| Hot Deals Section Share your hot deals from around the web here!! |
![]() Join Date: Jan 2014 Location: Tampa Florida Area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
(Thread Starter) | Not Ranked : 0 score Rebate http://g-ecx.images-amazon.com/image...296408113_.pdf If you use the Subscribe and save (15% off) its $16.29 - $5 = $11.29 Just cancel the subscription after you receive the oil. Otherwise its $14.16 today if you don't want to wait for the subscription. Still beats going into Walmart any day |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Not Ranked : 0 score Prime members only... Cheapest non–Prime option per gallon looks to be $37.44 –– which isn't a good deal. |
| Awesome deal. You could get a free trial of Prime if you want. sent from my Nexus 6P
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score Looks to me like you must do the prime thing to get this, not seeing shipping cost either aside from that Rotella T6 5W40 Motor Oil, 2.5 gal - Walmart.com this will be about 57 after taxes to your door and just right for a BSD car
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
Groans: 211
Or maybe I did something wrong but I use my brothers prime account now.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| I started a free trial halfway through the month and still haven't got charged. You might have did something wrong. sent from my Nexus 6P
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Thor Hammer (04-27-2016) |
| Not Ranked : 0 score Thought i'd point out that this year's Rotella coupon is slightly different than it's been in past years. In the past there's typically been a limit of two coupons per household/person with a max savings of $10 (although the checks they sent me were for $12.50). The coupon this year can be used 4 times per household and states it's good for "$5 per Gallon" Also, this rebate lasts until the end of the year. ![]() ![]() So if i'm understanding this correctly, you could potentially purchase x4 2.5 gallon jugs and receive a savings of $50. @btstarcher; Need to stock up? |
| The Following User Says Thank You to frothy For This Useful Post: | btstarcher (04-27-2016) |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
| Not Ranked : 0 score Thanks my brother! Always need more oil, 6 quarts/month.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following User Says Thank You to btstarcher For This Useful Post: | frothy (04-27-2016) |
| Rotella T6 Rebate Going! | Jap11g | Mazdaspeed3/6 General Discussion | 2 | 03-26-2014 06:51 PM |
| Rotella T6 rebate | Crizomatic | Mazdaspeed3/6 General Discussion | 17 | 05-03-2013 10:40 AM |
| 1 Gallon of Rotella T6 for $8.99 after rebate | therza2169 | Gen2 MS3 General Discussion | 3 | 05-03-2013 08:53 AM |
| Shell Rotella T6 | needforspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 12 | 06-25-2011 09:34 AM |
