Like Tree3Likes
  • 1 Post By Thepedigree13
  • 1 Post By SpeedRebirth
  • 1 Post By ms_3
 Old 06-16-2016, 12:30 PM   #1
ms_3's Avatar
Posts: 374   (View Stats)
ms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the world
Default Full E-Tune E85 question
On the website under the $200 e-tune there is an e85/meth option.. if i select "yes please" does that add a separate full E85 tune to the 93 Octane tune or is it 275 for a full E85 tune?
Sorry if this was posted or clarified previously didn't see it spelled out anywhere.
2007 True Red Mazdaspeed 3 GT
Power - Cobb AP v3, AT HPFP internals, Ultimate racing DP, Borla CBE, Forge v2 bpv, CP-E TIP, Mazdaspeed OEM CAI
Handling - CS Genwin Steering wheel, Maisonvi custom shift knob, Koni FSD shocks, Hotchkis f+r sway bars, Damond RMM,
EBC USR rotors + Yellowstuff pads, JBR SSP + weight + bushings
Soon - FMIC
Followed by a protune
2008.5 CWP Mazdaspeed 3 SOLD
ms_3 is offline   Reply With Quote
 Old 06-16-2016, 12:59 PM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
if you only want a tune for e its probably just the 200.
i run e30 there isnt much to gain by using more e, just a chance of black death at 50%+e
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-16-2016, 09:12 PM   #3
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
I think he means a full tune for E85, not a tune for "full" E85. Full meaning not an OTS+ deal.
757CX7 likes this.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
 Old 06-17-2016, 03:59 PM   #4
mxlplx71's Avatar
Groans: 128
i guessed that just making a suggestion, i have an e30 pump near my house.
makes it really easy, no mixing.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-17-2016, 06:15 AM   #5
macdiesel's Avatar
Posts: 825   (View Stats)
I believe it he price is for both because you can buy a 93 tune for $200 and later add an e85 tune for $75. Which is what I'm doing now
 Old 06-17-2016, 09:26 AM   #6
ms_3's Avatar
Thanks for your feedback all
That's what I thought! Thats rad AF if that is the case
Soon - FMIC
 Old 06-17-2016, 11:02 AM   #7
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
E85 tune is "just" a continuation of the completed 93 tune, where you raise timing/boost and adjust other related parameters to get the most out of your setup.
757CX7 likes this.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
ms_3 (06-17-2016)
 Old 06-17-2016, 11:34 AM   #8
ms_3's Avatar
Thank you brother! Stoked to get this ball rolling
Soon - FMIC
 Old 06-17-2016, 04:29 PM   #9
macdiesel's Avatar
E30 bmw pump?
Sent from my iPhone using my stinky little fingers
 Old 06-17-2016, 04:36 PM   #10
mxlplx71's Avatar
Groans: 128
e85 or e30 at the station
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-21-2016, 08:03 AM   #11
ms_3's Avatar
Justin emailed me a response and just to confirm for anyone that may not know, as macdiesel and speedrebirth stated, the $275 covers a fully dialed in 93 tune and an E85/mix tune
macdiesel likes this.
Soon - FMIC
The Following User Says Thank You to ms_3 For This Useful Post:
mxlplx71 (06-21-2016)
 Old 07-07-2016, 04:27 PM   #12
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
I think Justin is done with my 91 tune. His last email to me did not say one way or the other and had no revision attached. My last set of logs I sent him I pointed out fuel trims slightly off at normal cruising but fine at WOT. I mentioned they were fine with the previous map and most likely a boost leak I can track down easily. I sent the logs and his response was;
Hey man
Nothing should have changed with the maf cal. You can try loading rev C again. Could be boost leak, o2 sensor, purge valve, dirty maf, dirty air filter lol. Lot of things
So I responded to him asking if we were done tuning. As I have no clue. Ugh. Frustrating. I'll have to wait 5 days before I hear back I am guessing. My MAF is brand new OEM, and everything else is clean, newish, etc. I made sure my ride was on a fresh tune up before starting with him.
Anyhow, assuming he can do no more for me at 91 octane I want to do an E85 tune. I only paid for a 91 tune thus far. So do I pay $75 to do E30 mix or $200 again?
I want to do E85 as I had high KR at 21 psi and none at 18 psi. Will I be able to run higher boost on an E30 mix? Is it worth it?
 Old 07-07-2016, 05:26 PM   #13
Groans: 33
It is totally worth it. I would think your timing is around 10* on 91, after that it will knock. 93 is usually maxed out at round 12-14* timing. And with E85 you can go as high as 17-21*. How much timing you can run is also relative to how much boost you run. Heat and pressure is what causes knock. So hell yeah, go for it!
And it should be $75 yes
Mazdaspeed6 -06
290 AWHP / K04
 Old 07-07-2016, 05:41 PM   #14
Groans: 211
I see. Thank you for the response. I will ask Justin in my next email to move onto E85. Will it be time for a step colder plug like the NGK he suggests on his websites FAQ?
 Old 07-07-2016, 05:46 PM   #15
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Once i was tuned with e there was no looking back. I use 93 only if I'm going on a trip where some hodgie will screw up my mix ratio by not letting me mix my own gas (cough jersey cough) or cant get to e85. It runs the motor safer and takes more heat out of the cylinders as well as giving mucho powa. Imo the extra for a e85 tune is cheap considering the timing has to be reworked.
MECP
2012 BM
Rfinkle tune in progress
Thor Hammer (07-07-2016)
 Old 07-07-2016, 06:08 PM   #16
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
you won't regret going corn fed! DO IT!!
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
The Following User Says Thank You to wes3id For This Useful Post:
ots + or full tune? Me2speed3 FREEKTUNE 2 03-28-2016 05:19 PM
Freek OTS or full tune Bug2110 2010 MS3 - ECU Computer Tuning 13 05-28-2015 08:26 AM
Tune needed only for full TBE? Speedstick 2010 MS3 - Engine, Transmission & Driveline 28 12-08-2010 08:19 PM
Cp-e Full Control Flash w/o standback & tune? steven88 MazdaSpeed 3 - Engine, Transmission & Driveline 0 07-10-2009 10:32 AM
Cp-e Full Control Flash w/o standback & tune? steven88 MazdaSpeed 3/6 - ECU Computer Tuning 57 07-09-2009 11:53 PM
Page generated in 0.40243 seconds with 27 queries
