| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() | | #1481 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #1482 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
| Not Ranked : 0 score You shouldn't even need a MAF cal with 2 gallons. I didn't.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
![]() | | #1483 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score FWIW - I have been running 3 gallons for a long time, and didn't need to adjust my MAF until they switched to E70, and there was just a tiny spot around 4.9v that needed adjusted. |
![]() | | #1484 | ![]() |
(Thread Starter) | Not Ranked : 0 score depending on how accurate your petrol MAF cal is you shouldn't need to change it for 2-2.5 gallons. you will want to add some timing to get the full benefit though.
![]() | | #1485 | ![]() |
just tickling the tip of the curve huh?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #1486 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
| Not Ranked : 0 score So closest E85 to me is 25 miles away. Seems E85 is in short supply around here
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
![]() | | #1487 | ![]() |
Groans: 386
![]() | | #1488 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score I drive 18 miles for mine. Just buy a bunch of 5 gallon gas cans and a single 2 gallon can so you can measure correctly. I do it this way and have about 2 months worth of E85 before I have to go back, works great so far.
__________________ www.MOTOIQ.com Beater Titan |
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | MattJackson86 (12-09-2011), rfinkle2 (12-09-2011) |
![]() | | #1489 | ![]() |
Groans: 50
| Not Ranked : 0 score Did you check out propelfuels.com?
![]() | | #1490 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score I am about 20 miles from the corn pump as well and I couldn't be happier, it's worth the drive. I use a bathroom scale to measure the fuel. 20lbs of the juice and 9 gal of 93. I couldn't find any 3 gallon containers. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | rfinkle2 (12-09-2011) |
![]() | | #1491 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score I have one at the end of my road. I could freakin throw a stone there. Why am I not using it??
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
![]() | | #1492 | ![]() |
(Thread Starter) | Not Ranked : 0 score b/c your boost control is all fucked up...that's why....you need a good tuner....I know of a couple...DJ, Lex, Socks....any one of them could help you out.
| The Following User Says Thank You to Dano For This Useful Post: | rfinkle2 (12-09-2011) |
![]() | | #1493 | ![]() |
| Not Ranked : 0 score I know of a great tuner named Dano, but he is just having a bit of trouble with the comp tables on some cars (as we all are). |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Dano (12-09-2011) |
![]() | | #1494 | ![]() |
Coughloadtunecough
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning | |
| The Following User Says Thank You to Boost_creep For This Useful Post: | Dano (12-09-2011) |
![]() | | #1495 | ![]() |
all kidding aside I don't think load tuning will work either...I've sent your BCS test logs to David and we'll see what he thinks but to me it looks like your BCS is laggy at best and can't reach targets at worst. for everyone else we completely neutered the comp tables to test if the BCS would just follow commanded values and to me it failed but I don't know how closely logged DC should match commanded. Here were the commanded DC values from 2500: Code: 40.00 45.00 40.00 45.00 45.00 50.00 60.00 65.00 70.00 70.00 logs attached. edit: imma gonna cut a load map this weekend and have boost_creep give it a try.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following User Says Thank You to Dano For This Useful Post: | Boost_creep (12-09-2011) |
![]() | | #1496 | ![]() |
| Not Ranked : 0 score Wgdc like a stegosaurus is the new coolest thing. You guys are all jealous. Who's everyone else? Lol.
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning Last edited by Boost_creep; 12-16-2011 at 10:32 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Boost_creep For This Useful Post: | rfinkle2 (12-10-2011) |
![]() | | #1497 | ![]() |
(Thread Starter) | Not Ranked : 0 score just guys reading the thread wondering WTF I am talking about.
| The Following 4 Users Say Thank You to Dano For This Useful Post: | Boosted Beluga (12-09-2011), Boost_creep (12-09-2011), btstarcher (04-02-2012), rfinkle2 (12-10-2011) |
![]() | | #1498 | ![]() |
![]() Join Date: May 2008 Location: New orleans, la
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
| Not Ranked : 0 score I think my car is doing something similar to boost creeps. Boost is on target but strays off somewhere near 5k and the ecu does not seem to do anything to correct it. Pure boost tune only BEC active. I also have a lean condition during and sometimes after spool in rare cases that can hold close to 5k rpms. I think a bit lean on spool is common on this car? I have no idea why it sometimes holds for the majority of the run and I am out of ideas on how to fix this. Most logs run about .2 or .3 high during initial spool but hit their target right after. This log shows both. intake/tip/dp/fuelpump - sealevel and its 50 degrees outside. 18 psi boost target and 11.1 afr target. |
![]() | | #1499 | ![]() |
| Not Ranked : 0 score Im gonna go try and get some E85 shortly and test it out. If it sells me on it then I will work something out on how to store it. Would 100octane race gas be comparable to E85 performance wise? Cost wise its WAY more I know.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | rfinkle2 (12-14-2011) |
![]() | | #1500 | ![]() |
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 12-13-2011 at 10:26 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Dano For This Useful Post: | MattJackson86 (12-13-2011) |
![]() | | #1501 | ![]() |
I haven't heard back from David so I cut a load based tune and sent it over to @Boost_creep and as I suspected, the same issue was there. Plus, his WGDC actually dropped into the single digits during the middle of a WOT run. This proves to me we have some underlying issue since the ECU is dropping DC like that. We are gonna remove the AP and see what DC looks like on an OE tune via DH and go from there. so the bottom line, his issues are not directly related to any boost targeting logic and his car just wants to be difficult
![]() | | #1502 | ![]() |
Whether it be the ots comp values, the grimmspeed, or the combo of the 2, something is crushing the wgdc table down to nothing when load values are being approached (sometimes) or exceeded. (in a way you'd expect a protective table to act vs. a compensation table) | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Boost_creep (12-14-2011), Dano (12-14-2011) |
![]() | | #1503 | ![]() |
TRL from 2.5K 2.00 2.30 2.30 2.25 2.15 2.10 2.00 1.75 1.55 1.50 logs attached. BTW his WGDC sometimes shoots up to 99 while in vacuum/cruise as well. And lets not forget the "shark fin" effect which I have never seen before. Edit: so you have seen DC cut this much when a target is exceeded?
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Boost_creep (12-14-2011), rfinkle2 (12-14-2011) |
![]() | | #1504 | ![]() |
| Not Ranked : 0 score Ive been thinking about this. When I log, I usually pull over to the side, cause I have bad connection issues. So I start a log, then pull out onto the highway and usually try to get to 4th pretty quick. Lol. If you look at the OTS wgdc table at anything over 25% TP and under 2250 rpm's, I am targeting 100% wgdc. Could this just be my ecu hitting the target, but then a compensation table knocks it down?
| The Following User Says Thank You to Boost_creep For This Useful Post: | Dano (12-14-2011) |
![]() | | #1505 | ![]() |
(Thread Starter) | Not Ranked : 0 score I suppose that is possible however I just looked back thru some of your logs and see 90 and 75DC @ 16TPS which doesn't approach higher TPS in any surrounding cells so its isn't a resolution issue....but do see quite a bit of 99 at over 20TPS. I forgot you had one of the APs that has trouble logging. is yours a v2b? [dongless] so lets chalk up the PT DC as BS and move on. the drop from 50 to 2 DC at WOT is unexplainable to me and couple that with issues with a BT tune and Load tune right at about the same RPM/DC of 5K/50+ I'd like to hear back from finkle and anyone else that has seen this happen. me your ECU
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Boost_creep (12-15-2011), djuosnteisn (12-15-2011) |
![]() | | #1506 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Boost_creep (12-15-2011) |
![]() | | #1507 | ![]() |
| Not Ranked : 0 score I think I was able to find 2 similar situations here: 1) speed6 not hitting boost targets 2) Boost Tune Woes |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #1508 | ![]() |
| Not Ranked : 0 score Afr was set low while I am working on my lean issue. I've seen 12.7 when targeting 11.1. I'd hate to see what a higher afr looks like... I can't say I notice any power increase going from low to high 11's. If there us one I doubt it's much. This car doesn't seem to make much power off running leaner. |
| The Following User Says Thank You to Meder For This Useful Post: | rfinkle2 (12-15-2011) |
![]() | | #1509 | ![]() |
| Not Ranked : 0 score I have the V2b dongless AP. I still feel a load table is getting in the way here. Or possibly a table yet to be discovered by Cobb.
![]() | | #1510 | ![]() |
| The Following User Says Thank You to Dano For This Useful Post: | rfinkle2 (12-15-2011) |
![]() | | #1511 | ![]() |
| Not Ranked : 0 score Been a while since this has been touched. Alas, I have documented this WGDC "issue" with several customers that is present in both boost and load based tunes. In the upper RPM the ECU just doesn't follow load or boost targets and drops WGDC. This will be worse in cold weather, E85 cars, BT cars. Stay tuned, I will do a write-up ... and then COBB will have to be doing some work I should say that I really like how we're getting more and more control of the ECU and COBB have been awesome and very responsive at catering to our requests.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 01-13-2012 at 12:55 PM. |
| The Following 8 Users Say Thank You to Lex For This Useful Post: | Boosted Beluga (01-13-2012), Boost_creep (01-14-2012), BrianB6 (01-15-2012), Dano (02-16-2012), Nataphen (01-18-2012), rfinkle2 (01-13-2012), SJP0tato (01-13-2012), wolly6973 (01-13-2012) |
![]() | | #1512 | ![]() |
![]() Join Date: Oct 2011 Location: Berrien Springs, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score subd |
![]() | | #1513 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Dano when you say you can force the tune to go for Boost Targeting instead of Load Targeting do you think this could be done with any tuning tool. e.g. Mazdaedit.? How would I put the load targets out of reach? Noob tune with Gen 2. Which Tables would take care of my Boost tune. Sorry if you have to repeat yourself but I was trying this out. Your thread is unreal and I am hopeing to be able to do a Boost Tune using my current software package on my gen 2. Look forward to your response. |
![]() | | #1514 | ![]() |
| Not Ranked : 0 score There are several ways to force a tune into boost targeting mainly but they revolve around the LEC (load error correction) tables. VersaTuner does not give you access to the coarse LEC tables - does MazdaEdit give you access to all the load error and boost error correction tables the AP does?
![]() | | #1515 | ![]() |
| Not Ranked : 0 score These are the parameters I have on MazdaEdit for LOAD. There is one for LOAD Correction with a ? on it. |
![]() | | #1516 | ![]() |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
![]() At the 5800-6200 wgdc just drops, this is on a boost tune, e85 + 3071.... Also, for some reason it puts your post back in 1970... uploadfromtaptalk1352936282055.jpg Sent from my Galaxy Nexus using Tapatalk 2
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP | |
![]() | | #1517 | ![]() |
Freekn tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | rfinkle2 (11-20-2012) |
![]() | | #1518 | ![]() |
Tappin Date stamp is b/c old thread is old Lol. Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 11-15-2012 at 12:37 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Dano For This Useful Post: | SarcasticOne (11-15-2012) |
![]() | | #1519 | ![]() |
![]() Join Date: Jan 2011 Location: Indianapolis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 232
I posted my map and a log in this thread: ATR 1.9.1.0-5046 is out with Load Tuning > 80% IDC resolution... I'd really appreciate any help you guys can give in solving this issue. @Lex @Dano @rfinkle2
__________________ 2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it) | ||
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/dano-s-boost-tuning-101-cool-stuff-68239/ | ||||
| COBB AccessPort | This thread | Refback | 10-15-2013 01:02 AM | |
| Versatuner on Gen 2 Experience | This thread | Pingback | 04-25-2013 04:19 PM | |
| horto's tuning/logs | This thread | Refback | 06-20-2011 08:28 AM | |
| Boost Based Tuning with ATR | This thread | Refback | 06-16-2011 08:29 PM | |
| Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | This thread | Refback | 04-12-2011 06:09 PM | |
| Boost Comp x Gear - 1st not working | This thread | Refback | 04-11-2011 10:52 AM | |
| ATR Required Load questions - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | This thread | Pingback | 02-24-2011 09:34 AM | |
| Initial Details into How The Boost Based Tuning Works with AccessTUNER | Christian. | MazdaSpeed 3/6 - ECU Computer Tuning | 108 | 01-12-2011 09:22 PM |
| WTF is going on with my boost?... tuning noob | Fatguy729 | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 12-24-2010 05:57 PM |
| Dano's SS Exmani install | Dano | MazdaSpeed 3 - How-To's | 18 | 11-12-2010 10:38 PM |
| Help tuning for Boost w/ New Perrin Pro EBCS... | dougefresh_ | Cobb ATR Support | 4 | 06-11-2010 11:43 AM |
| Boost Targets Table... Significance when Tuning Load/Gear | dougefresh_ | Cobb ATR Support | 18 | 05-19-2010 08:06 AM |
