 Old 03-18-2014, 04:45 PM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Default Connecting to goddamn R4 software/AIC unit
I've tried 3 different fucking serial/usb connectors now. 2 of them instantly freeze R4 when trying to connect to the AIC1 unit. The 3rd, a sabrent, doesn't instantly freeze when trying to connect, but brings up dozens of instantly-pops-up "error #9 " messages before R4 freezes and shuts down.
This is on a windows 8 laptop. I've tried "compatibility" settings, etc. I'm getting ridiculously frustrated trying to connect to this motherfucking AIC.
WHO STILL FUCKING USES SERIAL PORT TECHNOLOGY IN 2014.
07 MS3
The original Genpoo Hater
MarineMazda (03-30-2014)
 Old 03-19-2014, 06:32 AM   #2
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I think I figured it out: Windows 8 BLOWS GOAT NUTS.
Managed to get R4 on an old netbook I have (WinXP), and connected right to the split second.
Fuck windows 8. I'm fixin to buy Win7 to put on that new laptop.
07 MS3
 Old 03-19-2014, 06:38 AM   #3
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Groans: 70
2 of our 3 products still do (I know, its stupid).
If anyone needs a USB to Serial adapter, use the IOGear branded one. The biggest problems with these adapters are the drivers, IOGear seems to be the only one who has drivers all the OS versions.
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
 Old 03-19-2014, 08:14 AM   #4
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I tried FTDI drivers, cuz most of these products are made by the same manufacturer and just rebadged. I had to search Amazon to find ones that actually look different, too.
07 MS3
 Old 03-22-2014, 12:59 AM   #5
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Yeah.
Windows 8 can suck it lol
www.tunedbynishan.com
 Old 03-30-2014, 07:57 AM   #6
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
@gingermike
I am having this same issue right now with Windows Vista. I tried using R4 on my MAC with XP in Parallels and I can't even open Customers on that without getting error msgs.... I thought it was MAC fail so i tried with my Work IBM which runs XP as well and get the same errors.
I am with you who the FUCK uses Serial connectors anymore!!! I have an email in to SS right now....
Can you confirm this works with Windows 7?
MarineMazda is offline   Reply With Quote
 Old 03-30-2014, 04:24 PM   #7
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I had to finally use an old netbook I have with XP on it to get it working. I know it's finicky regarding the serial/usb connectors that it works with. Would be optimal to find an old lappy with a serial port on it.
07 MS3
 Old 03-30-2014, 05:02 PM   #8
Most aftermarket standalones and ECUs are archaic this way. For our Megasquirt builds we use an adapter that I've tested to be compatible across all Windows versions.
 Old 03-30-2014, 05:23 PM   #9
Surprisingly I got it to work on Windows 8.... It must not like Vista....
 Old 04-17-2014, 09:40 PM   #10
wdautrem's Avatar
Posts: 159   (View Stats)
wdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the world
I work in industrial controls where there is still a lot of (picky) serial stuff around. I've been using a Tripp-Lite branded usb to serial adapter on my Win 7 laptop with good results. I'll see if I can find what the model number is.
wdautrem is offline   Reply With Quote
 Old 04-30-2014, 03:33 PM   #11
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
I tried two cables and three computers before I could connect. pita
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Chimmike (04-30-2014)
 Old 05-13-2014, 08:46 PM   #12
wdautrem's Avatar
Yeah, the one I have is a Tripplite USA-19HS. So far it's worked with every oddball device I've tried to connect to.
dashhawk software interfering with other software? builthatch Mazdaspeed3/6 General Discussion 3 07-09-2012 06:26 AM
Standback Tuning Software, Drivers, and Logging Software www.cp-e.com Custom Performance Engineering (cp-e.com) 24 04-24-2011 11:49 AM
ap connecting mouse6933 MazdaSpeed 3/6 - ECU Computer Tuning 10 02-18-2010 07:31 PM
AP not connecting Tomas
Cobb ATR Support
7 08-04-2009 10:31 AM
Page generated in 0.31238 seconds with 26 queries
