 Old 02-18-2015, 09:09 PM   #1
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
Default This is why you FREEK
So as some of you may know, I recently decided to install a shmedium turbo. My car is my daily and I wasn't interested in breaking any records, so with response and drivability in mind i decided to go with the GTX2867r. I purchased the turbo/tune from Justin as a bundle when he was running the site-wide 5% off in response to the COBB sale. Justin contacted me right away with tracking info and the turbo arrived at my door within a few days. Justin was very straight forward and helpful with making sure all of my supporting mods were right to reach the goals I had set. I was provided with a base map right away and from there he build began. The longblock itself was the only thing that wasn't replaced. Once the install was finished the fuel system was primed and the base map was loaded. I crossed my fingers and turned the key and car immediately roared to life and settled itself in to a perfectly smooth idle. After only 6 revisions i present you with my final numbers...
I couldn't be happier with the outcome of this process. Justin managed to get me almost 45 more horsepower than i had figured i would put down on pump gas. He has been an absolute pleasure to work with and his communication is second to none. I cant wait to work with him again when my methanol setup is ready to go.
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
The Following 8 Users Say Thank You to getemslough For This Useful Post:
Agent_Orange (02-19-2015), Blk_pu (02-19-2015), Code Monkey (02-18-2015), Easter Bunny (02-19-2015), Hush (02-19-2015), mxlplx71 (02-19-2015), Scare Dem (02-19-2015), taf0422 (02-19-2015)
 Old 02-19-2015, 03:15 AM   #2
Scare Dem's Avatar
Posts: 1,505   (View Stats)
Great numbers. How many miles are on your motor?
2008 Mazdaspeed3 GT
GTX2867r
getemslough (02-19-2015)
 Old 02-19-2015, 04:30 AM   #3
Blk_pu's Avatar
Posts: 190   (View Stats)
Blk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond repute
Very nice on a conservative build! I am excited to give my map a shot and see what numbers I can pick up on my poo.
Cobb AP V3 - HTP 3" intake system - UR axleback - Depo catted downpipe - Forge Black BPV - ADD W1 oil catch can - JBR cylindrical shit knob - JBR shit plate - JBR solid shit bushings - JBR 88d RMM - JBR RSB
Blk_pu is offline   Reply With Quote
The Following User Says Thank You to Blk_pu For This Useful Post:
 Old 02-19-2015, 05:40 AM   #4
lnumbp's Avatar
Posts: 178   (View Stats)
lnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the worldlnumbp is the leader of the world
All that power on only 22 psi. Those are some great results.
2007 COSMIC BLUE MICA MS3 GT
ENGINE↑ AUTOTECH CDFP ♦ BNR S3 V2 ♦ CP-E: DP, SAFESEAL ♦ DO 2.5 BAR KIT ♦ ETS TMIC ♦ JBR: 3" WP, 88 DURO TRILOGY, EGR DELETE, TIG ♦ MAGNAFLOW CBE ♦ SYNAPSE DV
SUSPENSION≈ BILSTEN B8 ♦ SWIFT SPEC-R ♦ WHITELINE: ALK, BUMP STEER CORRECTION, POLY BUSHINGS
WHEELS & TIRES↓ ENKEI EVOLUTION X ♦ MICHELIN PILOT SUPER SPORT
CREATURE COMFORTS☺ TWM FULL ASSEMBLY ♦ STRATIFIED EXTENDER
TUNED BY
lnumbp is offline   Reply With Quote
The Following User Says Thank You to lnumbp For This Useful Post:
 Old 02-19-2015, 08:14 AM   #5
Gixxer2k4's Avatar
Posts: 130   (View Stats)
Gixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond reputeGixxer2k4 has a reputation beyond repute
Really great #'s OP! Can't wait to see what he does with my 3071r.
Gixxer2k4 is offline   Reply With Quote
The Following User Says Thank You to Gixxer2k4 For This Useful Post:
 Old 02-19-2015, 08:25 AM   #6
Thanks everyone! And @Scare Dem; I am at 74k.
The Following User Says Thank You to getemslough For This Useful Post:
 Old 02-19-2015, 08:32 AM   #7
#WUTLIP
ge3kspd's Avatar
Posts: 201   (View Stats)
ge3kspd has disabled reputation
Looks solid. What kind of ambient temps were you seeing during these logs?
Atp Gtx2871r Hypnotic tuned with sprinkles of unicorn jizz.
ge3kspd is offline   Reply With Quote
The Following User Says Thank You to ge3kspd For This Useful Post:
 Old 02-19-2015, 09:20 AM   #8
it was between 60 and 65.
ge3kspd (02-19-2015)
 Old 02-19-2015, 07:06 PM   #9
sheston's Avatar
Posts: 1,847   (View Stats)
Can't wait to see the results with Meth!
If you don't like or want E, ask the @Freektune; what he thinks about Meth in your tank. I feel it adds a lot of safety to any tune and lets you really roar
 Old 02-19-2015, 08:28 PM   #10
i may look into that, the plan is a tb spacer with opposing do7 nozzles though
 Old 02-20-2015, 02:52 PM   #11
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Great results! Hope you don't mind if I pick your brain a little bit here. A few weeks ago I was talking to a local and he was steering me away from the BNR S3 and towards a GTX2867R. In researching what this turbo can do, I have found that it is much more in line with my goals, which is right around what OP is putting down (I'm also at sea level, w/93 octane), with room to grow in the future if I decide to build my bottom end. Right now I am thinking it is most logical to either go with the ATP GTX2867R IWG kit, or the ATP GTX3067R EWG kit...with a lengthy and expensive list of supporting mods including a Freek tune. The reasons I would choose an ATP kit are convenience and cost.
My question is whether or not you're getting any creep with the catted CS long downpipe and the ATP IWG. In looking through MSF I have found:
1) Everyone universally says that you need to upgrade the downpipe to run a larger turbo like this
2) People with catless downpipes are all getting creep
3) People with catted downpipes are sometimes getting a small, but not necessarily problematic amount of creep
What I don't understand is why I couldn't run the stock downpipe with a test pipe. I have a hard time believing there's some kind of massive increase to be had going from the stock DP with a TP to a catted long DP. Thanks in advance for anyone's input here.
edit: I forgot to add, said local was adamant that I get a 3" catless downpipe.
2007 Mazdaspeed3 GT
 Old 02-20-2015, 03:07 PM   #12
I gotthatzumzum's Avatar
Posts: 552   (View Stats)
I gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the world
I'm actually looking into downpipes right now to hopefully replace mine soon. From what I have read, people have seen upwards of 40+hp gains just from a downpipe and retune (obviously with hpfp internals). That right there should be picture enough as to why a downpipe would be needed. There is plenty of aftermarket downpipe options that still retain a HFC, which is the direction I'm headed. Personally, I feel it's the best of both worlds, and should help with creep as well.
i wish more than like 2 colors didnt look stupid on my fucking brightest red ever car
I gotthatzumzum is offline   Reply With Quote
 Old 02-20-2015, 04:24 PM   #13
Scare Dem's Avatar
A good free-flowing exhaust is best with a bigger turbo.
Does a downpipe make a difference?
2008 Mazdaspeed3 GT
GTX2867r
 Old 02-20-2015, 03:03 PM   #14
No creep issues here at all.
FREEK vs Brand X Smelson FREEKTUNE 48 05-27-2015 06:42 AM
Getting Freek Tuned! Weston FREEKTUNE 4 08-24-2014 05:51 PM
Tuning with the Freek Teethkikr 2010 MS3 - ECU Computer Tuning 224 05-10-2012 05:46 PM
How to get Freek'd! GunGuru727 2010 MS3 - ECU Computer Tuning 29 04-24-2012 11:43 AM
Page generated in 0.36505 seconds with 29 queries
