf0422 (04-02-2015)
 Old 04-02-2015, 09:06 PM   #16
shaneski's Avatar
Thank you sir!!, didn't even know they even existed lol.
 Old 04-05-2015, 09:47 AM   #17
NCspecV81's Avatar
Posts: 2,867   (View Stats)
How is this really implemented with aux fueling? Just by monitoring the AFR's? So this is more reactionary than preventative? Wished AEM had this in an AIO package with the meth failsafe.
2013 CWP and Stock
 Old 04-05-2015, 04:22 PM   #18
GCPhotographers's Avatar
Posts: 1,198   (View Stats)
I have one for some time now just connected to the 02 sensor reading AFR. I didn't connect any other wires besides ground of course. @Justin@Freektune; I read your article. Great information. Should I have my settings like ours or waiting on my tuning results?
2012 Black MazdaSpeed3
Fuel: 91 & 93 Octane /
COMING SOON
 Old 04-05-2015, 05:36 PM   #19
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Edit: I fail at reading.
Justin, I have to ask....what's the highest meth concentration you have run through the system? I had one (actually AEM sent me 4 replacement flow sensors) and they would not handle 100% meth. One full pull and they were melted/locked up with zero flow reported.
I went round and round with AEM support...eventually they arranged for me to get my money back from Jegs. I was very disappointed as this was my last shot at a flow sensor and failsafe for my setup. May try a pump current drwa type like CM has.
 Old 04-05-2015, 05:40 PM   #20
865ms3's Avatar
Not a drop of meth runs though this. It's AFR/boost based.
It goes lean...it triggers the bpv with the setup Justin made
Brent
Dragon Slayer Setup
FreekTuned
 Old 04-05-2015, 05:42 PM   #21
Trail of Fail
Dano's Avatar
hahah
reading fail...ignore my post and continue reading.
865ms3 (04-05-2015), Justin@Freektune (04-07-2015)
 Old 04-05-2015, 05:44 PM   #22
865ms3's Avatar
hahah
Should be an end all for the flow gauge problems. I plan to use it on my 5858 build using lots o meth. Installed it on a 6th port car a few weeks ago too.
Brent
Dragon Slayer Setup
FreekTuned
 Old 04-05-2015, 09:59 PM   #23
NCspecV81's Avatar
how fast does it react to the AFR trigger? I need a new boost gauge so this may be 2 rocks with 1 bird...or wait...2 rocks with 1 whore...or shit..2 birds with 1 whore...I give up.
How tall is the o2 sensor?
2013 CWP and Stock
Mauro_Penguin (04-06-2015)
 Old 04-06-2015, 07:35 AM   #24
Lakespeed6's Avatar
Seems to react quick.
You can set the about of time the o2 has to be out of the threshold before it is triggered.
I think default is 500 milliseconds. This is incase the o2 reads 1 cell out of target it doesn't cut the system.
o2 height seemed standard not sure if I can get behind my turbo enough to measure for you but I'll try.
 Old 04-07-2015, 01:56 PM   #25
Default is 500 milliseconds, and you can have it trigger faster than that if you want. You don't want it too fast or too tight of a window or you won't be able to FFS when racing.
Lakespeed6 likes this.
PTE 6062
633HP/523TQ
NCspecV81 (04-07-2015)
 Old 04-06-2015, 12:13 AM   #26
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
So this would be a better choice the. The snow safe inject system since it runs off afr instead of flow sensor? I am only running 50/50 meth since 100% is hard to come by around where I live and This car is my dd.
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 04-07-2015, 05:26 PM   #27
NCspecV81's Avatar
I'm thinking about doing this. However, I have a couple of questions to those who have this.
Can you run AFR on the digital and Boost on the analog and vice versa? By the looks of the software it looks like you can, but didn't want to spend $300 to find out that's not true.
Also, how high does boost pressure read on the digital? Looks like the face is capped at 30psi.
2013 CWP and Stock
Mauro_Penguin (04-07-2015)
 Old 04-07-2015, 05:58 PM   #28
Lakespeed6's Avatar
Yes you can swap the digital vs analog for boost or afr.
Gauge only reads to 30psi
In need of help with current exhaust configuration Zbrit00x Gen2 MS3 General Discussion 17 08-18-2012 03:27 PM
Dp/tp configuration options jack_hammer Mazdaspeed3/6 General Discussion 26 01-25-2012 12:21 PM
Porsche finds new configuration for four wheels with a pair of street bikes Haltech Automotive News 0 07-26-2011 07:20 AM
coolant line configuration for non-water cooled turbo madvillain MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-20-2010 06:05 AM
Mazdaspeed 3 @ Buttonwillow Configuration 13 and Willow Springs AlpineFD Auto-X / Road Racing / Time Attack 11 01-27-2010 05:12 PM
Page generated in 0.51226 seconds with 32 queries
