Go Back   Mazdaspeed Forums > MSF News And Event Info > Site News & Events > Hot Deals Section
Hot Deals Section Share your hot deals from around the web here!!
 Old 05-29-2015, 01:59 PM   #1
aviator79's Avatar
Posts: 3,934   (View Stats)
Default Cool Living 18,000 BTU Home Window Mount AC Unit | 900 Sq Ft (220v) 10.7 EER $290 Air Conditioner
I know nothing about this AC but I am not seeing another 18000 btu AC for only $290
NOTE 220V!
Cool Living 18,000 BTU Home Window Mount AC Unit | 900 Sq Ft : CL-WAC18 : VMInnovations.com
One cool feature is you can use set it to use the thermostat on the remote.
I bought this unit and will be installing this weekend hopefully.
Purchased outlet on amazon:
P&S White Industrial Single Outlet Receptacle NEMA 6-15R 15A 250V 5651-W Boxed - Electrical Outlets - Amazon.comP&S White Industrial Single Outlet Receptacle NEMA 6-15R 15A 250V 5651-W Boxed - Electrical Outlets - Amazon.com
DISCRIPTION:
This Cool Living Air Conditioner is designed to be installed in a standard double-hung window with a window width of between 28" and 41". It boasts a thermostat range of 64 - 86 degrees Fahrenheit (cooling only), and a programmable timer that allows you to set the run time anywhere from 0.5 to 24 hours. Included with the unit, is an LCD remote control that has a signal range up to 20 feet.
This 18,000 BTU window mount Cool Living Air Conditioner is one of the most versatile on the market. It features 7 different modes, 3 fan speeds, and a multi-directional vent. It's small and compact, yet powerful and efficient, and is energy star rated. When it comes time to clean the filter, just pull down on the indents of the filter door on the front of the unit. Included instructions make it simple to install.
•7 Modes - Cooling, Energy Saver, Fan Only, Dry (dehumidifier), Auto, Sleep, & iFeel
•Eco-friendly R-410A refrigerant
•Requires a 208/230v outlet
FEATURES:
NOTE: This item has a NEMA 6-15P plug that requires a 208-240V outlet to operate, it will not fit the standard 120V household outlet.
•Brand New 18,000 BTU Window Mount Cool Living Air Conditioner | CL-WAC18 •Cools a room up to 900 sq ft
•Designed to be installed in a standard double-hung window with a window width of between 28" and 41"
•LCD Remote Control has a signal range up to 20 feet
•Thermostat range of 64 - 86 degrees Fahrenheit (cooling only)
•Programmable Timer runs anywhere from 0.5-24 hrs
•7 Modes •Cooling Mode - use at low, medium or high
•Energy Saver Mode - the fan will cycle on and off with the compressor, this results in wider variations of room temperature and humidity. Normally used when room is unoccupied
•Fan Only Mode - use at high, medium, or low to provide air circulation without the cooling effect
•Dry (Dehumidifier) Mode
•Auto - the unit chooses between AC, Dehumidifier, and fan mode based on the current room temperature
•Sleep Mode - automatically reduces the set temp 2 degrees F after one hour, and 4 degrees after 2 hours that provides energy savings while you're sleeping
•iFeel Mode - changes the thermostat sensor from the AC unit to the location of the remote; the unit will set the AC's room temperature according to the temperature reading of the room the remote is located in
•3 Fan Speeds (high, med, & low)
•Easy access to the filter - just pull down on the indents of the filter door on the front of the unit
•Loss of Power Protection - if power to the AC is lost or interrupted, the AC will automatically restart to the setting last used
•Compact Size
•Extra Long 3-Prong Power Cord
•Multi-Directional Vent - Use the lever on the front of the air vents to adjust the direction of the air flow (left & right, up & down)
•Energy Star Rated
•Included: •Non-Hardware: •Window Air Conditioner
•LCD Remote Control
•(2) AAA Batteries
•Top Mounting Rail
•Foam Top Mounting Rail Seal Strip
•(2) Accordian Panels
•(2) Side Retainers
•Window Sash Seal
•Foam Seal for Bottom Rail
•Owner's Manual
•Hardware: •(2) Safety Locks
•(4) 1/2" Long Screws w/ Locknuts
•(2) 3/4" Long Flat Head Bolts w/ Locknuts
•(2) Sill Angle Brackets
•(10) Long Hex-Head Locking Screwsw for Top Angle, Side Retainer (5/16" Long)
•(2) 7/8" Round-Head Screws
•(4) 3/4" Round-Head Screws
•Specifications: •Power Supply (Ph/V/Hz): 1/230-208/60
•Rated Cooling Capacity (BTU/h): 18,000
•Cooling Power Input (Watts): 1,700
•Rated Current Cooling (Amperage): 8.8
•Cooling EER: 10.7
•Noise Level H/M/L [dB(A)]: 58/56/54
•Air Flow H/M/L (CFM): 470/430/390
•Dehumidifying Capacity: 132 Pints per day
•Product Dimensions (W" x H" x D"): 23.625 x 17.75 x 25.5
•Net/Gross Weight (lbs): 113/125
•Refrigerant Type: R-410A
•Plug Type: NEMA 6-15P
•Color: White
•Product Condition: Brand New
•Part Number: CL-WAC18
•1 Year Manufacturer Warranty
How Uplifting: Tokyo home elevates Lamborghini Countach right into living room Haltech Automotive News 0 04-01-2010 05:30 PM
Mobile Home: Motive presents a guide to in-car living Haltech Automotive News 0 09-04-2008 08:20 AM
Page generated in 0.26304 seconds with 20 queries
