  • 1 Post By Ayaritz
 Old 10-12-2012, 12:01 PM   #1
Ayaritz's Avatar
Posts: 586   (View Stats)
Ayaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the world
Lightbulb ATR Table Spreadsheet
Well, I was a bit bored yesterday at work and decided to come up with a spreadsheet that had all of the ATR tables in it.
If you are anything like me, you like to be able to compare things side by side.
Anyone can easily copy and paste there current table into an empty excel sheet for comparison reasons, I just decided to take that one step further and make everything a little more organized.
The sheets are protected, so the only thing you can modify is the table data itself (like ATR).
Hopefully this is helpful to some people.
Let me know your thoughts, or if you would like me to change/ add anything.
Oh, and a side note; the current data in the tables right now is just the OTS map Stage2+SUR2+TIH 93.
ASHMS3 likes this.
Ayaritz is offline   Reply With Quote
The Following 16 Users Say Thank You to Ayaritz For This Useful Post:
ABSpeed3 (10-23-2012), allo80 (04-24-2013), ASHMS3 (10-12-2012), batmsp3 (02-11-2016), BigjohnB20 (10-12-2012), jdeves (10-12-2012), Micha (01-07-2015), ms6mil (10-12-2012), Pointless (11-06-2012), qkrthnu2 (10-26-2015), Snip (05-07-2014), someguyondrugs (07-30-2013), speedms6 (10-12-2012), svd (10-04-2013), udntknw (02-17-2013), Xploder08 (10-12-2012)
 Old 10-12-2012, 12:35 PM   #2
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
That's pretty cool man, thanks for doing that.
The Following User Says Thank You to ASHMS3 For This Useful Post:
Ayaritz (10-12-2012)
 Old 10-12-2012, 12:41 PM   #3
Ayaritz's Avatar
No problem!
I also thought it would be nice to be able to print off all your different revision maps.
Just another way to trouble shoot I guess!
 Old 06-12-2014, 01:04 PM   #4
Snip's Avatar
Posts: 329   (View Stats)
@Ayaritz;
Very handy if one wants to make a clear and good hard copy from their software map.
I just have a couple of things that need attention, to make it perfect again, i think over time COBB implemented a couple tables to ATR, that need to be added to your sheet:
- Closed Loop - Max load E
- Fuel OL/Part Throttle Commanded EQ (Unused)
- Engine Volumetric Efficiency (VE) - VVT Comp (BETA)
- Load Target Comp - High RPM (BETA)
- Load Target Comp - Injector Base Offset (BETA)
And i found one grammar nazi note:
- WG Duty Baro Error Comp (Fine)(Boost Based) needs to be WG Duty Boost Error Comp(Fine)(Boost Based)
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
MAF Tuning Spreadsheet badams118 MazdaSpeed 3/6 - ECU Computer Tuning 4 01-23-2010 04:41 AM
Wastegate IAT table AFcadet
Cobb ATR Support
18 01-16-2010 07:51 AM
MAF Table B for radiator fan on? Erich
Cobb ATR Support
2 06-02-2009 12:15 PM
Do we know when the ECU uses each table? FreeFlyFreak
Cobb ATR Support
17 05-07-2009 01:54 PM
Dashhawk data in a spreadsheet? Zeya MazdaSpeed 3/6 - ECU Computer Tuning 0 12-17-2008 09:24 PM
Page generated in 0.25517 seconds with 23 queries
