Go Back   Mazdaspeed Forums > MSF News And Event Info > Site News & Events > Hot Deals Section
Hot Deals Section Share your hot deals from around the web here!!
 Old 10-12-2015, 02:16 PM   #1
aackthpt's Avatar
Posts: 1,450   (View Stats)
Default Rhino Ramps $31 @Walmart store pickup
12,000 lb GVW Rhino Ramps for $31. I have these and they are badass and huge.
RhinoRamps (up to 12,000lb GVW) - Slickdeals.net
2013 'speed3, silver
Stage Bro
The Following 5 Users Say Thank You to aackthpt For This Useful Post:
maisonvi (10-12-2015), MS3Shadow (10-12-2015), nekret (10-12-2015), snailD (10-12-2015), superman (10-12-2015)
 Old 10-12-2015, 04:21 PM   #2
nekret's Avatar
Posts: 421   (View Stats)
Can you drive up these without scraping the front?
Drivetrain
Chassis
Rice
 Old 10-12-2015, 06:44 PM   #3
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
I have those! I use them all of the time for oil change. Pretty beefed up and I had no problem. But it'll scrape if you're lowered but it all depends on the angle of the driveway or roads you're using it on
TAPPPPPin
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
 Old 10-12-2015, 06:53 PM   #4
nekret's Avatar
I have a set of ramps (not these) but can't use them since they hit the front bumper before the wheels hit the ramp. On stock suspension too! Sounds like I'm headed to get some replacement ramps.
Drivetrain
Chassis
Rice
 Old 10-12-2015, 06:58 PM   #5
I have the same problem. i just put some 2x4 in front and I was able to get onto the ramps just fine.
sent from my Nexus 6P
aviator79 (10-19-2015), daafisch (10-13-2015)
 Old 10-12-2015, 07:02 PM   #6
nekret's Avatar
I did the 2x4 thing for a while but stopped when it was wet and the 2x4 slipped out. Currently I'm using a pair of 2x6 boards glued and screwed together and chamfered to make a multi-stage ramp. So far so good on these but it would be nice to have something a bit higher so I don't have to bust out the jack stands for oil changes.
Drivetrain
Chassis
Rice
 Old 10-13-2015, 12:04 PM   #7
aackthpt's Avatar
Rhino Ramp board mod:
Stage Bro
 Old 10-19-2015, 08:56 AM   #8
aviator79's Avatar
Posts: 3,934   (View Stats)
2x4s in front of ramp is all I need, not on the ramp where they will slip off. I have no problem doing oil changes under these...only reason I bought them really was to do oil changes.
 Old 11-02-2015, 01:59 PM   #9
aackthpt's Avatar
Nearly the same deal currently available at Advance Auto Parts:
RhinoGear RhinoRamps Vehicle Ramps (12,000-lb capacity) - Slickdeals.net
Stage Bro
Ball Regular-Mouth Quart Mason Jars w/ Lids and Bands (Set of 12) $8 + Free Store Pickup aviator79 Hot Deals Section 3 03-30-2014 03:09 PM
Rhino lined roof ms3 I Love Brownies Appearance - SILVER 123 03-05-2014 04:20 PM
10-piece Craftsman Evolv Deep Impact Socket Set (Standard or Metric) $15 + Free Store Pickup aviator79 Hot Deals Section 4 01-12-2014 07:04 PM
$5 Off $20 In-Store Coupon Walgreens at Online Store Haltech Hot Deals Section 0 04-11-2008 07:11 AM
Page generated in 0.29152 seconds with 24 queries
