 Old 07-15-2010, 06:35 PM   #1
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
Default Difference between Cobb stock map and Mazda stock map?
If you guys saw my other post, my AP died and had to be sent to Cobb for repairs. Much to my surprise, they deleted my stock map backup that was on the AccessPort.
I recently uninstalled the AccessPort and, of course, had to use the map that was provided with the AccessPort since my own stock map was gone.
My question is, what is the difference between the Cobb stock map that was flashed during the install and will my dealership be able to tell that I no longer have the Mazda stock map?
Hoping for some good news or Cobb will get a call from an angry customer!
Qtip is offline   Reply With Quote
 Old 07-15-2010, 09:38 PM   #2
lavoiespeed3's Avatar
Posts: 4   (View Stats)
lavoiespeed3 will become famous soon enoughlavoiespeed3 will become famous soon enough
This will void your warantie.. The dealer can't connect the OBD2 scan to the ECU with a AP MAP on it.. don't go to the dealer.. sorry
Call cobb they will take care of you .. like they did for me
Last edited by lavoiespeed3; 07-15-2010 at 09:38 PM. Reason: MSF Database - Automerged Doublepost
lavoiespeed3 is offline   Reply With Quote
 Old 07-15-2010, 09:43 PM   #3
speed23's Avatar
Posts: 1,480   (View Stats)
What he said
 Old 07-16-2010, 05:10 AM   #4
Qtip's Avatar
Ah shit. I'll give them a call. This will probably end up taking another two months of my life to get resolved.
 Old 07-16-2010, 10:58 AM   #5
Qtip's Avatar
I spoke with Cobb and they told me that even without the stock map backup, when you uninstall the AccessPort, it will put the ECU back to a stock Mazda map.
He said that the dealership will not be able to tell that the ECU was flashed or played around with.
Can anyone confirm? I don't want to find myself in a hard place if something does go wrong and I take the car in for repairs.
 Old 07-16-2010, 11:09 AM   #6
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
Confirmed
KayWhy is offline   Reply With Quote
The Following 2 Users Say Thank You to KayWhy For This Useful Post:
kgb (07-18-2010), Qtip (07-16-2010)
 Old 07-16-2010, 11:13 AM   #7
speed23's Avatar
I am pretty sure that you have a mazda map on your car if you unistall, but mazda could tell that it isnt the map that was on your car to start with if they really dug deep- otherwise why would cobb give you the option to save YOUR mazda tune to the accessport?
I am sure they wouldnt have any idea unless something really bad happend and they suspected a tune
The Following User Says Thank You to speed23 For This Useful Post:
Qtip (07-16-2010)
 Old 07-16-2010, 11:53 AM   #8
Lama's Avatar
Posts: 339   (View Stats)
Lama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond repute
Cobb uninstall stock map is a mazda map save from another car. Dealer won't notice !
Mazdaspeed 6 2007 GT : Cobb AccessPORT, Cobb Stage 2+SF TIH 91 BT map, Cobb SF SRI, Cobb Turbo Inlet, Cobb shifter weight, Cobb XLE BPV, Cp-e TMIC, SAMCO Xtraflex recirc hose, AutoEXE Boost tubes, CP-e Rear Motor Mount, Cp-e diff mount, SURE juggernaut, Magnaflow Catback , SU Test pipe, TWM Short Shifter Stage 2 & Bushings, DashHawk, Denso ITV-22, RPM sport springs, whiteline RSB, freins Rotora, TSW nurburgring wheels
Lama is offline   Reply With Quote
The Following User Says Thank You to Lama For This Useful Post:
Qtip (07-16-2010)
 Old 07-16-2010, 01:31 PM   #9
Qtip's Avatar
Thanks all, I will be able to sleep tonight.
 Old 07-20-2010, 02:11 PM   #10
Travis@Cobb
Lurkers
Travis@Cobb's Avatar
Posts: n/a
As was mentioned above, when you uninstall the AccessPORT, a Mazda OEM Rom is flashed back onto the ECU. This basically makes your car 100% stock again, at least from an ECU standpoint.That is, if you uninstall the AccessPORT, it returns your ECU to stock.
If you simply flash the stock map onto your car, all that means is you have a stock calibration, but the AccessPORT is still installed.
If you wish to uninstall the AccessPORT you must go through the complete uninstall process.
The Following 3 Users Say Thank You to For This Useful Post:
Docnox (07-20-2010), evidence (07-24-2010), Qtip (07-20-2010)
 Old 07-20-2010, 05:08 PM   #11
Qtip's Avatar
Thanks for clearing that up, glad to have you back on the forum.
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
Page generated in 0.31662 seconds with 24 queries
