 Old 03-06-2011, 09:13 AM   #1
SPEEDRAC3R's Avatar
Posts: 399   (View Stats)
SPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the world
Default Colder Plugs
Just looking for input on when you need to switch out to colder plugs like the IVT22's or equiv.
Just installed my CorkSport SRI/TIP yesterday and will probably be installing the AccessPORT during the week. Do I need colder plugs with so few mods?
2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint
SPEEDRAC3R is offline   Reply With Quote
 Old 03-09-2011, 09:05 PM   #2
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
I have yet to be fully convinced that colder plugs actually do anything. I have yet to get them and don't plan on getting them until I see hard proof that they help. Most install posts I have seen end up having problems rather than benefits.
Please, somebody help OP and prove me wrong.
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
 Old 03-10-2011, 01:04 AM   #3
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
heat range of plugs does not affect horsepower. colder = less likely detonation/preignition, too cold = misfire, stumbling etc.
 Old 03-10-2011, 01:55 AM   #4
niterydr's Avatar
Posts: 298   (View Stats)
niterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond reputeniterydr has a reputation beyond repute
A buddy of mine is running 1 step colder plugs (IVT-22's) with Cobb SRI/TIP and the OTS Stage1+sf w/ an AP.
I helped him install them and he has been running great with no problems for around 30-40,000 miles.
2013 Mustang GT - California Special
niterydr is offline   Reply With Quote
The Following User Says Thank You to niterydr For This Useful Post:
wette460 (03-24-2011)
 Old 03-10-2011, 05:15 AM   #5
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
Wrong you are my little asian friend. Spark blow out is going to affect power. This becomes an issue once you start throwing more air and fuel at our motors.
Amazon is offline   Reply With Quote
The Following 3 Users Say Thank You to Amazon For This Useful Post:
djuosnteisn (03-10-2011), socks (03-10-2011), wette460 (03-24-2011)
 Old 03-10-2011, 06:54 AM   #6
RacerX78's Avatar
Posts: 818   (View Stats)
RacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the world
Groaned at 6 Times in 4 Posts
If you start adding boost and improving intake your going to increase heat in the cylinder. Step colder will allow the plug to properly deal with the heat, reducing the chances of plug melting and knock. I've had a TMIC, SRI & CBE and had step colder plugs in since 3K miles and had no issues with running them.
That true but as long as you properly gap your plugs you'll be ok.
RacerX78 is offline   Reply With Quote
 Old 03-10-2011, 08:44 AM   #7
skiptowncat's Avatar
Posts: 1,592   (View Stats)
I had all sorts of hesitation and cuts as soon as I got an intake, it carried on when I got my HT and only stopped when I fitted itv22's.
 Old 03-10-2011, 09:21 AM   #8
2zz mr-s
dooderek's Avatar
Groans: 239
my venezuelan counterpart, i guess i worded it incorrectly or maybe i am perciving it wrong, blow out/misfire/stumbling etc to me is the engine unable to mechanically deliver the power it needs. if a engine can run at a heat range of 8, running 7 or lower will only decrease the chances of said detonation/pre ignition and of course too low like i stated above misfire etc etc. in no way does spark plugs increase hp is wat i mean or decease horsepower, just allows the engine to perform at peak efficency
 Old 03-10-2011, 09:23 AM   #9
Amazon's Avatar
Groans: 214
Properly gapping isn't going to help if your plugs have too hot of a spark for your application.
Once again my asian philippino, if your sparks aren't igniting the fuel/air mixture due to blow out, then the engine will suffer power loss, albeit a slight amount. I have some logs of stock plugs vs cooler plugs if ya would like to see the difference plugs can make.
 Old 03-10-2011, 09:24 AM   #10
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I can attest to this. Running mid 13's (granted horrible 60') at 1000 ft elevation while flowing more air than my previous 12.6 at 5500 ft elevation.
Blowout can seriously seriously hamper the "power" of a car lol.
You could actually see the blow out in my logs, with stair stepper rpm curve lol. It was some funny shit.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 03-10-2011, 09:31 AM   #11
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
So what plugs are you guys running? The Denso or a colder NGK?
ak_spray is offline   Reply With Quote
 Old 03-10-2011, 09:35 AM   #12
Amazon's Avatar
Groans: 214
One of the guys had issues trying to get the NGK's to gap since they come pre gapped too wide. Most of us tend to go with Denso.
The Following User Says Thank You to Amazon For This Useful Post:
ak_spray (03-10-2011)
 Old 03-10-2011, 09:45 AM   #13
2zz mr-s
dooderek's Avatar
Groans: 239
well my muchacho the efficeny of the engine affects how it performs and how much power it can put to the ground, im not arguing with you there, and yes obv if your spark is blowing out then ignition isnt happening meaning no power agreed, the point i was trying to make is that, if an engine is operating at peak efficeny, switching heat ranges on a plug aslong as there is no misfire/detonation etc etc, horsepower will not change. the point of proper heat ranged plugs is to have the "correct" temp for ignition without misfire/detonation etc. make sense or am i speaking gook again?
 Old 03-10-2011, 10:00 AM   #14
SPEEDRAC3R's Avatar
Car had been running awesome with just the intake for 250 plus miles, so I installed the AP on Tuesday. Started out running Stage1 + SF 91 Octane 1.08 map and noticed I got a lot of partial throttle surging, along with a very digital (on/off) throttle pedal.
Switched to the Stage1 91 Octane map and it was worse at first, but after 50 or so miles the problem has become much less prevalent, but it still seems to be there. Logged a 4th gear pull which seems pretty good albeit maybe a little lean (see attached).
Guessing that some of my problems are the uncalibrated MAF, but have also heard people with similar issues on the stock plugs. Seems that as soon as they jump over to the ITV22s, their surging and touchy throttle problems go away.
 Old 03-10-2011, 04:11 PM   #15
MattJackson86's Avatar
Posts: 1,407   (View Stats)
So whats the cure for blowout? Smaller gap? Do the heat range have any effect?
MattJackson86 is offline   Reply With Quote
The Following User Says Thank You to MattJackson86 For This Useful Post:
 Old 03-10-2011, 04:23 PM   #16
scriccs's Avatar
Posts: 263   (View Stats)
scriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the worldscriccs is the leader of the world
Groans: 50
When do you think it makes sense to go a step colder? I will be installing my TIG and and test pipe soon. Do you think it makes sense with my setup?
08.5 CWP MS3 GT
Cobb SRI & TIP | Jbarone SSP & Bushings | SURE RMM | CS Racepipe | ASA AR1 w/ Conti DW 235/40/R18
scriccs is offline   Reply With Quote
 Old 03-10-2011, 04:45 PM   #17
Captain
Haven't had a chance to figure it out. Fucked my motor up being a meth head before i got a chance.
I dunno if heat range has an influence on spark. I want to say it shouldn't but who knows. I say run the warmest plug you can as long as your not having detonation issues. I plan on running 1 step colder plugs, and gapped tighter if necessary.
AFRs play a huge role as well. As does nozzle size if you spray water / meth injection. Everything seems to contribute.
I would say after a couple bolt ons, and a tune, it's smart to go 1 step. But i wouldn't go any colder unless you have to.
www.permtuning.com
MattJackson86 (03-10-2011), wette460 (03-24-2011)
 Old 03-10-2011, 05:21 PM   #18
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
I've always wanted to ask if ambient temps affect what range plugs to run. I have mods in sig and am just starting to get into ATR to turn up the boost a little bit. But I live where in the winter my car will sometimes have to sit outside for 9 hours at -10F while I am at work. Then I need it to be able to start and run till it warms up which takes quite a while at those temps. Will the colder plugs not run as well in the cold weather?
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
 Old 03-10-2011, 05:25 PM   #19
Captain
I have no clue lol. I haven't played with different heat ranges that much. But at one heat range colder, i don't think you'd see any appreciable difference from stock.
www.permtuning.com
 Old 03-10-2011, 06:30 PM   #20
RacerX78's Avatar
Step colder plugs will be just fine in that weather. They don't affect how long it takes your engine to warm up. They they are just built to handle more heat than stock heat range which happens when you turn up the boost.
From Denso IR Power FAQ Site
Q. Why are there different heat ranges? Which one should I use?
A. Part of your spark plug’s responsibilities, in addition to firing a spark, is to remove heat from the combustion chamber. This is accomplished by channeling the heat through the insulator material and metal housing. From there, the heat is transferred to the cylinder head where the engine cooling system can go to work. A spark plug’s heat range is its ability to dissipate heat. The “colder” the plug, the more heat it can channel out of the combustion chamber. In a performance application, colder heat ranges may be necessary to handle the extreme temperatures brought on by higher compression ratios, forced induction, and high RPM’s. While “Colder” plugs may seem to be the way to go, please remember that the spark plug must achieve its “self-cleaning” temperature where it can burn off fuel and carbon deposits. Otherwise, the plug could “foul out” where it is prone to misfiring and poor acceleration. A plug that is too “hot” can overheat, also causing power loss, detonation, pre-ignition, and possible engine damage. A good, general rule of thumb is to start with the factory recommended heat range. For every 75 to 100 hp you add to your engine, you may go to the next colder step. DENSO heat ranges move up as they get colder; 16 would be our hottest Iridium Power plug, 34 would be our coldest (ranges; 16,20,22,24,27,31,34)
The Following 4 Users Say Thank You to RacerX78 For This Useful Post:
djuosnteisn (03-11-2011), EwMPS (03-18-2011), scriccs (03-10-2011), wette460 (03-24-2011)
 Old 03-10-2011, 06:38 PM   #21
Davy180's Avatar
Posts: 256   (View Stats)
Davy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the worldDavy180 is the leader of the world
Very helpful info, thanks
Davy180 is offline   Reply With Quote
 Old 03-10-2011, 06:42 PM   #22
scriccs's Avatar
Groans: 50
Agreed but I still have no clue what I'm going to do. I figure new stocks are better than mine with 30k on them.
08.5 CWP MS3 GT
 Old 03-10-2011, 07:07 PM   #23
Thanks. This thread came at a good time as I have been getting blowout for a couple weeks now. Not all the time, but when I do I too get the "stair stepper" RPM curve
Ill try tightening the plugs. I am running 2 step colder now gapped at .027 and was going to stick with the same, not sure if I should only go 1 step colder though. I have had no issues with 2 step overall though.
 Old 03-10-2011, 07:13 PM   #24
RacerX78's Avatar
Something basic rule with plugs are go one step colder for every 75-100Hp you add over stock power. If your doing just a TIG with your SRI and TP you'll be fine with new stock heat range plugs.
 Old 03-10-2011, 07:25 PM   #25
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
IMO, two steps colder is not necessary at the power levels you can achieve with the K04..
I'm running two steps colder with my gt35 but I run at least 21psi daily, and do not have meth injection. If I hadn't spent $27 each on these HKS plugs I'd probably have switched back to one step colder plugs, because I don't think two steps is even necessary where I'm at currently...and they run like shit until the car is completely warmed up.
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (03-11-2011), MattJackson86 (03-10-2011), wette460 (03-24-2011)
 Old 03-10-2011, 07:37 PM   #26
myt_tuf1's Avatar
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
Can step colder plugs with just a SRI, TIP, TMIC, and RP cause any backfiring/afterfiring between a 2-3 shift? I just switched mine to step colder Denso's in anticipation for my AP install (I haven't installed the AP yet) and I seem to be getting a little backfire in-between my 2-3 shift...
(I also did some work with my BPV, I installed a spring rated for 20-25psi instead of the 10-20psi spring that was initially in it...)
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
 Old 03-10-2011, 07:39 PM   #27
Groans: 60
plugs no
BPV possibly
It's always a good idea to change one part at a time, it makes trouble shooting the issues much easier.
The Following User Says Thank You to SSinstaller For This Useful Post:
myt_tuf1 (03-10-2011)
 Old 03-10-2011, 07:39 PM   #28
RacerX78's Avatar
I've got a SRI, TMIC and CBE and i get backfire when i shift at WOT every now and then. I don't get it during my DD.
 Old 03-12-2011, 06:10 AM   #29
2zz mr-s
dooderek's Avatar
Groans: 239
um, when you detonate after having the improper heat range, youll be convinced. but i doubt you will be pushing your car to that limit anyway. wtf is that runescape link?
 Old 03-12-2011, 06:13 AM   #30
Amazon's Avatar
Groans: 214
He's basically soliciting. Cut that shit out. And Runescape is gay.
 Old 03-12-2011, 06:23 AM   #31
Originally Posted by yuanyelss View Post
I'm not completely convinced that the cold plug has done anything. I do not have them, do not let them in the plan, until I see hard proof that they help...
Buy RS Gold,Runescape Gold
RS Gold,Buy Runescape Gold
I save my groans for the most appropriate occasions. Groan button pushed.
bcmountainspeed (03-12-2011)
 Old 03-17-2011, 06:15 PM   #32
What gap would you suggest? Stick with .027 and just try new 1 step colder plugs, or go smaller to say .025?
 Old 03-17-2011, 07:56 PM   #33
SPEEDRAC3R's Avatar
I just installed the plugs right from the box. They come pre gapped, so I didn't mess with them.
 Old 03-17-2011, 09:37 PM   #34
See that has caused issues for me (and others) in the past. I know our suggested gap is between .024-.032. I have found I have to run a closed gap or I have issues and out of the box they are not pre-gapped correctly.
 Old 03-18-2011, 06:36 AM   #35
The recommened gap for itv22's is .024-.027 if you are running a COBB AP.
I know you were questioning exactly what gap to run, and I haven't heard anyone from the low (.024) to high range (.027) say they had an issue.
FWIW, Denso suggests that iridium plugs are much less sensitive to gapping issues due to their efficiency.
Chriscote (01-30-2012)
 Old 03-18-2011, 06:55 AM   #36
Amazon's Avatar
Groans: 214
I sense faggotry in this thread
 Old 03-18-2011, 07:23 AM   #37
darth vader's Avatar
Posts: 665   (View Stats)
darth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the world
Groaned at 9 Times in 9 Posts
Heat range and blowout have nothing to do with one another. Blowout is caused by high cylinder pressure and weak spark induced by that, or too large gap settings.
The heat range is merely the survival range of the plug in a situation of INCREASED CYLINDER PRESSURE (read: EXTRA HEAT) and, a measure of the plugs ability to clean itself off of unburned HCs at startup and cooler weather. A colder plug will more effectively transfer that extra heat to the cylinder head and thus the cooling system, rather than retaining it in the plug body, widening gaps, distorting tips, causing pre-ignition or worst case, melting altogether.
A too-cold plug WILL decrease power SLIGHTLY over a proper range for the conditions it's in. It's safer to err on the side of caution but, you really have to READ the plug that's in the motor to determine if going colder is necessary.
I went over the line at near full bolt and only barely so, I think you're safe, unless you're booting around in Venus-level ambient temps. I do get some fouling issues at startup in freezing temps.
darth vader is offline   Reply With Quote
 Old 03-18-2011, 07:39 AM   #38
Without disputing your technical knowledge, some of the ots gen2 maps were just above the knock threshold that Cobb is comfortable with (OTS anyway), and the 1 step colder plugs cleared the kr issue up.
Cold starting wasn't a problem in these few cases, but very well may be a problem if your current setup is not exhibiting any problems now.
I guess the moral of the story may be... if it ain't broke...
 Old 03-18-2011, 08:41 AM   #39
SPEEDRAC3R's Avatar
Faggotry asside, what are you using to gap your plugs?
I'm coming from naturally aspirated V8's with carburetors where the plugs were not made with precious metal. All I have is a set of feeler gauges, and from what I know about gapping precious metal plugs, contacting the electrode is a no no. I guess I could have brought the plugs into work and used the vision system to measure them, but that seems a little excessive.
Right from the Denso website:
Q. Do I need to set the gap?
A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip.
Q. How do I gap Iridium plugs
A. Before attempting to gap any DENSO Iridium Power spark plug, please review the specification chart to see the factory-preset gap. In most cases your Iridium Power plugs do not need to be gapped. Even with small variations in the factory set gap the ultra-efficient firing power design will compensate for those small variations. Should you decide to re-gap your Iridium Power plug, use extreme caution as improper gapping may damage or destroy the Iridium center electrode or porcelain center. To increase the gap size: Step 1 Use needle nose pliers or spark plug gapping tool to bend the ground strap up to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN. Step 2 Re-check the gap with a calibrated gapping tool. To decrease the gap size: Step 1 Use the same method as above, however bend the ground strap down to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN. Step 2 Re-check the gap with a calibrated gapping tool. WARNING: Failure to follow these directions may permanently damage the spark plug. Note: Never use a round gapping tool to check the gap or to increase or decrease the gap setting.
http://www.globaldenso.com/en/produc...ium/qa_22.html
 Old 03-18-2011, 08:48 AM   #40
SpeedRac3R... You'll need a "feeler" gauge available @ any local auto parts store.
When you get it, keep in mind that you may have to use 2 "feelers" @ once to equal the gap u want.
eg... although may not be the actual feeler numbers .025+.002=.027
Just be weary of touching the actual irridium, and use a good pair of needle nose pliers to open the gap, and tap the plug on top to close it. There are a few vidoes... on sites other than denso. Try ngk's site....
Do I need step colder plugs? drenkel 2010 MS3 - Engine, Transmission & Driveline 1 07-13-2010 01:43 PM
Should I go with colder plugs AllLostThings MazdaSpeed 3 - Engine, Transmission & Driveline 10 05-28-2010 11:16 AM
colder plugs? triple_threat MazdaSpeed 3/6 - ECU Computer Tuning 12 12-19-2009 11:07 AM
KR and Colder Plugs Qluber MazdaSpeed 3 - Engine, Transmission & Driveline 21 03-20-2009 08:26 AM
1step colder or 2 step colder plugs, need to decide which plugs before tune day(by CHURCH) johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 12-13-2008 04:17 PM
Page generated in 0.59214 seconds with 36 queries
