Mazdaspeed Forums
-   FJ Performance (http://www.mazdaspeedforum.org/forum/forum/f736/)
-   -   FJBuilt Ultimate short block Finally Released!!! (http://www.mazdaspeedforum.org/forum/forum/f736/fjbuilt-ultimate-short-block-finally-released-190647/)
Matt@FJPerformance 07-10-2015 06:46 AM
3 Attachment(s)
We have finally released our Ultimate sleeved short block!!!! Starting at only $5499
A lot of people ask what makes this different from our current short block. SLEEVES!!
If you're making too much power for the weak stock engine to handle, or you've already shattered your engine block - along with your hopes and dreams - you need this bottom end. Included is an assembled ready to go short block with forged rods, forged alloy pistons, Seasoned cylinder block thats given our own special FJ treatment and crankshaft and new bearings. Short block is assembled to specified parameters by our technicians and shipped ground freight to the destination.
Engines are assembled with Manley H plus beams and Manley Pistons pistons at the factory compression ratio, crank is rebalanced after removing balance shaft gear, balance shaft delete and baffle kit. Individual components are subject to manufacturer warranty. As a high performance engine with widely varied applications and abuse patterns, there is no warranty expressed or implied on the assembly. Message us for shipping quote
($1900 core charge applies)
Core Requirements:
Inspect sleeves for cracks
All main bolts and main girdle must be included
It must be properly packaged with protection on all sides
Please clean off as much oil residue as is possible
Remove all accessories (anything that is attached to the engine)
Leave anything internally on the engine as a part of the core.
WHAT REALLY SEPERATES FJ FROM THE REST?
Attention to detail. Our blocks are machined to the most precise specs possible to give our customers the absolute best product we can! Its your hard earned money, you deserve the best!!!
Here are some pics of a customers FJBuilt Ultimate block being assembled. Please feel free to message us with any questions
Mazdazilla6 07-10-2015 07:06 PM
Two questions:
1. Are dry sleeves an option?
2. Can we purchase just a block?
LumberJack 07-11-2015 10:37 AM
Quote:
Originally Posted by Mazdazilla6 (Post 2914702)
Two questions:
Those particular sleeves are a Darton MID Sleeve which is a true WET Sleeve option. As far as I can recall darton does not offer a dry sleeve for our motors, but maybe Matt could clarify a little further.
Matt@FJPerformance 07-11-2015 10:42 AM
Wet sleeves are all we offer and yes we could sell you a bare FJBuilt block with just sleeves. Message us for details
Page generated in 0.16775 seconds with 11 queries
