Like Tree26Likes
 Old 02-02-2016, 12:40 PM   #1
Atticaz's Avatar
Posts: 621   (View Stats)
Default My OTS+ Tune Experience
I am new to e-tuning. But this looks pretty sweet for an OTS+ tune. I felt like I needed to really grip that steering wheel, when I floored it, for the first time in a long time. Loving it. Was kinda hoping for a bit more. But, perhaps my smaller Corksport SRI, TIP & OEM CBE are holding that back?
I have yet to drive the required miles to send in the new log to @Justin@Freektune;. But, I'll get them to you soon and toss up some new vdynos.
By the way: I set my OCC Weight at 160 w/ tire height of 25.09.
------ FREEK Base Map OTS+
------ FREEK Revision 1 OTS+
Monforte88 and robbspeed like this.
2007 MAZDASPEED3 - SOLD
The Following 3 Users Say Thank You to Atticaz For This Useful Post:
Monforte88 (02-02-2016), robbspeed (02-03-2016), Speedy955 (09-25-2016)
 Old 02-03-2016, 07:44 PM   #2
Atticaz's Avatar
Did another few pulls on my lunch break. All were a bit lower than the first vdyno above. Here is the best one out of the batch.
EDIT: I am pretty sure I had wheel spin on this pull. Comparing the logs. This second one looks better, from what I have learned so far. I will post the logs soon. Not sure how to tell by looking at the logs if I had spin. My tires are pretty quiet when they spin.
 Old 02-03-2016, 07:55 PM   #3
Snowing's Avatar
Posts: 78   (View Stats)
Snowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud of
Groaned at 3 Times in 1 Post
Awesome numbers! I was running a cobb OTS map which I didn't really like and then switched to the free Stratified OTS stage 2 map which is seems to have my car running much better. I've heard great things about Freektune so I'm sure you will be completely satisfied!
Snowing is offline   Reply With Quote
The Following User Says Thank You to Snowing For This Useful Post:
Atticaz (02-04-2016)
 Old 02-06-2016, 01:13 PM   #4
Atticaz's Avatar
Just did my first 4th gear pull, today. Car is still feeling great. I kinda hoped for more constant horsepower pass its peak around, as all the OTS+ vdyno's on here I have seen seem to. But, it is what it is, right? One revision.
I've had the car for 2 years, now. I think I've done well so far and gained a shit-ton of knowledge from you guys. I wish I woulda known to go larger intake when I picked mine up. But I was super noob, then. Can't wait for the day I can pick up the CS turbo, larger intake and full tune. It may be a while though, unless business picks up.
Here is a newer vdyno and wot log.
EDIT: Concern....Should I be concerned about the WGDC hitting 99.9!?? @Justin@Freektune;
wes3id likes this.
Last edited by Atticaz; 02-06-2016 at 07:13 PM. Reason: Added concern after reviewing the log further. and added another 4th gear vDyno
The Following User Says Thank You to Atticaz For This Useful Post:
Snowing (02-06-2016)
 Old 02-03-2016, 08:03 PM   #5
Atticaz's Avatar
I was gonna type this above. But I got called away from the computer. All in all, the car feels incredible. The power is there when I need it, now. Before, the car was peppy, but it felt a little disconnected. Much more at my command now... even when driving while staying out of boost.
I will definitely go full custom FREEKTUNE, when I get my larger intake and CS turbo.
Justin@Freektune (02-03-2016)
 Old 02-04-2016, 12:59 PM   #6
Atticaz's Avatar
Here are the 2 logs I have handy. Base map and MAF cal w/ couple adjustments to the boost control tables.
 Old 02-04-2016, 01:00 PM   #7
Atticaz's Avatar
For some reason I could upload both logs in the last reply. Here's the other.
 Old 02-04-2016, 01:13 PM   #8
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
I just finished my E85 tune by @Justin@Freektune; and am pretty happy with his work. I also have a 93 tune through him as well. I definitely need to get a better turbo though, a bit disappointed i didn't reach 300whp being fully bolted....but speed6. Justin, your tunes are awesome...thanks again.
File Type: jpg virtual dyno run 1 4th gear pull e85A.jpg (131.4 KB, 115 views)
Atticaz likes this.
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
The Following User Says Thank You to wes3id For This Useful Post:
 Old 02-04-2016, 04:47 PM   #9
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
Just for reference, what were your numbers from the 93 tune, compared to the e85? I'm in the same boat. Wrapping up my 93 ots+ from Freek, and thinking about the e85 ots+.
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
hollar1211 is offline   Reply With Quote
The Following User Says Thank You to hollar1211 For This Useful Post:
 Old 02-04-2016, 04:57 PM   #10
wes3id's Avatar
IIRC it was around 273 or so, but day to day temp differences while logging will change the numbers...unless of course you run both logs the same day within a reasonable amount of time to each other and on the same strip of road. I ran a log the following day after the one i posted and i was down about 10whp and up about 10fpt. so take it for what it is.
I don't trust virtual dyno #'s too much, but it gives a rough estimate.
The Following 2 Users Say Thank You to wes3id For This Useful Post:
Atticaz (02-04-2016), Snowing (02-06-2016)
 Old 02-04-2016, 06:07 PM   #11
Atticaz's Avatar
Not sure how much I trust vdyno either. My first pull was 272. Everyone after has been 265-/+ car feels great though. I'm gonna try to not get so hung up on numbers. TRY. LOL
I just use it to roughly track my gains.
 Old 02-04-2016, 06:39 PM   #12
wes3id's Avatar
Ya i'm "Trying" not to either, but it's hard not being disappointed when you see the numbers
Atticaz likes this.
 Old 02-06-2016, 09:16 PM   #13
speedfreak44's Avatar
Posts: 1,391   (View Stats)
No. 99.9 is fine
The line up:
Atticaz (02-06-2016)
 Old 02-06-2016, 09:18 PM   #14
Atticaz's Avatar
No. 99.9 is fine
Ok good. What does it exactly mean. The WG is letting exhaust gas bypass the compressor or its holding it in? I know noob question. I admit I have a bit more to learn.
 Old 02-06-2016, 09:49 PM   #15
It means the wg is attempting its best to stay closed and build more boost. Basically you have hit the limit of the turbo
Atticaz likes this.
The line up:
The Following 2 Users Say Thank You to speedfreak44 For This Useful Post:
Atticaz (02-06-2016), Snowing (02-07-2016)
 Old 02-07-2016, 07:47 AM   #16
Justin@Freektune's Avatar
Posts: 954   (View Stats)
I can tell just by the sharp of your VD curves that your logging roads are very inconsistent. No Mazdaspeed will ever have peak hp at 4200 rpms as you are seeing in some of your logs
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Atticaz (02-07-2016)
 Old 02-07-2016, 07:57 AM   #17
Atticaz's Avatar
Ok. I wasn't sure if it needed to be the same road. I did see on another forum late lastnight that the road used needs to be the same and flat, free of bumps. I will try to find one and stick to it.
The road on my logs I sent you for the base and revision was a bit bumpy. It's hard to find smooth roads by my house and traffic is pretty congested by my work. Hope that didn't mess with my chances of gaining more power.
Looks like I need to figure out what road I used for that smooth vdyno run?
What conditions cause the vdyno to read peak hp so soon like that, I can know what roads to stay away from using?
Snowing likes this.
 Old 02-07-2016, 09:11 AM   #18
Snowing's Avatar
I think ideal roads would be flat and smooth. I redid some of my logs last night because a portion of the road was bumpy. I wasn't even sure if it mattered but I did them in a different spot anways. Both my logs from the flat smooth road read the EXACT same hp/tq numbers so I was pretty impressed with the consistency of VD in that respect.
2012 Mazdaspeed 3
CS SRI + TIP - CS TMIC - CS Catted DP - Autotech HPFP Internals - Denso ITV22
Purple Drank Tune in process
 Old 02-07-2016, 11:47 AM   #19
Exactly this. If you can't get two logs to lay perfectly on top of each other and be smooth. Then the road isn't sufficient for what you are trying to do. Ideally you should be able to log in both direction on the same road and get the same numbers. Pretty hard to find a road that flat though and a reason to take VD numbers with a grain of salt.
wes3id, Atticaz and Snowing like this.
PTE 6062
633HP/523TQ
 Old 02-07-2016, 12:08 PM   #20
Atticaz's Avatar
I'm just gonna stop sweating the vDyno numbers. All my roads here suck shit. Lol. Car feels awesome. That's all that matters. Can't wait for the larger turbo and full tune.
wes3id likes this.
 Old 02-07-2016, 04:07 PM   #21
wes3id's Avatar
took another 4th gear pull on a different stretch of road.....best i've gotten so far
Atticaz likes this.
 Old 02-07-2016, 04:09 PM   #22
Atticaz's Avatar
Nice. Looks great. Smooth. I'm spooked about the AFR's in my last run.
 Old 02-07-2016, 04:20 PM   #23
wes3id's Avatar
ya you might want to trying cleaning MAF sensor and monitor your AFR at idle and cruising to make sure they are set where they need to be before going WOT.
 Old 02-07-2016, 04:21 PM   #24
Atticaz's Avatar
Just cleaned the MAF sensor before buying the OTS+. Justin said everything looked great.
 Old 02-07-2016, 04:23 PM   #25
wes3id's Avatar
have you tried emailing him that log for him to look at? did you try a different road and compare?
 Old 02-07-2016, 04:25 PM   #26
Atticaz's Avatar
I have tried several roads. Never seen this before. That's why it freaked me out. No changes were done and all of a sudden... I did email him but it would not go through for some reason. Kept coming back. So I tagged him here.
 Old 02-07-2016, 04:29 PM   #27
wes3id's Avatar
try sending him a quick PM. i know emailing him can take days because he's a busy guy. I'm not a fan of bugging people, but if you are really worried about it...i'd try to reach him and ask if he can take a quick look.
 Old 02-07-2016, 07:11 PM   #28
I would grab another log and see if it repeats. If so. You have a leak or hardware issue
PTE 6062
633HP/523TQ
 Old 02-07-2016, 07:45 PM   #29
Atticaz's Avatar
I did a short one, before I saw this reply @ ~4100 to ~6000 and there were no signs of the issue.
I'll grab a few more tomorrow. If I am just doing WOT logs to check AFR at WOT, does it sill need to be the same road, or is that just for vDyno?
Just a thought. My AP was glitching earlier. I am hoping this is the issue. I did two WOT runs and the AP overlapped them as one. Weird.
 Old 02-07-2016, 07:46 PM   #30
Snowing's Avatar
I did a short, before I saw this reply @ ~4100 to ~6000 and there were no signs of the issue.
I would think that no matter the road conditions you should be under 12 a/f.
2012 Mazdaspeed 3
 Old 02-08-2016, 01:17 PM   #31
Atticaz's Avatar
I just noticed I had the CF set wrong in my last vdyno. Will fix when get home.
Can't fix the above CF. Mistakingly deleted the logs. Shit
 Old 02-10-2016, 01:56 PM   #32
Atticaz's Avatar
Here is my latest vDyno.
For whatever reason, I have been running lean for the first half of some pulls and only at the beginning of some of my WOT pulls. (Seen in the most recent vDyno above.) One most recent was 12.9's for the first half of the pull. Most of the pulls, AFR's are falling within mid to high 11's.
I am pretty sure its not tune related. Something is off. If it were tune related it wouldn't be so erratic. But the cool thing about having a tuner is they are all about helping you out.
Justin is a great guy and is helping troubleshoot this.
So far I have double checked the torque on all DP bolts, looked for exhaust leaks, went back to the stock BPV, pulled a few more logs and sent them off to him. So far, the issue hasn't shown up again. At the beginning of one log the AFR's were lean for a about 4-5 cells of the CSV spreadsheet, which I believe is a very short time and nothing to worry about. I hope.
This shit freaks me out <- pun not intended.
So far, I have been hanging around 268/270 average whp. Can't complain too much for an OTS.
Car feels great. After I figure out the lean issue and complete my TBE, by getting the CNT CBE, I think I am going full tune. Can't wait for the BT. Need moar powa.
wes3id likes this.
 Old 02-10-2016, 02:02 PM   #33
wes3id's Avatar
Just ordered a BNR S3 and will go full Freaktune for both 93 and E85...coming soon
Atticaz and Justin@Freektune like this.
 Old 02-11-2016, 04:21 PM   #34
Atticaz's Avatar
I believe I got this lean AFR at WOT shizz all figured out. Thanks to this thread... Very last post. SU Turbosmart - 10-20psi or 20-25psi spring for stock k04??
Thanks Street Unit. #sarcasm I have the proper spring on order and the OEM BPV installed for the time being.
wes3id and Justin@Freektune like this.
Justin@Freektune (02-11-2016)
 Old 02-14-2016, 04:09 PM   #35
Atticaz's Avatar
@Justin@Freektune; I have the stronger spring on the way, for my BPV. Meanwhile, I'm leaving the stock BPV in. I decided that I am going to buy a full tune from you VERY soon. But I am picking up a CS 3" intake first. That is on its way too.
Is the $75 OTS+ tune still a credit towards the full tune?
 Old 02-15-2016, 06:07 AM   #36
There is a credit that goes toward the full tune. Shoot me an email when you are about ready and I will get you a discount code to use
MS3Shadow, Atticaz and Elitesweets like this.
PTE 6062
633HP/523TQ
Atticaz (02-19-2016), MS3Shadow (02-15-2016), Tifosi42 (02-17-2016)
 Old 02-19-2016, 10:17 PM   #37
Atticaz's Avatar
I just got my 3" CS Intake in and ordered my full custom Freektune. The OTS+ was great. But it's time to move on.
 Old 02-20-2016, 05:48 AM   #38
Tifosi42's Avatar
Posts: 179   (View Stats)
Why not 3.5" intake? If I could do it over again, I'd do it right the first time and get a 3.5" intake. I probably will eventually with a battery box as well, especially when I go to upgrade the turbo. I can't wait until spring to do my in tank meth tune with Freektune!
BNR S3 - FREEKTUNED on E33
 Old 02-20-2016, 07:47 AM   #39
dale_gribble's Avatar
Posts: 4,720   (View Stats)
There's no point to go overkill on intake. You lose low flow resolution (idle, off idle) resulting in a rough idle and for example instead of having 0-4.5v of resolution, you only have 0-4v on MAF sensor. Even Bnr s3 and cs turbo can't outflow 3" intake. 3" is a good size.
MINI H1 6.0 - CAR LED TAILS
Atticaz (02-20-2016), Tifosi42 (02-20-2016)
 Old 02-21-2016, 03:38 PM   #40
Atticaz's Avatar
I am digging the size difference! Got her all installed and slumming it with a Cobb Stage 2 OTS, for now. not digging the power loss though. anxiously awaiting my Freektune base map.
From the looks of the sludge shown in the turbo pic, its time for an OCC?
local tune or inet tune RACER_X Gen2 MS3 General Discussion 19 11-13-2014 02:05 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
WOT-Tune (My experience) akbrazil 2010 MS3 - ECU Computer Tuning 3 07-09-2012 08:09 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.59625 seconds with 28 queries
