 Old 11-17-2008, 02:14 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default COBB 3" Stainless Steel Downpipe for MazdaSpeed3 Now Available
COBB 3” Downpipe for MazdaSpeed3
Intelligent engineering, exceptional craftsmanship and premium materials go into this extraordinary piece
COBB Tuning announces the immediate availability of the COBB 3” Downpipe for the 2007-2008 MazdaSpeed 3,which is a study in engineering design and artistic execution. The COBB 3” Downpipe replaces a very restrictive element in the Mazdaspeed3 exhaust system. Considerable effort was spent designing a flow path with the fewest number of direction changes and minimal degrees of bend in order to eliminate restrictions. This beautifully fabricated downpipe delivers significantly improved exhaust flow, resulting in faster turbo response time and power gains across the entire rev range, while still protecting the environment with its highly efficient custom catalytic converter.
The engineering that went into the COBB 3” Downpipe started with the CAD designed investment-cast turbine outlet, made of 304 stainless steel for enduring corrosion resistance and reduced heat transfer to the engine bay. The shape of the outlet flange makes optimal use of the tight confines of the MS3's engine bay, smoothly blending turbine outlet and wastegate gases. The outlet flange is configured with two O2 sensor bungs; one to accommodate the stock O2 sensor and another with a pre-installed plug that can be removed to allow an aftermarket wideband O2 sensor or datalogging device with easy engine bay access.
A custom spun metal substrate high flow catalytic converter comes next. This one piece 400 grade stainless steel cat has a much higher flow rate and longer lifespan compared to ceramic or “brick” style cats. It also reaches operating temperature faster than other style cats for cleaner cold-start emissions. A third O2 sensor bung is located immediately after the cat to be used by the second OEM O2 sensor.
The stainless steel flex section used in the COBB 3“ Downpipe is internally lined (unlike most flex sections) and provides smoother exhaust flow and much longer lifespan for the steel braiding. The placement of this flex section in the factory location (before the first exhaust hangers) is critical in absorbing engine movement and eliminating damaging stresses that would otherwise be applied to the flange, cat, exhaust hangers and chassis. This increases the longevity of the downpipe as well as downstream exhaust components.
All tubing used in the fabrication of this downpipe is polished 304 stainless steel for increased corrosion resistance and a mirror-like finish. The 304 stainless steel hangers are cross-welded and well braced to eliminate a point of fatigue that is evident in other aftermarket downpipe designs.
The end flange uses the stock donut gasket and factory spring bolts to aid in flex, longevity and proper fitment. This provides an improved seal compared to other methods, as well as reduced noise. An additional benefit is that it makes the COBB 3” Downpipe compatible with any cat-back exhaust that mates to the factory cat section.
When researching downpipes for your MazdaSpeed3, consider COBB's intensive engineering, quality of materials, impeccable fabrication and all around versatility. The COBB 3” Downpipe is unmatched in the marketplace!
COBB 3” Downpipe for MazdaSpeed3 Features:
• Increased horsepower and torque
• CAD designed cast turbo outlet for maximum flow
• Minimal bends for less restriction
• 304 stainless steel throughout for corrosion resistance
• Custom spun metal substrate high flow cat
• Internally lined stainless steel flex section
• Three O2 bungs for factory sensors plus aftermarket
• Cross-welded and braced hanger section for added strength
• Polished tubing and cat for attractive finish
• Factory location of flex section eliminates stresses
• Stock donut gasket for optimal sealing and long life
• Compatible with all cat back exhaust that mate to factory downpipe
MAZDASPEED EXPERT GROUP
- ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE
 Old 11-17-2008, 04:02 PM   #2
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
question this downpipe deletes the second cat, right? No need for testpipe?
booya620 is offline   Reply With Quote
 Old 11-17-2008, 04:04 PM   #3
Correct, both cat sections are replaced with one piece. It mates to the cat-back.
The Following User Says Thank You to Cobb Tuning For This Useful Post:
booya620 (11-17-2008)
 Old 11-17-2008, 07:12 PM   #4
SpyNaldo's Avatar
Posts: 21   (View Stats)
SpyNaldo is an unknown quantity at this point
Do you have a Non Catted?
SpyNaldo is offline   Reply With Quote
 Old 11-17-2008, 07:21 PM   #5
peruspeed3's Avatar
Posts: 326   (View Stats)
peruspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud of
can sumone dyno test the pipe, it would be awsome
peruspeed3 is offline   Reply With Quote
 Old 11-17-2008, 07:41 PM   #6
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
nice piece Josh......this will put quite a few smiles on Speed3 owners as they torch the highway. The downpipe bolt-on has been my favorite mod so far, and this one looks great. Glad to see you finally made it to market.
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline   Reply With Quote
 Old 11-17-2008, 07:35 PM   #7
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
Again.... Typo:
"Compatible with all cat back exhaust that mate to factory downpipe"
should read - "Compatible with all cat back exhaust that mate to the factory midpipe."
For example: The vibrant CBE wouldn't be compatible with this downpipe, but it bolts to the factory downpipe.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 11-18-2008, 07:41 AM   #8
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
Originally Posted by mrlilguy157 View Post
Again.... Typo:
I don't think that is technically a typo. People think of the downpipe as just the short piece that attaches to the turbo, however in many applications (mainly the WRX/STi) the term downpipe implies the everything between the turbo and the catback. Technically on a subaru the downpipe is two pipes like on the MS3, but 90% of the aftermarket downpipes have integrated them into a single, long pipe--developing the term downpipe to imply both the downpipe and cat or race pipe. Since Cobb's specialty of sorts is the WRX/STi its only natural that they would use these terms on newer applications as well.
So in Cobbspeak:
Downpipe: The pipe or pipes between turbo and catback
Midpipe: pipe between downpipe and axleback, typically contains resonator if any
Axleback: pipe that contains muffler and exhaust tip
Catback Exhaust: Midpipe+Axleback
Turboback Exhaust: Downpipe+ Catback
I don't think that Cobb should need to change their product description because Vibrant falsely advertises their exhaust system as a 'catback exhaust', when technically is it not since it deletes a factory cat.
ElBartoRex is offline   Reply With Quote
The Following User Says Thank You to ElBartoRex For This Useful Post:
FCmaniac (11-20-2008)
 Old 11-18-2008, 02:45 AM   #9
Only catted. It outflows turbos up to around 450 h.p. so it is not a restriction.
Solar Powered Stainless Steel Lawn & Garden Lights (two pack) $14.95 Haltech Hot Deals Section 0 03-30-2008 07:41 AM
Kenmore 720-0549 Stainless Steel 4-Burner Gas Grill (770 sq in Cooking Area, 61000 BTU) $254.99 Haltech Hot Deals Section 0 03-28-2008 01:50 PM
Page generated in 0.30652 seconds with 26 queries
