Like Tree12Likes
 Old 01-10-2019, 06:01 PM   #41
Altenius's Avatar
Posts: 67   (View Stats)
Altenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond reputeAltenius has a reputation beyond repute
The release of LibreTuner is coming up, but I need more ECU ROMs to analyze. Currently, I have only added support for one speed6 firmware version.
I'm looking for both speed6 and speed3 ROMs. If you would like to help and you have a J2534 PassThru cable, you can use the current alpha release of LibreTuner to download ROMs and save them to a file.
It can be downloaded by following the download link on the website and selecting the LibreTuner-v0.0.4-Windows.zip download. Unzip the archive and run LibreTuner.exe. If your PassThru cable was detected, it should show up under datalinks. If not, please let me know. There is only one option for the platform: Mazdaspeed6. This option will work for speed6s AND first gen speed3s. If you have a genpu, try it too but I'm not sure how similar the firmware is to the first generation.
When you're done with setup go to File > Download ROM, type a name, and make sure the PassThru cable is connected to the computer and OBD-II port. Turn the key to ON and continue. It should start downloading. If not, let me know what the error is. When it's completed, a new window will show up saying the firmware version is unsupported. Press "Yes", save the ROM somewhere, and send it to me. If you don't get that windows and it says "successfully downloaded" instead, you have the one firmware version supported and I don't need the ROM.
The download instructions can also be found in the manual.
Thanks!
Altenius is offline   Reply With Quote
The Following 3 Users Say Thank You to Altenius For This Useful Post:
mituc (01-11-2019), Realgib3 (01-11-2019), Vansquish (01-10-2019)
 Old 01-11-2019, 05:39 AM   #42
Dommo14's Avatar
Posts: 694   (View Stats)
Dommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the world
subbed
I'm stock bro.
Dommo14 is offline   Reply With Quote
 Old 01-11-2019, 08:18 AM   #43
Realgib3's Avatar
Posts: 2,443   (View Stats)
We'll get some downloaded. I thought I had some rom files on my laptop still, but it looks like I just have the hex files from when I was looking at everything in IDA. Of course I don't even have a Mazda anymore, but I do have a cable, so I'll meet up with someone and get something downloaded.
Altenius (01-11-2019)
 Old 01-11-2019, 10:19 AM   #44
Altenius's Avatar
Does the hex file include the entire ROM? If you were analyzing it with IDA it probably does and in that case I can use it. '.hex' isn't a standard format and it could just be part of the ROM so I might be wrong.
Access Ports will not be supported.
 Old 01-11-2019, 11:16 AM   #45
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I can provide the ROM images as collected by Versatuner for a 3MPS BK (Mazdaspeed3 gen1 EURO spec) and a CX7 2008 manual transmission (EURO spec as well, the 260bhp version).
I can also get you a 6MPS EURO spec image, also acquired by Versatuner.
I don't know how VT encodes them so please met me know if they're usable for you in any way. Or if you don't know I can just send them to try them out.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-14-2019, 01:33 PM   #46
nindoja's Avatar
Posts: 2,395   (View Stats)
I can pull the firmware from my MS6 and MS3 (both with VersaTune installed) to pull those down if it would help. Where should I send them to?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 01-14-2019, 01:54 PM   #47
Altenius's Avatar
That'd be super helpful. You can PM them to me on here or email them to support@libretuner.org.
Also, if you have an issue with your PassThru cable not showing up let me know. Mine stopped showing up a few days ago for whatever reason and I patched it but haven't made a release with it yet.
[edit] v0.0.4 should fix that issue.
nindoja likes this.
 Old 01-15-2019, 08:46 AM   #48
rbarnz's Avatar
Posts: 10   (View Stats)
rbarnz is an unknown quantity at this point
Subbed because this is cool. I have an AP on gen 2 so not sure how much help I can be.
--2013 MS3-- 17x9 RPF1; CS Full 3.5" Intake; Autotech Internals; Grimspeed 3 Port; JBR SSP+CW; JBR Shifter Bushings; SP63 Breather; JBR OCC; DM OCC VTA; DM PCV Plate; DM Trilogy; ATP Turbo DP+RP (Catless); UR Catback w/ Cobb Hangers; JBR EGR Delete; JBR Hood Vent Insert; SSQV VTA; TR8 w/ JBR Under Route; CS HPSS Fuel Line; CS Adjustable Short Shifter; CS Interior Kit; CS IM & 72mm TB; DO DVC 30 w/ single D14 (50/50); CS Battery Box (ECU Relocate); CS Gauges (Triple A Pillar); BNRS4v3; Cobb IWG Bracket; CPE Exhaust Manifold; Tial MV-R 44mm Screamer; 3 Bar MAP; Cobb AP; STuned on E30
rbarnz is offline   Reply With Quote
 Old 01-15-2019, 09:01 AM   #49
Altenius's Avatar
I'm not familiar with AP so it's hard to say. If it's like VersaTune in the case where it cannot be reflashed by another software until it is "unmarried", then it won't work.
 Old 01-15-2019, 02:25 PM   #50
Quazz236's Avatar
Posts: 16   (View Stats)
Quazz236 will become famous soon enough
If you're ever planing to add Genpu support I'll be more then happy to download and send some ROMs for you, or w/e else that might help. Sadly at the moment that's all I can offer since I don't have a MS6 or 1st gen. I really like the idea though so hopefully you'll keep at it, and possibly if it takes off expand to genpu also. Either way good luck. I'm definitely going to keep an eye on this.
Quazz236 is offline   Reply With Quote
 Old 01-15-2019, 04:16 PM   #51
Altenius's Avatar
I definitely want to add genpu support. You should be able to download it by selecting Mazdaspeed6; the download protocol is the same afaik.
To anyone with a CX-7: I've gone through a CX-7 ROM and it looks like it uses the same method as well.
The Following User Says Thank You to Altenius For This Useful Post:
mituc (01-16-2019)
 Old 01-15-2019, 05:34 PM   #52
Quazz236's Avatar
Cool. I'll give it a try sometime next week. Won't have aces to a Passthru cable till Monday.
 Old 08-29-2019, 11:53 PM   #53
magnaddl's Avatar
Posts: 2   (View Stats)
magnaddl will become famous soon enough
I have a 2008 Gen1 Mazdaspeed 3 that I can pull codes on for you. I'd be happy to. I've been monitoring several FOSS projects for a while now, waiting for an Open Source ECU/Tuning software solution, so finally stumbling on this is awesome. I have an AP tuner, but I've been moving everything toward Open Source and this, is like my Holy Grail.
Anyway, I noticed you mentioned a Windows binary for grabbing or sending you the tune, but I don't run Windows on anything anymore. Not until I setup my virtualization server, but with what I have on my plate right now, I don't see that happening anytime soon. Is there perhaps a Linux binary or is this part of the source now where once compiled, I can now do what's needed from the software off of Github. I don't have the cable you mention, but I'd be willing to buy it to help, as long as this is still in active development. If the price is too high, I'm good with making my own cable. I do that sort of thing all of the time. I hope you haven't given up. This is looking so promising.
magnaddl is offline   Reply With Quote
 Old 08-30-2019, 12:02 AM   #54
magnaddl's Avatar
Altenius likes this.
The Following User Says Thank You to magnaddl For This Useful Post:
Altenius (08-30-2019)
 Old 08-30-2019, 08:22 PM   #55
Altenius's Avatar
It should build on Linux but I haven't tested it in a few weeks -- I'll try it and work out the bugs tomorrow. As for the cable, you're choices right now are SocketCAN and ELM327. I've used an OBDLink-SX as well as a CANable (open-source by the way) with success. The CANable doesn't include an OBD-II adapter so something like this is needed, and if you decide to get the CANable flash it with the candlelight firmware.
How you can be part of an open-source Le Mans racer Haltech Automotive News 0 03-12-2014 07:40 AM
Open source tune? Speedster07 2010 MS3 - ECU Computer Tuning 17 02-04-2013 06:43 PM
Open Source Tuning for my car TWOptSL0W MazdaSpeed 3/6 - ECU Computer Tuning 4 12-05-2012 07:47 PM
BMW wants to help develop open-source in-vehicle platform Haltech Automotive News 0 10-24-2008 04:10 PM
Google Android open-source OS could come to cars Haltech Automotive News 0 09-25-2008 06:40 AM
Page generated in 0.38258 seconds with 28 queries
