Event Rules 4/17/2016: Rules and Classes Update!!! UPDATE: Official Start Date: May 1st End Date: December 31st Video and a time slip will be required to validate the run. Come December 31st, we will have a winner for each class. Simple as that folks! STOCK TURBO -Any FWD/AWD- DISI MZR powered 3/6 -Car must retain stock appearing exhaust manifold. -Turbo must use the stock bolt pattern from the exhaust manifold/header to the turbine housing and be located in the stock location. -Turbo must retain STOCK compressor housing. This means bone stock turbo, S1, billet wheel upgraded k04's, etc. Nothing larger. -External dumps are not permitted. -Full exhaust exiting the rear of the vehicle is required. -FMIC, intercooler plumbing, turbo inlet with air filter, small battery kits are all OK for this class. -Two front seats, front door panels, full factory dash, center console and glove box door required. -No Lexan. STOCK APPEARING TURBOS -Any FWD/AWD- DISI MZR powered 3/6 -Car must retain a stock flange manifold pattern -Turbo must remain in the stock location. -Any variation of modified compressor housing is permitted. ( BNR, ATP, CS etc are all permitted, but MUST RETAIN STOCK EXHAUST FLANGE PATTER ) -No Hood Exit Dumps permitted. Open Long down pipe or exhaust cutouts are allowed. -FMIC, intercooler plumbing, turbo inlet with air filter, small battery kits are all OK for this class. -Two front seats, front door panels, full factory dash, center console and glove box door required. -No Lexan. QUICK STREET -Any FWD/AWD- DISI MZR powered 3/6 - Any exhaust manifold style may be used and any size Compressor wheel is acceptable. ( If you feel you can compete in this class with a smaller turbo, then by all means compete your little heart out. ) -OEM front and rear style/location suspension. Springs/coilovers/sway bars/control arms aftermarket are permitted. -Exhaust may Exit the vehicle anywhere. -Wastegate(s) may Exit the vehicle anywhere. -1 Seat is permitted, front door panels, factory dash, and center console must be intact. Glove box and any items behind dash permitted to be removed. - Any form of Aero acceptable. ( Mirror deletes, fog deletes, drag wing etc are PERMITTED ) -No Lexan. Some things to note -No turbo size restriction for QS class. -No fuel restriction for any class. Auxiliary fueling, port injection, meth injection, fuel cells etc are all permitted. -No weight requirements as most tracks don't open their scales unless it's an NHRA event. -One of the most interesting parts of the Shootout classes is the fact that people literally form their builds, choose their parts, etc, around these classes. I think instead of adding any more classes to appease the "tweeners", just use this structure to force some people to make some slight build changes. That's what makes it interesting. Official Entrants List: Stock Turbo Class @xfeejayx; @PurplFox; @nindoja; Stock Appearing Turbo Class @WetzMS3; @JgamB; @snailD; @shaneski; Quick Street Class @Micha; @Justin@Freektune; @LumberJack; @mazdafreak; @atvfreek; @Etipp98; @HOCKEYNUBE; |
Quote:
Perhaps list the rules as what's isn't allowed, or you might end up fielding questions like this for a while. @LumberJack; |
So who is in and in what class so far? Is there an end date for entering or just open to whoever, whenever? I'm guessing at this point, no cash is involved? Stock Turbo Class @xfeejayx; @PurplFox; @nindoja; Stock Appearing Turbo Class @WetzMS3; @JgamB; Quick Street Class @Micha; @Justin@Freektune; @LumberJack; @mazdafreak; @atvfreek; @Etipp98; Feel free to add to the list or correct it. I apologize if I forgot or have no idea who is running what setup at this point. There were 18 votes in the other poll, but I have no way to see who voted, if we could somehow tag everyone who voted, that may help organize. |
Hmm, I guess I could technically run in both classes? Stock turbo in my 3 and stock appearing in the 6. |
Thank you @WetzMS3; for the quick list that you started. Please just copy and paste this list and add your names to it and I will update in this OP any time I log into MSF. I didn't allow the poll to show who has voted so I'm not too sure who has all voted yet either, but we have quite a few more votes than what we have for names on this list at this moment. Stock Turbo Class @xfeejayx; @PurplFox; @nindoja; Stock Appearing Turbo Class @WetzMS3; @JgamB; Quick Street Class @Micha; @Justin@Freektune; @LumberJack; @mazdafreak; @atvfreek; |
@Etipp98; @HOCKEYNUBE; where the fuck you pussies at? :) |
Quote:
add me to quick st blease |
Quote:
Maybe by someone else lol. I'm not runnin that car before I sell it. |
Creating a Results page with posting formats as this kicked off yesterday! |
I'll get in for stock appearing turbo class Stock Turbo Class @xfeejayx; @PurplFox; @nindoja; Stock Appearing Turbo Class @WetzMS3; @JgamB; @snailD; Quick Street Class @Micha; @Justin@Freektune; @LumberJack; @mazdafreak; @atvfreek; |
Can said video be from in cab camera. as likely to not have someone for filming |
Quote:
Sent from my Nexus 5 using Tapatalk |
Makes since, Makes me wonder what a basic bolt on speed should run. time for google |
quite the spread, anything from craptastic 14's to mid 12's. going to feel weird doing it in a car. |
If I can make it to a track with the speed this season I'll post it up. There is a track only about 40ish minutes from me who does multiple test n tunes a month. I'll shoot for it :) |
Quote:
@LumberJack; Can i be added to stock appearing please |
If it would stop raining, long enough. I might get a pass or two in. Texas is getting soaked. |
| All times are GMT -7. The time now is 06:51 AM. |
