| FJ Performance FJ Performance is dedicated to serving the community in the best way possible. We carry everything from OEM mazda parts to built long blocks. We also have our own product line FJBuilt. We have been in the mazda game for several years now and have a great understanding of the mazdaspeed platform as well as a few others. If you have any other questions about who we are or what we do please ask. |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
(Thread Starter) | Not Ranked : 0 score In May/June of 2014 i decided i was a little bored of my GTX2867r the turbo was great and made good power but the power plateaued around 6k. I have a really good relation ship with Matt @ FJ and decided to bug him about a turbo kit. The original idea was to swap my gtx28 to a t3 housing and get some more top end out of it. i say original idea because that all changed when @Captain KR; and my self arrived at FJ. i want to get this out of the way now the staff at FJ is like no other. Fran,Matt, & Cresto did more for me that weekend than i can possibly thank them for. Fast forward to August 2014 When we got there we strapped my car down on the dyno as is with the gtx28 it made 414/425. This was on 24psi and a pretty aggressive timing curve. We then put my car on the lift and stripped off my GTX28, manifold, dp, and hot pipe. It was then that the decision was made after Matt pulled the s360 out of the box for 30 seconds that i would be using it instead haha. At the time all that was made was the manifold. Which in turn caused Matt to shofer me to various speed shops to get AN fittings/Line and other random parts to make this work. The manifold and turbo got mocked up on friday, and i kid you not Cresto and Matt were up ALL night fabbing my Downpipe, dump tube, Undermotor Hot pipe(yes fj had this done in 2014 lol), and my connection to the catback . We left the shop at 3am to get some sleep and when we came back it was all there. All we had to do was finish the install. The install it self is not a bad process. The manifold does require a little wizardry to get in and you will need a second set of hands to pull the turbo up while bolting it to the manifold but really that's the hardest part. After we finished the install it was time to get some miles on the car. Everything worked the first time. There was a little creep, but it was easily manageable. We slapped it on the dyno and put down 420whp @ 22psi with a conservative 14* timing map.Boost came on later but it carries all the way till redline. I left it at that because i was 9 hrs away from home and a pussy bahahaha. See the dyno vid at the bottom of this review. So while all this is great the car made power the exceptional part to me is this. I've had this prototype kit on my car for 12 months and over 10,000 miles, and i haven't had to touch this kit ONCE since the initial install.Not one bolt, Vband, or clamp everything just works. I've run it at boost pressure ranging from 22-32psi on my stock motor and never has the kit given me a single problem. The craftsmanship of this turbo kit is second to none. Cresto even with a pissed off fiance, stayed all night, took his time, and made sure my kit was fabricated right the first time. TLDR: kit is great heres a dyno vid. FJ went above and beyond for me.
__________________ Last edited by 2.0t03speed; 08-05-2015 at 12:47 PM. |
| The Following 29 Users Say Thank You to 2.0t03speed For This Useful Post: | 2eatV8everyday (08-13-2015), Amnesiac (08-05-2015), aromig (08-05-2015), blakjak0271 (08-06-2015), brandon3212 (08-05-2015), Captain KR (08-05-2015), Dralphy (08-06-2015), Easter Bunny (08-05-2015), Farhan@DM (09-07-2015), g00s3y (08-08-2015), hermz (12-08-2015), impossible (05-01-2016), ItsNox (08-07-2015), Jackis (08-12-2015), Jester2552 (08-15-2015), Justin@Freektune (08-06-2015), KiwiFlavor (12-08-2015), maisonvi (08-05-2015), Matt@FJPerformance (08-05-2015), Mauro_Penguin (08-06-2015), Mazdazilla6 (01-26-2016), PUGENE (09-16-2015), Scare Dem (08-05-2015), Shwaykid (08-05-2015), tastysi2004 (08-06-2015), Thepedigree13 (08-05-2015), TRBLSM (08-05-2015), WAMBUSHHHH! (08-07-2015), WetzMS3 (08-05-2015) |
(Thread Starter) | Not Ranked : 0 score Also here is a vdyno from one of my most aggressive timing maps.
__________________ |
| The Following 9 Users Say Thank You to 2.0t03speed For This Useful Post: | aromig (08-05-2015), BLKSTIG (08-05-2015), Easter Bunny (08-05-2015), Hammology (08-05-2015), impossible (05-01-2016), KiwiFlavor (12-08-2015), Matt@FJPerformance (08-06-2015), NCspecV81 (08-07-2015), RE-ACTIONENGSPEED3 (08-07-2015) |
![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score Will this kit ever be able to bolt on to a speed6?
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
(Thread Starter) | Not Ranked : 0 score One Day. Drive there and let the, test fit it on your 6.
| The Following User Says Thank You to 2.0t03speed For This Useful Post: | Matt@FJPerformance (08-06-2015) |
![]() Join Date: May 2012 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score Wow that is was a very nice right up. The video was crazy too. Was all of this done on a stock block? How much is this kit?
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq Last edited by knocturnal; 08-05-2015 at 05:10 PM. Reason: Info missing |
| The Following User Says Thank You to knocturnal For This Useful Post: | Matt@FJPerformance (08-06-2015) |
| Not Ranked : 0 score No way I am driving my car from ALASKA to the East coast LOL, NO THANKS. I volunteer someone else !
| The Following 2 Users Say Thank You to levon.mark For This Useful Post: | Easter Bunny (08-05-2015), WAMBUSHHHH! (08-07-2015) |
| Not Ranked : 0 score Intake is too small.
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
| Not Ranked : 0 score I installed the whole kit by myself. Holding a 5858 awkwardly placed in one hand and bolting it to the EM at the same time was interesting to say the least.
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG |
| The Following 2 Users Say Thank You to King Scumbag For This Useful Post: | Easter Bunny (08-05-2015), Matt@FJPerformance (08-06-2015) |
| Not Ranked : 0 score Thanks for posting this review. Now if we could only get @Captain KR; to update his build thread.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Mauro_Penguin (08-06-2015) |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
| Not Ranked : 0 score Holy shit, that makes me fuckin moist.
__________________ "I apologize for nothing!" - Hedonismbot ![]() |
| The Following User Says Thank You to aromig For This Useful Post: | Matt@FJPerformance (08-06-2015) |
i know too bad they don't have and 4.5" intakes besides custom.
lol good luck he is lazy. i'll be up at his car on saturday tho.
__________________ | |||
| The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post: | Code Monkey (08-05-2015), Matt@FJPerformance (08-06-2015) |
| Banned ![]() Join Date: Jun 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
| Not Ranked : 0 score Thanks Ryan for the awesome review!! As far as the speed 6, we are trying to figure out a kit, we know the speed 6 crowd gets left in the dark. The problem is we can never have a speed 6 for an extended period of time. Everyone always says well I'll drop it off for the weekend. To turn out a high quality product, we would need one for an extended period of time. But we are working on it!!! |
| The Following 7 Users Say Thank You to Matt@FJPerformance For This Useful Post: | 2.0t03speed (08-06-2015), Easter Bunny (08-06-2015), impossible (05-01-2016), ItsNox (08-07-2015), Mauro_Penguin (08-06-2015), Thepedigree13 (08-08-2015), Turbo gI (12-09-2015) |
| Not Ranked : 0 score @dagrimey1; have your build done and be a test 6 right there and it's 10min from your wife's family. Just saying.
| The Following 2 Users Say Thank You to King Scumbag For This Useful Post: | ItsNox (08-07-2015), Matt@FJPerformance (08-06-2015) |
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Do they sell that turbo manifold by itself? My god that thing is sexy as fuck!
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
| The Following User Says Thank You to JakeMS3 For This Useful Post: | Shwa (08-06-2015) |
| Not Ranked : 0 score @2.0t03speed; you didn't have any problem with clearance on the dump tube between the block and the axle?
-__-
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG | |
(Thread Starter) | Not Ranked : 0 score Yep like i said prototype kit is different haha. my downpipe also doesn't have a flex section in it. Also i don't know if the production kit is like this but my hot pipe is 2 pieces
![]() | | #19 | ![]() |
Mine is two pieces as well, 90 before the IC and then the rest to the ouutlet. My dump tube sits between my block and my axle. Adjust it one way it rattles off the block, adjust it the other way it rattles and rubs into the axle. As well as basically dumps onto the charge pipe..
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh man thats completly different than my routing. did you try wrapping the dump tube and putting it up against the block ?
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Another view of my hot pipe/dump
![]() | | #25 | ![]() |
| Not Ranked : 0 score If I wrap it to much it will be in contact with both. I tried wedging a peice of high temp tubing on the side and against the block but it just vibrates free. Regardless the dump still dumps right into the charge piping. I've tried orienting that dump every way to Sunday and this is the only routing in which it fits. The axle is about grooved right through the sidewalk of the dump tube at this point.
![]() | | #26 | ![]() |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score @King Scumbag; have you contacted fj about this problem before now? Has it caused any false knock issues?
__________________ 417whp 428tq 12.037@117.2mph |
![]() | | #27 | ![]() |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| Not Ranked : 0 score bang bang goes the hammer for clearance
| V2 Pre-amp | | |
![]() | | #28 | ![]() |
![]() Join Date: Sep 2011 Location: virginia, portsmouth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 164
| Not Ranked : 0 score Fanstastico write up Ryan.
__________________ 2008 MS3 gt mica black EL NATOR DE Virginia/Florida Update: getting that Purple drank in my tank. build block, pnp everything, tr825 core, meth and lots of it. 554whp/546wtq @ 30psi. another build? maybe soon.. b/c race cars need more attention than women. . ![]() ![]() adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~ #CATBACKEXHAUST |
![]() | | #29 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Around 540 and not even 26psi that's mental, . What is the fucker capable of with boost wound up.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Matt made 630ish @ 30 psi if i remember right. Also the 1-2-1 Canadian with the ms6 made around 580 i think @ 28 psi. Like i said that was pretty much the most aggressive timing map i ever made.
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
![]() Join Date: Sep 2012 Location: Escondido, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 296
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Beautiful kit and nice numbers, the SC guys over on the Club Lexus forums love the S360/366 for the quicker spool characteristic (3.0L) and price of these turbochargers. A few guys have made 650-700 on 100% E85 with these
__________________ Stocked Out with my Cock out |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Whats this turbo like when belting it through the gears is it pretty much instant boost like a 5858PTE or 30 frame garret etc?
| The Following User Says Thank You to shaneski For This Useful Post: | BLKSTIG (08-15-2015) |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score this turbo is much larger than those 2 turbos and it's journal bearing. So there is some lag associated with it. For reference this turbo flows 71lb/min and a gt4088r flows 72lb/min
| The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post: | Easter Bunny (08-16-2015), shaneski (08-17-2015) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score But it makes the power!!! Sent from my iPhone using Tapatalk |
![]() | | #36 | ![]() |
![]() Join Date: Mar 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score @King Scumbag; That is what mine does as well. When I install my built motor, I think I'm going to change the routing of the dump tube so it's more like Ryan's. And I agree, there's about no way to avoid it either rattling or rubbing on the axle. On the bright side, our axles are stronger than the cast piping...lol. @levon.mark; The biggest issue with the speed 6 is the intercooler piping. Because of the transfer case (mostly the sheer size of it), the intercooler piping can't be run down around the motor like this. The dump tube will also need something creative done, probably routed back with the downpipe, just to have clearance. @shaneski; Initial spool is a little laggy, but there's not a whole lot you can really do about that on a turbo frame this size. This turbo maintains wheel speed really well between gears though, for a journal bearing turbo at least, so when banging gears, the lag is nearly negligible.
__________________ Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11 Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS) [SIGPIC][/SIGPIC] K04 POWER FIGURES 277HP/325TQ SixTuned On 93 314HP/356TQ Rfinkle2 Tuned With 33% Corn S360 POWER FIGURES 365HP/356TQ Purple Drank Tuned ON 93 421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING |
| The Following 4 Users Say Thank You to Ray Danger 2020 For This Useful Post: | 2.0t03speed (08-17-2015), Easter Bunny (08-16-2015), Matt@FJPerformance (08-17-2015), shaneski (08-17-2015) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score I don't care about the intercooler piping being routed underneath my block lol. I just want more bolt on options to pick from. At this rate, I am better off buying a DC TIG welder and doing everything myself! The only kit that I see that is truly bolt on, is kosmic's kit, which is pretty expensive for what you get.
![]() | | #38 | ![]() |
![]() Join Date: Nov 2010 Location: Saint-Petersburg, RU
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
| Not Ranked : 0 score Wow, some nice numbers. I remember bout the cams, I am still waiting for detailed response from local. But the very first answer was: all the bolts locations are the same, width is the same, timing should be manually set with the clock timing tool, thats true. I am waiting for part #, ref data and more info. We are considering now for local russian builds some S200SXE turbos with new style compressor wheel. From reading the maps and understanding the wheels geometry, they should be lil bigger than 5858, but the price really matters, we can get them for 800bucks! BorgWarner S200SX-E Has someone here gone this way?
__________________ Does your MS3 start when it's -30C (-22F)? Forged, bolted, tuned, gtx30/tial/ewg. Thanks. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score No one has yet but it will be something we will be offering soon with our kits. We love our BWs around here! We like the way you think Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Matt@FJPerformance For This Useful Post: | Jackis (09-04-2015) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Not too many people run BW on our cars so it's kind of tough to find info for them. What size oil feed does your kit use and are you using a restrictor at all?
| Corksport turbo review | hitANDrun21 | CorkSport | 117 | 01-16-2016 04:08 PM |
| Review: 2013 Fiat 500 Turbo | Haltech | Automotive News | 0 | 05-20-2013 10:30 AM |
| PG Turbo Inlet Impressions and Review | NCZ13 | MazdaSpeed 3/6 - Turbo Induction | 30 | 06-18-2011 03:15 PM |
| HKS Type-0 Turbo Timer Review | joos89 | MazdaSpeed 3/6 - Car Audio & Electronics | 9 | 11-18-2009 01:35 AM |
