| Website Help/Feedback If you have problems or suggestions for the forum, post here. |
![]() Join Date: Jul 2016 Location: South Florida
Rep Power: 0 ![]() Thanks: 0
__________________ 2013 genpu, CST4 Turbo, JBR 3.5 aluminum intake, cs hpfp, cs injector seals, cs small battery box, JBR 3-port ebcs, TR8L with CXracing piping, JBR pmm, Cobb rmm, Damond tmm, GFB BOV, 3 inch catless downpipe Last edited by GenpuMike; 01-31-2020 at 05:12 PM. |
__________________ 2013 genpu, CST4 Turbo, JBR 3.5 aluminum intake, cs hpfp, cs injector seals, cs small battery box, JBR 3-port ebcs, TR8L with CXracing piping, JBR pmm, Cobb rmm, Damond tmm, GFB BOV, 3 inch catless downpipe | |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score I'm not sure what's wrong. You can't make more boost above the spring pressure without any wastegate duty.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Vansquish (01-31-2020) |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| What @tegxsi; said. ^^^
If you're having trouble hitting boost targets on some other map, then you might have a problem. But, from the log you posted, on the map you're running, your car is doing precisely what it is supposed to do.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
(Thread Starter) | Not Ranked : 0 score Thanks guys, I think i found the problem. I recently checked my 3 port ebcs and found that a couple of the wires going into it have disconnected. New one is on the way, Ill keep both of you updated!
![]() Join Date: Jul 2019 Location: Central NJ
Rep Power: 10 ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score My CST4 is en route, will keep an eye on this thread in case your issue is turbo related |
| Snow maf/boost controller boost Line question | speed3gen1 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 1 | 10-29-2012 07:29 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Smooth Boost or boost jump. What is causing this, I am baffled. | FreeFlyFreak | Cobb ATR Support | 9 | 10-31-2009 01:38 PM |
| ideally whats the best boost targets for custom tune from full boost to redline? | Wenis Prinkle | Cobb ATR Support | 26 | 08-24-2009 06:36 PM |
