Ultimate long block release I will post pictures soon., but a lot of people ask us how much for everything to be done and upgraded! Well we have finally decided to launch a product that will do just that for you. Introducing our new Ultimate long block, it will be on the website soon on sale for $7099 This block has everything you ever could need for your mazdaspeed 3/6 Engines are sleeved with darton wet sleeves then assembled with Manley turbo tuff I beams and Manley Pistons at the factory compression ratio, crank is rebalanced after removing balance shaft gear, balance shaft delete and baffle kit. Individual components are subject to manufacturer warranty. As a high performance engine with widely varied applications and abuse patterns, there is no warranty expressed or implied on the assembly. Head is completely ported intake and exhaust side, all valves are upgraded to +1 as well as crower 65lb springs. all motors receive the following Mazda OEM Timing Chain Mazda OEM Timing Chain Tensioner Mazda OEM Camshaft Bolt Mazda OEM Camshaft Washer Mazda OEM Friction Washers x3 Mazda OEM Crank Pulley Bolt Mazda OEM Front Oil Seal Mazda OEM Chain Guides Mazda OEM Valve Cover Gasket Mazda OEM Oil Pump Mazda OEM Rear main seal Mazda OEM Oil pick up tube note core charge of 3100 applies for long block(we suggest you send yours in first) Please feel free to ask us any questions. We are very happy to bring another great product to the community! |
I've been trying to figure out how I'd upgrade my block to fix my low compression issue and take more advantage of my gtx3076. This seems like a sound path. About how much power would you say the motor is safely rated for? |
Quote:
Honestly this thing will handle anything you throw at it. This block was designed to handle 4 digit land. I realize thats over kill but better safe than sorry! We can def get you set up with what you need asap! |
Keyed crank and sprocket? Pinned cams? |
What headstuds? |
L19s and yes keyed crank and sprocket Sent from my iPhone using Tapatalk |
Subbed. I'll have to save this thread for possible future use. |
| All times are GMT -7. The time now is 01:17 AM. |
