 Old 12-04-2011, 01:54 AM   #1
Karmat's Avatar
Posts: 1,179   (View Stats)
Default Boost Tune Woes
Decided to try the new boost tune OTS maps and so far they are pretty terrible. Debating on going back to the v107 load tune or tweaking this to work.
Getting a lot more random knock while cruising and partial throttle situations.
Getting high partial throttle/WOT cut outs which from my untrained eye look like possible boost cuts at WOT.
It is quite cold outside ~32F so these maps may be struggling.
If the tuning gods could take a look and chime in with some suggestions I would greatly appreciate that.
2 4th gear WOT runs tonight with ambient temps around 32F:
2002 Corvette Z06 (Black)
 Old 12-05-2011, 10:36 AM   #2
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Without looking at your logs I would say this is the same thing I had. I had to reduce my wgdc table. Someone who diagnosed my problem should be able to help you.
Sent from my HTC Droid Incredible using Tapatalk
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
 Old 12-05-2011, 12:33 PM   #3
Karmat's Avatar
That's what I figured. How much do I need to reduce WGDC by? When it's cold I assume I have to have higher values but the temps around here vary from 60 during the day to low 30s at night. I assume its possible to find some sort of balance in this cold weather.
Also can someone chime in on the knock which is a lot more prevalent in the 2nd log. Got as much as 3 degrees on the second run. Will getting the boost closer to target levels help eliminate all this knock that i get?
 Old 12-05-2011, 12:51 PM   #4
You need an adjustment to both timing and a little trim with boost but that's not too bad.
Karmat (12-05-2011), rfinkle2 (12-05-2011)
 Old 12-05-2011, 01:20 PM   #5
Karmat,
You are getting large amounts of wgdc hacked from your table by the wgdc load error comp table.
You can either raise your trl - x gear tables to about .1 above logged calculated load per rpm, or decrease the authority of the wgdc load error comp table.
Karmat (12-05-2011)
 Old 12-05-2011, 01:21 PM   #6
And just to answer your questions - judging by the KR values, your gas quality is poorer than what that map is set for. So you will likely have to lower timing on the map to deal with it or run a better gas/E85 since it is probably too high across the board. Send me a note if you're looking for a tune.
 Old 12-05-2011, 01:22 PM   #7
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Groans: 62
I had the same issues with those maps, decided to just tweak a v107 map. I'm also a dumbass at tuning.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
 Old 12-05-2011, 01:24 PM   #8
I would take Lex's suggestions, given you do have some pretty substantial knock in the second log.
Before tuning boost any further, it would definitely be a good idea to back out some timing.
 Old 12-05-2011, 01:41 PM   #9
Karmat's Avatar
I'm going to flash back the v107 map for now while I finish up the semester and finals. I will have some time during winter break to play around with the v200 maps. v107 didn't give me any problems although the car feels to pull a lot harder with the v200.
Thanks for the input guys.
The Following 2 Users Say Thank You to Karmat For This Useful Post:
Don06speed6 (12-05-2011), rfinkle2 (12-05-2011)
 Old 12-15-2011, 01:31 PM   #10
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
^^ same boat here.
I have a v108 map that ive been running for over a year. Recently got my firmware updated, loaded the v200 map. butt dyno recorded a substantial improvement, but got some random knock
i couldnt replicate the knock on either load or RPM ranges, so im thinking its just shitty seals or something, but it was there a lot so, I went back to 1.08 maps since I had some track events coming up.... but im currently spending some time on the v200 maps, and im excited to figure the knock out of it.
super_pablo_ is offline   Reply With Quote
The Following User Says Thank You to super_pablo_ For This Useful Post:
rfinkle2 (12-15-2011)
 Old 12-15-2011, 01:42 PM   #11
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
IMO the OTS V2xx maps still need a lot of tweaking to get right. In my own experience, they seem to be somewhat unpredictable. Part of the problem I've seen with those maps is the huge ramp on the overboost side of the BEC table.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
The Following 2 Users Say Thank You to SRTie4k For This Useful Post:
Boost_creep (12-15-2011), rfinkle2 (12-16-2011)
 Old 12-15-2011, 02:41 PM   #12
^^ what do u mean?
My BEC tables had higher correction values on previous maps... maybe i tweeked em? i dont fucking remember lol... last map i revised was over a year ago (other than the one im currently working on)
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
is it possible to tune over 22psi of boost with johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 2 09-11-2009 01:55 PM
Cobb ATR Support
26 08-24-2009 06:36 PM
Page generated in 0.32943 seconds with 27 queries
