Like Tree16Likes
 Old 12-01-2014, 08:53 PM   #1
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Default HOW TO - Switch to VersaTune
So I made the switch to VersaTune. While migrating my ATR tunes, into Versatune I documented what tables in ATR, translate to tables in VersaTune. Many translate directly into VersaTune others do not, and some tables in VersaTune do not exist in ATR.
The document is just the table translations. I hope to use this thread to talk about any little quirks that need to be observed when making the switch, and hopefully some good discussion on what exactly some tables do.
I hope this is helpful to the community. Maybe we can make it a sticky as more people make the switch. If anyone discovers something I missed or anything of that nature, please let me know and I will update it.
Thanks to @phate; there are some more goodies in the document
https://onedrive.live.com/redir?page...O5TeBCdLQ1fOUQ
@phate; @Lex; @rfinkle2; @Justin@Freektune; @Steve@VersaTune; and any other tuners I have forgotten.
Quirks to look out for
The big thing is to watch your Axis values and units of measure while doing this.
Also many tables Scale out to 8k so be sure to adjust the rows above 7k
Absolute Limits tables
Most of these tables are pretty straight forward. Just remember to watch your axis values
Accelerator Pedal Calibration
These all translate directly with the exception of "APP Multiplier Speed Adjustment" The Axis values do not line up
Boost Control
These all copied over nicely, just remember several of the tables in VersaTune scale out to 8k rpm. ATR only goes to 7k so make sure to adjust the 7500 and 8k columns
Fueling
One thing I noticed with these tables. The Closed Loop tables have lower loads listed than the OL tables. So if you copy your OL tables into the CL tables, you will notice the last couple rows did not get changed. Make sure to copy into the first load value that matches on the right, then adjust the first few rows accordingly.
Also the Y axis, which is load, does not share the same values as ATR, so when copying from ATR into VersaTune, be mindful. What I did was copy the rows that where close into VersaTune, then I vertically interpolated between the modified rows to adjust the unmodified rows.
VersaTune used Lambda, and does not use AFR so make sure to switch ATR into lambda
Also it seems ATR has Fuel Specific Gravity labeled wrong. ATR shows the unit of measure as kg/m^3 when it should be kg/l. Which is how versatune labels it.
there is also no injector scalier at the moment, so if migrating a E85 tune be aware of this
Gear Tables
These all translate almost exactly from ATR, they are not covered in the document for this reason
Idle
These also translate without any issue
Ignition
The big thing here is the Y axis which is Load does not line up with the Load axis in ATR. So I used the same method that I used in Fueling tables to get this translated over.
Load Targeting
The axis values in this tables line up between VersaTune, and ATR.
Be aware that VersaTune only does Load based tuning. This means that the values in these tables will need to be modified, if you do boost tuning in ATR, since the have likely been set to a number that your car can not achieve. Running these tables from ATR unmodified could = ZZB. You have been warned.
Sensor Calibration
Be sure to set VersaTune to use Metric units. then you can copy your MAF cal from ATR directly into VT.
It seems VersaTune has the same number of MAP related tables, but I could not figure out exactly how that correlated with the MAP tables in ATR
Throttle Control
These copy over without issue
Valve Timing
Damond Built Speed 6
The Following 37 Users Say Thank You to Deldran For This Useful Post:
802MS3 (12-02-2014), Axel907 (12-08-2014), Boost_creep (05-21-2016), chaser27 (12-03-2014), Code Monkey (12-01-2014), CWP_MS3 (12-03-2014), dsb_chicago (12-03-2014), Easter Bunny (12-03-2014), Enki (12-02-2014), f15ms6 (12-01-2014), fivefingerdeathpunch (12-02-2014), ItsNox (12-11-2014), JgamB (12-03-2014), Justin@Freektune (12-03-2014), kgb (12-03-2014), King Scumbag (12-03-2014), Koke382 (12-03-2014), Matt@DamondMotorsports (12-01-2014), Mauro_Penguin (12-02-2014), Mazdazilla6 (03-03-2016), meicalnissyen (10-10-2016), mituc (12-03-2014), mxlplx71 (12-02-2014), Nliiitend1 (12-02-2014), phate (12-01-2014), Polish_Eagle (12-03-2014), Raider (12-03-2014), rfinkle2 (12-02-2014), rtabagaboy (12-03-2014), SarcasticOne (12-01-2014), SparkySparks (12-09-2014), SpeedRebirth (12-06-2014), TiGraySpeed6 (12-02-2014), Tomas (12-02-2014), torquemaniac (08-02-2016), Voltwings (12-03-2014)
 Old 12-01-2014, 09:04 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Thanks for starting to sort these out, Andrew. Hopefully this eases some fears about making the move to VT from the AP - I know some folks are fed up with Cobb's lack of updates, but are apprehensive about making the switch.
I just purchased VT, so once the cable gets here I'll start working through and adding anything I find.
Rob@Hypnotictuning likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 15 Users Say Thank You to phate For This Useful Post:
802MS3 (12-02-2014), 865ms3 (12-01-2014), chaser27 (12-03-2014), CWP_MS3 (12-03-2014), Deldran (12-01-2014), dsb_chicago (12-03-2014), Easter Bunny (12-03-2014), fivefingerdeathpunch (12-02-2014), GrumpyMPS (12-03-2014), JgamB (12-03-2014), Nliiitend1 (12-02-2014), rfinkle2 (12-02-2014), Roddiy (12-10-2014), TiGraySpeed6 (12-02-2014)
 Old 12-01-2014, 09:08 PM   #3
Deldran's Avatar
Groans: 118
I forgot to mention. After one revision, because I had a couple of tables configured wrong, the car is running super smooth. It does feel a bit down on power, but I was pretty conservative with load targets.
TiGraySpeed6 likes this.
The Following 3 Users Say Thank You to Deldran For This Useful Post:
phate (12-01-2014), rfinkle2 (12-02-2014), TiGraySpeed6 (12-02-2014)
 Old 12-01-2014, 11:23 PM   #4
f15ms6's Avatar
Posts: 1,546   (View Stats)
f15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the world
Thanks again for sending me the link. I am sure it will be a huge help to get things started once I get VT.
@TiGraySpeed6 I am sure you will be interested on this as well.
2006 MS6 GT - Titanium Silver - #05750 -Cobb AP V2 - AT HPFP - 3" JBR Full Intake-
FidanzdaFlywheel - AWR Trilogy - Techna-Fit Brakes & Clutch SSL - Turbo XS Test Pipe - Maganaflow Catback
99 Civic Dx 5spd - DD/Backup Car
f15ms6 is offline   Reply With Quote
The Following 3 Users Say Thank You to f15ms6 For This Useful Post:
Deldran (12-02-2014), phate (12-01-2014), TiGraySpeed6 (12-02-2014)
 Old 12-02-2014, 05:29 PM   #5
Eth Fiend
phate's Avatar
Alright, I just finished setting up a base map. I went through all of the tables and made notes and additions to Andrew's document. I also found a couple interesting things
VT has 3 tables called "Closed Loop Load Limits"...they all happen to be set at 2.50 load over the entire rev range. There have been a couple threads posted about AFR "things" happening at 2.50 load here and here
VersaTune has a bunch of tables listed as "overload", but nothing in particular to determine when they are used (same as the Knock/No Knock tables that are labeled incorrectly in ATR). The "Closed Loop Load Limits" are described as being a sort of unknown, so I'm thinking they might be related.
@Lex, @ms6mil, @rfinkle2, @Justin@Freektune - you guys were in those threads and I'm not sure a resolution was ever reached. What say ye guys? We've suspected for a long time that there are multiple closed/open loop transition points for different parameters, this might be one that actually comes in handy.
-06 MS6
The Following 13 Users Say Thank You to phate For This Useful Post:
802MS3 (12-02-2014), 865ms3 (12-02-2014), chaser27 (12-03-2014), Deldran (12-02-2014), dsb_chicago (12-03-2014), Easter Bunny (12-03-2014), Enki (12-02-2014), f15ms6 (12-02-2014), Justin@Freektune (12-03-2014), Mauro_Penguin (12-03-2014), ms6mil (12-02-2014), TiGraySpeed6 (12-03-2014), torquemaniac (08-02-2016)
 Old 12-02-2014, 06:17 PM   #6
Justin@Freektune's Avatar
Posts: 954   (View Stats)
That could very well be where an issue lies. We never found a resolution other than putting more work into the maf cal. The maf literally has to be 100% spot on to hold target Afr above that achieved load of 2.5+
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 6 Users Say Thank You to Justin@Freektune For This Useful Post:
Deldran (12-02-2014), Easter Bunny (12-03-2014), Mauro_Penguin (12-03-2014), ms6mil (12-02-2014), phate (12-02-2014), torquemaniac (08-02-2016)
 Old 12-02-2014, 10:51 PM   #7
I contacted Steve about this issue and he replied that he had never come across that particular situation.
I am growing tired of having to basically tune a fuel curve 2x's but my hope that we will ever bend Cobb's ear is lost.
IMO, this type of project is far more important than being able to rev to 10000k rpm but
The Following 8 Users Say Thank You to rfinkle2 For This Useful Post:
802MS3 (12-03-2014), Deldran (12-03-2014), Easter Bunny (12-03-2014), Justin@Freektune (12-03-2014), Mauro_Penguin (12-03-2014), ms6mil (12-04-2014), phate (12-02-2014), torquemaniac (08-02-2016)
 Old 12-02-2014, 11:12 PM   #8
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
I push the Load Limit Force Spark Retard table way up in my tunes. That may be why I have never seen this.
I *think* the Overload tables are used for low octane tuning. I've seen CX-7 calibrations that have the Load Limit Force Spark Retard set to all zeros for certain regions. In those calibrations, the overload tables are different from the normal tables. Based on this, I suspect that exceeding the Load Limit Force Spark Retard may cause you to run off of the Overload tables.
Steve
Lead Tuner
The Following 7 Users Say Thank You to Steve@VersaTune For This Useful Post:
802MS3 (12-03-2014), chaser27 (12-03-2014), Deldran (12-03-2014), dsb_chicago (12-03-2014), Easter Bunny (12-03-2014), phate (12-02-2014), torquemaniac (08-02-2016)
 Old 12-02-2014, 11:28 PM   #9
If going through the exercise of familiarizing yourself with VT coming from COBB one of the things to do is to look at a stock tune for the same generation car. You can then see which tables match with which. This is what I did when the answer wasn't obvious and was porting tunes.
I personally also love to see logs in .csv. There is a .csv output function on the logs and you will see that the variables have lots of digits after the decimal that makes the log hard to read. If viewing in excel, select the entire sheet and click on the "comma" for comma style. This will limit the number of decimal places and make the log much easier to read.
The Following 10 Users Say Thank You to Lex For This Useful Post:
chaser27 (12-03-2014), Deldran (12-03-2014), Easter Bunny (12-03-2014), f15ms6 (12-03-2014), kgb (12-03-2014), Mauro_Penguin (12-03-2014), phate (12-02-2014), Polish_Eagle (12-02-2014), TiGraySpeed6 (12-03-2014), torquemaniac (08-02-2016)
 Old 12-03-2014, 06:14 AM   #10
Enki's discussion was moved here: Enki's Bluetooth VT Discussion
Deldran (12-03-2014), Mauro_Penguin (12-03-2014), phate (12-03-2014)
 Old 12-03-2014, 07:09 AM   #11
Deldran's Avatar
Groans: 118
Thanks @Raider;
Any chance we could make this a sticky?
 Old 12-03-2014, 07:21 AM   #12
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
VT has 3 tables called "Closed Loop Load Limits"...they all happen to be set at 2.50 load over the entire rev range....
I'm not sure we actually see any true OL with the AP unless we are over 2.5 load.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 4 Users Say Thank You to chaser27 For This Useful Post:
Deldran (12-03-2014), ms6mil (12-04-2014), phate (12-03-2014), TiGraySpeed6 (12-03-2014)
 Old 12-03-2014, 07:46 AM   #13
The ECU always trims fueling even under WOT. We just don't see the trims so you are correct.
chaser27 (12-03-2014), Deldran (12-03-2014), torquemaniac (08-02-2016)
 Old 12-03-2014, 08:17 AM   #14
torquemaniac's Avatar
Posts: 733   (View Stats)
I can confirm that if you exceed the Load Limit Force Spark Retard, you will run on the Overload tables
The 2nd gen CX-7 OEM tune has all zeros in the Load Limit Force Spark Retard (why?), and all attempts at altering the Normal Ignition tables did not work because of this
If you ask me, the OEM tuning can be fucking retard
2011 CX-7 AWD 2.3 turbo
The Following 3 Users Say Thank You to torquemaniac For This Useful Post:
chaser27 (12-03-2014), Deldran (12-03-2014), phate (12-03-2014)
 Old 12-03-2014, 08:28 AM   #15
Eth Fiend
phate's Avatar
Do you know if it's just the ignition tables, or all overload tables (specifically fueling) are used in this case?
-06 MS6
 Old 12-03-2014, 08:39 AM   #16
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
@Evan@COBB; You guys should be aware if you're customers aren't satisfied.
Perhaps people beginning to jump ship is enough to promote changes. Adapt to survive.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 10 Users Say Thank You to CWP_MS3 For This Useful Post:
Cheapspeed (12-03-2014), Easter Bunny (12-03-2014), JgamB (12-03-2014), Justin@Freektune (12-03-2014), kgb (12-03-2014), Mauro_Penguin (12-03-2014), Micha (12-03-2014), ms6mil (12-04-2014), phate (12-03-2014), Z32_MS3 (12-13-2014)
 Old 12-03-2014, 08:51 AM   #17
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Holy shit, do the fan control tables actually work for genwon? I've literally been dying to get this.
Deldran (12-03-2014), kgb (12-03-2014)
 Old 12-03-2014, 08:54 AM   #18
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Adapt to survive.
Not sure I'd push that too much at cobb....
They're adapting to Subaru, Ford, BMW, Porsche, Nissan...
All of whom are actively producing new cars for them to work with. Mazda isn't, at least not currently. I'd look for the resurgence when the new Speed3 is released.
I'd love to see some of the promised updates get released, but even the beta testing for the stutter fix has fallen off, and that's almost current activity.....
VT related content- that stutter fix is putting a check in a box. Cobb has some talented people, but come on, a checkbox, compared to cobb ignoring or not being able to correct an issue for years....
340hp / 371tq
The Following 8 Users Say Thank You to TiGraySpeed6 For This Useful Post:
chaser27 (12-03-2014), CWP_MS3 (12-03-2014), Deldran (12-03-2014), Easter Bunny (12-03-2014), f15ms6 (12-03-2014), fivefingerdeathpunch (12-03-2014), Micha (12-09-2014), SpeedRebirth (09-03-2015)
 Old 12-03-2014, 09:17 AM   #19
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I'm just speaking from a person who is in the automotive industry to sell a product as well, and thinks customer satisfaction is above all. I prefer to know what my customers think of us regardless of good or bad.
I'm just bringing it to their attention that people are leaving to another company; and I meant nothing more. Whether or not they give a shit, and do what they can to make the desired changes, is up to them.
We all appreciate the things they have done for our cars. I meant nothing negative. However, if we're progressing, it would be nice to have them progress with us.
Rich Tuned
330WHP and 363TQ
The Following 4 Users Say Thank You to CWP_MS3 For This Useful Post:
chaser27 (12-03-2014), Easter Bunny (12-03-2014), phate (12-03-2014), TiGraySpeed6 (12-03-2014)
 Old 12-03-2014, 09:17 AM   #20
Deldran's Avatar
Groans: 118
So I have ran into something that kinda boggles my mind.
I copied my MAF CAL tables straight out of ATR and into VT.
Good thing it is cold out because I saw upper 12's and even a 13 on a 4th gear woot pull.
everywhere I can see, I checked both OL and CL fueling tables. I should be l .7xx lamba range, I never got below .8xx lambda during my pull.
I have no issues doing a maf cal, all though I despise them, it just seems this is something that should copy over without issue.
 Old 12-03-2014, 09:24 AM   #21
chaser27's Avatar
Groans: 42
Are you converting from lambda back to AFR or vis versa? If so are you on an E mix? If so, stoich isn't going to be 14.7... Just an idea.
Again, assuming you are on an E mix. Did you use fuel scalars or just redid your MAF?
ECU: self-tuned
 Old 12-03-2014, 09:29 AM   #22
Eth Fiend
phate's Avatar
NNNOOOOOOOOO!!!!!!
Stoich IS 14.7:1 no matter the fuel mix for our cars. O2's read in lambda, then convert to an AFR scale of choice. In our case the scale is based on 1.00 lambda equal to 14.7:1.
-06 MS6
Enki (12-03-2014)
 Old 12-03-2014, 09:33 AM   #23
chaser27's Avatar
Groans: 42
NNNOOOOOOOOO!!!!!!
I was thinking backwards (and outloud)... O2 reads AFR, then converts back to lambda.
I'll shut up now
EDIT: Does VT (Or ATR for that matter) give us the option of changing that AFR scale it converts back to?
ECU: self-tuned
 Old 12-03-2014, 09:34 AM   #24
Eth Fiend
phate's Avatar
Another note that I've written about before and will write more on later: the scaling of maf curves for e85 is NOT a single multiplier. I developed maf scalar curves back in the day, before we had the very convenient injector controls. Why this is the case, I'm not sure. But, those scalar curves were consistently accurate in the cars I tuned using the maf scalar approach.
Edit: I'm interested to see if this holds true in VT.
-06 MS6
 Old 12-03-2014, 09:35 AM   #25
Enki's Avatar
To further elaborate, some cars actually convert the lambda AFR into a gasoline AFR before using the number. Fortunately, our cars do not.
 Old 12-03-2014, 09:37 AM   #26
Deldran's Avatar
Groans: 118
It seems VT defaults logging in AFR, instead of Lamda, so I convert the logged AFR into lambda by dividing it by 14.67 (AFR/14.67)
I am just trying to understand why it is so far off. I know the Cal was not that far off with the AP.
 Old 12-03-2014, 09:49 AM   #27
NNNOOOOOOOOO!!!!!!
Stoich is lambda 1.000 for all fuels.
Stoich AFR of 14.7 is only for gasoline. E85 is very different.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Deldran (12-03-2014), Lex (12-03-2014)
 Old 12-03-2014, 09:51 AM   #28
Eth Fiend
phate's Avatar
Understood. It's around 9:1 for E100, and somewhere in between for lesser ethanol content. My point was that 1.00 lambda will be converted to 14.7 in our cars no matter the fuel.
-06 MS6
 Old 12-03-2014, 09:54 AM   #29
I never work in AFR, so I forget about that conversion.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Deldran (12-03-2014), Justin@Freektune (12-03-2014), Micha (12-09-2014)
 Old 12-03-2014, 09:56 AM   #30
Enki's Avatar
The description for the MAP Targets (Boost Targeting Mode) says that the table isn't used, but I don't see a way to set boost targets/limits other than this table, which also happens to be set to 30 psi (or roughly stock boost if viewed as absolute pressure). Is this the proper table to use?
 Old 12-03-2014, 09:57 AM   #31
Eth Fiend
phate's Avatar
Lambda makes WAY more sense, because we never know the exact fuel content from a typical gas station. Ergo, we never really know what the actual stoich AFR is haha.
-06 MS6
chaser27 (12-03-2014), Deldran (12-03-2014), Easter Bunny (12-03-2014), TiGraySpeed6 (12-03-2014)
 Old 12-03-2014, 10:23 AM   #32
VT does not use boost targeting mode, only load targeting mode. The Boost Target table is not used. The boost limit tables in the Absolute Limits section are used.
Steve
Lead Tuner
The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post:
Deldran (12-03-2014), Easter Bunny (12-03-2014), Enki (12-03-2014), phate (12-03-2014), torquemaniac (08-02-2016)
 Old 12-03-2014, 10:31 AM   #33
Good question...I will check this tonight!
Edit : I wasnt sure if there was overload tables for fueling, but there is indeed for open loop and WOT...the overload fueling tables are different than the normal fueling tables (richer...), however, I cant say if they are related to the load limit force spark retard table because I dont have log with the OEM fueling tables (I changed the normal and overload fueling tables to the same since day one)
The Following 2 Users Say Thank You to torquemaniac For This Useful Post:
 Old 12-03-2014, 11:28 AM   #34
Enki's Avatar
Just to confirm, need to multiply maf curve by current AP scalar correct? This will fuck up the values from my existing load tune
 Old 12-03-2014, 11:35 AM   #35
Deldran's Avatar
Groans: 118
Yes. That's what I did, but I have not ran my e85 tune yet.
my 93 maf Cal is horrendous and I copied it straight from ATR and I do not know why. Hopefully it's not some major difference in how ATR and VT handle the maf tables.
 Old 12-03-2014, 11:51 AM   #36
Enki's Avatar
Horrendous how?
 Old 12-03-2014, 11:51 AM   #37
A formal VT E85 tuning guide is very very near.
Steve
Lead Tuner
The Following 10 Users Say Thank You to Steve@VersaTune For This Useful Post:
802MS3 (12-03-2014), chaser27 (12-03-2014), Deldran (12-03-2014), GrumpyMPS (12-05-2014), Micha (12-09-2014), mituc (12-03-2014), nindoja (12-03-2014), phate (12-03-2014), SarcasticOne (12-03-2014), TiGraySpeed6 (12-03-2014)
 Old 12-03-2014, 11:53 AM   #38
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I'm using VT and my tune currently has a MAF cal with less than 3% adjustments in some areas (probably only because the fuel on this side or the planet) initially exported from an AP tune.
I'd say that as long as the voltage points line up you're good to go. Take some MAF cal logs to check if everything looks right and that's it.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 12-03-2014, 11:55 AM   #39
Enki's Avatar
just so you know, it *SHOULD* be possible to calculate the scalar from the FSG, however, if your going to do that as a feature, it would be more user friendly to just input an ethanol percentage number instead.
 Old 12-03-2014, 11:55 AM   #40
If you copied all the fuel tables and MAF tables in the correct areas there shouldn't be a difference between AP and VT. Recheck the tables to start.
The AP AFR is scaled based on gasoline. So lambda 1 in the AP is 14.7 AFR. If you want an 11AFR you need to target 0.748 lambda in VT.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/how-switch-versatune-180913/
Who's using VersaTuner? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 12-05-2014 09:43 AM
? View topic - Switching from Cobb to VT This thread Refback 12-03-2014 09:50 AM
Versatune Arrived Alpha Wolf CX-7 > Turbo Induction & ECU Tuning 29 02-14-2014 07:06 AM
Hello from VersaTune Steve@VersaTune VersaTune 63 08-08-2013 12:20 AM
Versatune Help crashdan MazdaSpeed 3/6 - ECU Computer Tuning 17 09-04-2012 02:57 AM
Page generated in 0.66472 seconds with 34 queries
