  • 2 Post By patABQ
 Old 08-24-2015, 07:39 PM   #1
Clutch8218's Avatar
Posts: 10   (View Stats)
Clutch8218 will become famous soon enough
Default Mr. Freektune
Hello, I am a new mazdaspeed 6 owner and I'm looking to pick up a Cobb accesport with a few other supporting mods.
Is I would like to have you tune the car for me. Now and as I progress with it. So what should my next step be ?
Clutch8218 is offline   Reply With Quote
 Old 08-24-2015, 07:40 PM   #2
Try purchasing a tune through his website.
 Old 08-24-2015, 07:42 PM   #3
Clutch8218's Avatar
That's the plan, but I don't know what to purchase or how he's going to set it up. He should probably know my plans and then he can sell me the right stuff.
 Old 08-24-2015, 07:50 PM   #4
chriswillrise's Avatar
Posts: 98   (View Stats)
chriswillrise is a splendid one to beholdchriswillrise is a splendid one to beholdchriswillrise is a splendid one to beholdchriswillrise is a splendid one to beholdchriswillrise is a splendid one to beholdchriswillrise is a splendid one to beholdchriswillrise is a splendid one to behold
He tunes for what you have, not what you're going to have in the future. Unless you plan on buying everything in one go and installing it very soon.
2008 ms3 |AT HPFP | Corksport SRI/TIP | JBR 70d RMM | Ebay catless test pipe | Corksport Catback exhaust
chriswillrise is offline   Reply With Quote
 Old 08-24-2015, 08:16 PM   #5
Clutch8218's Avatar
Yes @chriswillrise; I am ordering my first set of parts now and when they come in, I am going to install them all at the same time. Then the car is going to stay that way until I learn more and spend the winter planning the next step.
I have emailed him already tho, so I'll see what happens there.
 Old 08-24-2015, 08:37 PM   #6
patABQ's Avatar
Posts: 164   (View Stats)
patABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond repute
Justin is great. However, just starting the mod process you should stick with the basics and use the Cobb standard tunes. Then decide over the winter what you want to do and if you are doing something that requires a special tune (likely), then get Justin involved after you have installed the new mods.
Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa
MS3 Mods
Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter
Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP
Corksport TMIC
CP-E full HPFP with warranty
All Freektuned with two tunes, one for 15psi and another at 20psi
patABQ is offline   Reply With Quote
 Old 08-24-2015, 08:43 PM   #7
Clutch8218's Avatar
OK @patABQ; I just assumed that running the OTS Cobb tune would be a negative. Especially since I'll be relying heavily on the tune to give me the stability and sqeak out all the power possible with the first set of mods I'm going to install.
If Justin's recommendation is to run the standard Cobb tune until I have the big turbo ready to go in then that's what I will do I suppose.
I've just gathered that these cars can be real picky and I don't want to upset the balance.
 Old 08-24-2015, 08:56 PM   #8
brandonnicholson's Avatar
Posts: 1,699   (View Stats)
brandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the world
Buy the accessport from his website, freektune.com and get an ots+ map from him for now.
brandonnicholson is offline   Reply With Quote
The Following User Says Thank You to brandonnicholson For This Useful Post:
Justin@Freektune (08-25-2015)
 Old 08-24-2015, 11:11 PM   #9
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
Step one get accessport.
Step two install mods, and hpfp internals better be on that list.
Step three order tune, during which time you are required to tell Justin what mods you have.
Step four flash said tune and smile everyday
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
The Following 2 Users Say Thank You to Thepedigree13 For This Useful Post:
MS3Shadow (08-25-2015), Raider (08-25-2015)
 Old 08-25-2015, 07:36 AM   #10
patABQ's Avatar
It really depends on the mods. But, do what brandonnicholson suggests and everyone is happy.
MS3 Mods
Corksport TMIC
 Old 08-25-2015, 07:52 AM   #11
Tuff Gong's Avatar
Posts: 153   (View Stats)
Tuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant future
whats the big difference between the the $200 Freektune and the $50 Stratified tune since they both tune for your current mods?
Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds
Tuff Gong is offline   Reply With Quote
 Old 08-25-2015, 07:56 AM   #12
$200 Freektune - multiple revisions to dial in the tune.
$50 Freektune - base map + 1 revision.
 Old 08-25-2015, 07:57 AM   #13
Justin@Freektune's Avatar
Posts: 954   (View Stats)
The $50 tune is just a single flash tune.
The $200 tune is a full custom tune
I offer a $75 tune which is similar to the flash tune, but you also get a revision to dial in the tune a step further.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
 Old 08-25-2015, 08:01 AM   #14
Tuff Gong's Avatar
Ok cool might check you out when im certain i dont have Compression problems.
 Old 08-25-2015, 08:03 AM   #15
patABQ's Avatar
Jump on it with Justin. But you have to have the "ass mods".
Sorry - had to do it. "then as you ass mods we can discuss what the best map options for you are. "
MS3 Mods
Corksport TMIC
The Following 2 Users Say Thank You to patABQ For This Useful Post:
Easter Bunny (08-25-2015), Justin@Freektune (08-25-2015)
 Old 08-25-2015, 07:55 AM   #16
If you order the AP through me, I will put a base map on there for the mods you will have on there when you add the AP. That is my OTS plus map, and then you get a revision to dial it in a little further. That comes free with the AP purchase, then as you add mods we can discuss what the best map options for you are.
PTE 6062
633HP/523TQ
Freektune or no? Castillo817 2010 MS3 - ECU Computer Tuning 37 02-17-2015 07:04 AM
Freektune jseams 2010 MS3 - ECU Computer Tuning 14 12-02-2013 11:48 PM
Freektune and BT = Better MPG? NCspecV81 2010 MS3 - Big Turbo Builds 34 09-11-2013 11:27 AM
Page generated in 0.35838 seconds with 28 queries
