Like Tree26Likes
 Old 09-25-2016, 02:19 PM   #1
Atticaz's Avatar
Posts: 621   (View Stats)
Originally Posted by Speedy955 View Post
I was searching high and low for a v dyno of his base map. I flashed mine and was getting ~230 whp. I know v dyno numbers don't matter much, but that seemed extremely low.
Good to see the revision is where the power comes from.
I was hitting 234whp on my base. In the end you should be around 270ish on the OTS+, in cool weather, depending on your mods. Have patience. I felt the same way. I have since added more mods and went E33 tune and am rockin' 309whp on my last vdyno.
Always chose the same smooth strip of road, start at the same RPM and start at the point in the road, when doing datalog for VD. You'll get the best results. I had to switch my logging road recently, as I have to do all 4th gear logs or roll into the throttle in 3rd, as I always seem to get a bit of slippage, in 3rd, if I stab the gas pedal. Throws off the VD plot.
2007 MAZDASPEED3 - SOLD
local tune or inet tune RACER_X Gen2 MS3 General Discussion 19 11-13-2014 02:05 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
WOT-Tune (My experience) akbrazil 2010 MS3 - ECU Computer Tuning 3 07-09-2012 08:09 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.25361 seconds with 22 queries
