Like Tree104Likes
 Old 04-03-2014, 11:42 AM   #121
SparkySparks's Avatar
Posts: 1,314   (View Stats)
No, I figure it was due to higher ambient air temps and quite a bit higher humidty vs the day the first logs were done.
I was more asking because your occupancy weight in the VD is listed as 380.
On Order:
Coming Soon:
DIY Projects:
 Old 04-03-2014, 01:08 PM   #122
El Beaner's Avatar
Posts: 4,262   (View Stats)
lol - nope, that is my fatass - I'm a big guy.
SOLD 2012 LSM Tech - 11/17/17
 Old 04-03-2014, 02:56 PM   #123
Fair enough, I'm not a tiny guy either (300lbs), just wanted to double check everything was set correct for you on the VD.
On Order:
Coming Soon:
DIY Projects:
 Old 04-04-2014, 04:57 PM   #124
Mattcinnc1's Avatar
Posts: 573   (View Stats)
Mattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the world
Bought my ots early yesterday and can't wait to get a proper setup till I have my downpipe on then I can go full on tune
Justin@Freektune likes this.
2006 Mazdaspeed 6 WWP
Mods: Cobb ap, Freektune ots+, rebuilt ko4(hhskinny), Autotechs, AEM CAI, ETS tmic, Sure sidewinder, JBR RMM, Cpe diff mount, sure charge tubes, Corksport strut tower, catless test pipe, Magnaflow CBE, Forge BPV(v1), JBR shift bushings, corksport rear sway bar, VTCS delete, Dba 4000 slotted rotors, ebc red stuff
Interior: Block Vent pod, Prosport boost gauge, Redline leather boots, Mazdaspeed E-brake, Ipod integration, Corksport LEDs
Looks: 15% tint all around, 40% entire windshield, Corksport LED fogs, Corksport stub
Fluids: Rotella T6, Motorcraft XT-M5-QS, Redline 75w90
waiting to install (in garage):
Cpe catted dp
Mattcinnc1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mattcinnc1 For This Useful Post:
El Beaner (04-04-2014), King Scumbag (04-05-2014)
 Old 04-04-2014, 06:35 PM   #125
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Cool man. I should hopefully have that map to you tomorrow.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
King Scumbag (04-05-2014), Mattcinnc1 (04-04-2014), OverBoosted (04-04-2014)
 Old 04-04-2014, 06:54 PM   #126
Mattcinnc1's Avatar
Can't wait looking forward to it
Cpe catted dp
The Following User Says Thank You to Mattcinnc1 For This Useful Post:
Justin@Freektune (04-06-2014)
 Old 04-05-2014, 09:23 PM   #127
King Scumbag's Avatar
Posts: 2,384   (View Stats)
I told you you'd get it soon
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
Justin@Freektune (04-06-2014), Mattcinnc1 (04-06-2014)
 Old 04-06-2014, 07:01 PM   #128
OverBoosted's Avatar
Posts: 1,608   (View Stats)
Just wanted to chime in with my Final opinion. This was probably the best money I have spent on my car. Here are a couple VD plots to see my results. Also, Keep in mind that the stg2 log and my personally tweaked log were taken in about 40-50 degree weather and my Freek log was in 65 degree weather.
The Following 2 Users Say Thank You to OverBoosted For This Useful Post:
fr3shmps (02-10-2015), Justin@Freektune (04-06-2014)
 Old 04-06-2014, 07:07 PM   #129
pfp22972's Avatar
Posts: 820   (View Stats)
pfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the world
I agree 100%. Overall, my car drives so much better and is so much stronger than before my Freektune. I am beyond impressed with Justin's work.
Sent from somewhere...but not here.
2010 Celestial Blue Speed 3
- FREEKTUNED -
Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC
CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals
JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete
Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's
pfp22972 is offline   Reply With Quote
The Following 2 Users Say Thank You to pfp22972 For This Useful Post:
Justin@Freektune (04-06-2014), OverBoosted (04-06-2014)
 Old 04-06-2014, 07:18 PM   #130
El Beaner's Avatar
Wish the storms hadn't hit, I was gonna start saving for a test pipe but home repairs took over.
 Old 04-06-2014, 07:21 PM   #131
pfp22972's Avatar
Damn, that's right! You live up in that area. Did you get hit bad?
- FREEKTUNED -
 Old 04-06-2014, 08:24 PM   #132
El Beaner's Avatar
Yep
Holy sh!t:
 Old 04-06-2014, 08:27 PM   #133
Holy shit is right. That's crazy. Hope everything is ok man.
Tapatalked
 Old 04-06-2014, 08:28 PM   #134
El Beaner's Avatar
Tapatalked
Well put the fence back up yesterday. Upgraded to metal posts. Waiting on roof company to assess damage.
 Old 04-06-2014, 09:21 PM   #135
pfp22972's Avatar
I've been in storms like that. Seriously scary stuff. Glad you're ok.
- FREEKTUNED -
 Old 04-07-2014, 02:39 PM   #136
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
Holy spit, that's fast! With my cookie cutter mod list, I may have to go the OTS+ route.
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline   Reply With Quote
 Old 04-07-2014, 04:40 PM   #137
Mattcinnc1's Avatar
Yea man you won't regret it much smoother on the base map even you will be happy and fall in love with the car again
Cpe catted dp
The Following 4 Users Say Thank You to Mattcinnc1 For This Useful Post:
Justin@Freektune (04-07-2014), King Scumbag (04-07-2014), MadOzodi (04-08-2014), OverBoosted (04-07-2014)
 Old 04-07-2014, 04:46 PM   #138
pfp22972's Avatar
The Freektune OTS+ was the best thing I've had done to my car. The car runs so much better and has much more power than any other OTS map I've tried.
- FREEKTUNED -
The Following 4 Users Say Thank You to pfp22972 For This Useful Post:
 Old 04-07-2014, 04:53 PM   #139
This ^
Tapatalked
Justin@Freektune (04-07-2014), MadOzodi (04-08-2014)
 Old 04-07-2014, 05:03 PM   #140
El Beaner's Avatar
Agreed, the feel is so much better. Worth the $75
 Old 04-11-2014, 09:09 PM   #141
Billcraft78's Avatar
Posts: 230   (View Stats)
Billcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the world
Just ordered mine can't wait to see how different the car will feel with a proper tune.
Corksport Sri, Tip, Rmm, springs, CPE tmic, CPE cbe, UR test pipe, JBR PMM, stage 2 oil catch can in vta, shift knob, boost tubes, ssp, AP V3, autotech internals (Freektuned ots+ tune) Forge BPV, alcohol injection systems-progressive meth kit
Billcraft78 is offline   Reply With Quote
The Following User Says Thank You to Billcraft78 For This Useful Post:
Justin@Freektune (04-11-2014)
 Old 04-11-2014, 10:15 PM   #142
mozzie6's Avatar
Posts: 24   (View Stats)
mozzie6 is a glorious beacon of lightmozzie6 is a glorious beacon of lightmozzie6 is a glorious beacon of lightmozzie6 is a glorious beacon of lightmozzie6 is a glorious beacon of lightmozzie6 is a glorious beacon of light
Default Has anyone tried the OTS plus map(s)?
I ordered a v3 from him with an OTS+. Waiting on usps now, so far great email correspondence!
mozzie6 is offline   Reply With Quote
 Old 04-14-2014, 11:37 AM   #143
Will keep you guys updated on how the tune go's and how it feels as soon as I get my 1st 93oct map. I know some people are on the fence about getting an ots+ map over the reg ots maps that are free. So just trying to help you guys out and hope to get @Justin@Freektune; a couple more sales in the process. Can't wait
 Old 04-14-2014, 11:46 AM   #144
mozzie6's Avatar
I am using his OTS+ now! it feels smooth and pulls much harder. It's hard to believe he will be tweeking the map even more so than it already is. It seems perfect.
The Following 2 Users Say Thank You to mozzie6 For This Useful Post:
Billcraft78 (04-14-2014), El Beaner (04-14-2014)
 Old 04-14-2014, 06:14 PM   #145
Just got back in town from the epic nator meet. Which was a blast as always. . So should be able to start getting back to emails and tuning tomorrow
PTE 6062
633HP/523TQ
The Following 5 Users Say Thank You to Justin@Freektune For This Useful Post:
Billcraft78 (04-14-2014), King Scumbag (04-14-2014), MadOzodi (04-15-2014), mozzie6 (04-14-2014), Putin 2.3T (04-15-2014)
 Old 04-14-2014, 06:20 PM   #146
pfp22972's Avatar
I had the same reaction. His base map was already better than the map I had been tweaking for quite some time. The revision truly amazed me with how smooth, yet powerful it was from idle to redline. Justin's Freektunes are the real deal!
- FREEKTUNED -
The Following User Says Thank You to pfp22972 For This Useful Post:
 Old 04-14-2014, 06:22 PM   #147
mozzie6's Avatar
My gas mileage even went up, more power and mpg's? I'll take two!
 Old 04-14-2014, 06:26 PM   #148
atvfreek's Avatar
Posts: 7,787   (View Stats)
I just drove 600 miles and my display reads 29.6 mpg. And anyone that knows me knows how I drive. Lol. Not too shabby for a 500hp car
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
JgamB (04-17-2014)
 Old 04-14-2014, 06:31 PM   #149
pfp22972's Avatar
I noticed a bit of an increase as well but figured it was because I playing far above my knowledge base with my previous map.
That is just amazing to think about. Most supercars with that much power get nowhere near that kind of fuel mileage. Superb work, my friend.
And, I can't even imagine almost doubling the power in my car. That has to be pure adrenaline!
- FREEKTUNED -
Last edited by pfp22972; 04-14-2014 at 06:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-16-2014, 07:37 PM   #150
Got my base map today and it feels strong. Super smooth also and only going to get better. Only had a little time to take it out but definitely feels way way better then my ots map I was running. Super happy my cars got a little Freek in it
The Following 3 Users Say Thank You to Billcraft78 For This Useful Post:
Justin@Freektune (04-16-2014), King Scumbag (04-17-2014), MadOzodi (05-02-2014)
 Old 04-16-2014, 09:07 PM   #151
Glad to hear you can already notice a difference
PTE 6062
633HP/523TQ
Billcraft78 (04-17-2014)
 Old 04-17-2014, 07:50 PM   #152
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
I'm torn on an OTS + or full tune.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
 Old 04-17-2014, 07:56 PM   #153
pfp22972's Avatar
Send Justin an email. He's a great guy and he'll be honest. He'll help you decide. I think it will depend most on what parts you've installed.
- FREEKTUNED -
ABOSWORTH (04-17-2014), Justin@Freektune (04-18-2014)
 Old 04-17-2014, 08:41 PM   #154
JgamB's Avatar
Posts: 2,566   (View Stats)
I detuned to your 93 map for the trip to ENM and managed 31.0 on the ECU computer, most of it spent well above the speed limit and a few WOT pulls past left lane douchebags. It sucks to come off the corn, but it's great to have that economy and still have solid power in your back pocket.
 Old 04-18-2014, 07:42 AM   #155
I would go with the ots+ till your fully bolted as it looks like you have plans to bolt on some more stuff soon. Then go full tune. Talk to Justin anyway to see what he thinks but I'm sure he'll say the same thing. He can get most of the power out the mods you have with just the ots+ map because he's bad ass like that and on a side note my car is running great just on the base map. Just like the other guys said many times before I can't believe it's going to get even better with my revision. Justin is truly awesome at what he does!!!
The Following 2 Users Say Thank You to Billcraft78 For This Useful Post:
El Beaner (04-18-2014), OverBoosted (04-18-2014)
 Old 04-18-2014, 08:04 AM   #156
ABOSWORTH's Avatar
I sent him a PM so we'll see what he says. I know the guy is busy as all hell so I don't expect to hear back any time soon. LOL
Current Mods
 Old 04-18-2014, 05:28 PM   #157
mrshoulders's Avatar
Posts: 652   (View Stats)
mrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the world
Groaned at 86 Times in 51 Posts
You are fully bolted why would not have a custom tune????
2010 Speed3 w/tech
Bolted E85 FREEKTUNE
mrshoulders is offline   Reply With Quote
 Old 04-18-2014, 06:14 PM   #158
Because I am having a full custom tune done very soon so just wanted something to tie me over till then. As we all know these guys are very busy so I'm just waiting till Mr Rob Finkle is ready and has the time for me and I know Justin is also very good so I figured y not just get the ots+ for now.
 Old 04-18-2014, 06:31 PM   #159
That still makes no sense. You spent $75 on a semi tune and will go to a different tuner for full price? Even though it prob would take Justin no more then two weeks to finish. Even tho it doesn't make any sense to me it's your car and you know better then me
2010 Speed3 w/tech
The Following User Says Thank You to mrshoulders For This Useful Post:
Billcraft78 (04-19-2014)
 Old 04-19-2014, 05:30 AM   #160
It makes a ton of sense! I know Rob personly and the price is great
JgamB (04-19-2014)
Page generated in 0.59047 seconds with 33 queries
