Like Tree104Likes
 Old 05-19-2010, 12:20 PM   #1
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Default Hypertech Tuning Device Review
Well I ordered this thing Monday and got it today. Its like I have an extra 1000 rpms to actually use now, and the car pulls hard as shit to redline. I logged a fourth gear pull on my stock tune right before I installed it and did a 3rd-5th pull after putting about ten miles on the hypertech tune. I will post those when I get home from work if I can get my girlfriend's vista 32 bit to load the damn thing (my 64 bit vista will not run the DH software).
I hooked it up to my laptop, installed the updater, it updated the thing in like 2 minutes with the latest rev, next I plugged her up, its easy as hell to understand a fucking retarded baby could understand the shit. It asked me if I wanted to remove the 0-60 factory restriction, I of course said yes, then it asked if I had an aftermarket cold air kit installed, I said yes and selected the Cpe Xcel from the list so it could load the correct maf calibration, then it asked if I wanted to raise the factory rev limiter or factory top speed, I didnt see the need to do either of these so I said no to those. Then it started the install, took about 1 minute and it was done. I started it up and it runs smooth as butter, idle even sounds kinda different somehow, not as clacky and shitty sounding I guess?
Third gear I can actually pull hard to 80 now... Thats a hell of a lot better than the stock tune where it dies off at 5500 rpm. 100 mph comes really fucking fast as does 120. Bottom line, if you are on stock turbo and want a simple plug and play off the shelf tune that hauls ass, this is a great alternative.
See these threads on M247 if you want to read up on their tuning technique and more info.
Mazdaspeed 3/6 tuning info Part 1 - Mazda Forums
Mazdaspeed 3/6 tuning info Part 2 - Mazda Forums
Mazdaspeed 3/6 tuning info Part 3 - Mazda Forums
Here are a couple logs.
Edit: June 15th, here are a couple more logs after a month or so of running the tune, both are fifth gear logs and i didnt have enough road to run out fifth gear all the way, but i wanted to see how it held boost, and the boost looks pretty smooth to me. Pulls like a mofo even in fifth from 3500 rpm onwards. Fuel pressure still seems to be holding fine as well, doesnt dip below 1600 by more than like 5 psi or so according to my dashhawk.
Edit: July 12th, I added some more logs from after my txs catless dp install, looks like i will be needing a fuel pump next... You can see that the fuel pressure dips below 1400 right as peak boost is hit.
09 MGM MS3
The Following 19 Users Say Thank You to Addikted To Boost For This Useful Post:
banditscout (05-19-2010), Brian MP5T (07-07-2010), Dre (06-14-2010), felt (05-19-2010), ganque (06-01-2010), IshiKage (05-19-2010), JohnMS3 (05-19-2010), kgb (05-19-2010), MGM_GT3 (06-07-2010), MPSdriver (05-23-2010), ms3077 (05-23-2010), NewCar (04-02-2013), phillyb (05-19-2010), skeeter149 (05-19-2010), speed23 (01-16-2011), speed3spin (11-14-2010), SpeedNess (06-01-2010), whos_MS3 (11-07-2011)
 Old 05-19-2010, 12:29 PM   #2
boardjnky4's Avatar
Posts: 402   (View Stats)
boardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the world
Groaned at 40 Times in 22 Posts
Neutral  :  -1 score
It just seems like so much money for what it is
boardjnky4 is offline   Reply With Quote
 Old 05-19-2010, 12:50 PM   #3
I got it for 430 shipped, which is much less than 595 for an ap, granted it doesnt do all the fancy shit that cobb's ap can, but thats why i got it, because i didnt want all those extra features like ATR, because I would more than likely fuck something up.
machspeed3 likes this.
09 MGM MS3
The Following User Says Thank You to Addikted To Boost For This Useful Post:
karl-hungus (06-09-2010)
 Old 05-19-2010, 01:31 PM   #4
felt's Avatar
Posts: 1,504   (View Stats)
Groans: 1,364
It worked with your race pipe, but will it work for a Downpipe?
felt is offline   Reply With Quote
 Old 05-19-2010, 01:42 PM   #5
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
I got mine for about $400 with 2 K&N oil filters because of some promo code I found. Googled it and found that one of the first sites to pop up was the cheapest.
I like it but I'm not planning on ever getting a downpipe, maybe a test pipe and cbe. It does pull hard all the way to 6300 or so, that's as far as I take it. Next step for me is 1 step colder plugs and a TMIC. Then cdfp internals if I ever see mine drop off, still holds 1650-1700 at WOT. Hopefully I won't get into boost/fuel cut range with only intake side mods.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 05-19-2010, 03:23 PM   #6
damn i wish i would have googled it and gotten it for 400... did you get free shipping too?
09 MGM MS3
 Old 05-19-2010, 03:36 PM   #7
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
what was that code, i may pick one of these up
2015 Mazda 6
 Old 05-19-2010, 03:40 PM   #8
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
I agree completely, this thing is great. The tune is awesome smooth feeling as well. I definitely don't regret this buy one bit.
banditscout is offline   Reply With Quote
 Old 05-19-2010, 03:44 PM   #9
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
i like all that i hear about this thing. thanks for the review sir.
 Old 05-19-2010, 03:53 PM   #10
IshiKage's Avatar
Groans: 278
will it work with FMIC?
2015 Mazda 6
 Old 05-19-2010, 03:59 PM   #11
yea if you check out those links to m247, they say that the tune will respond really well to a new intercooler, whether it be front mount or aftermarket top mount, and i think there are a couple people running it with a downpipe already. Basically they say that the tune will be able to handle basically anything besides a bigger turbo.
tc0308 likes this.
09 MGM MS3
 Old 05-19-2010, 05:21 PM   #12
sideslide4life's Avatar
Posts: 147   (View Stats)
sideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the worldsideslide4life is the leader of the world
Neutral  :  -1 score
I got mine last Friday for 300 used. Runs great, I can really feel the difference in 1st and 2nd gear. I need more time to evaluate 3rd and up as I was on a gas mileage test, wound up with 32.5 mpg.
Mods: COBB SRI, PG Inlet, ebay test pipe.
sideslide4life is offline   Reply With Quote
 Old 05-19-2010, 06:15 PM   #13
ilocano_621's Avatar
Posts: 136   (View Stats)
ilocano_621 has a spectacular aura aboutilocano_621 has a spectacular aura about
what is the part number? Just want to make sure i'm getting the right one..
sideslide-why was it used..the previous ownr wasn't satisfied?..
"Tough times don't last tough people do"
ilocano_621 is offline   Reply With Quote
 Old 05-19-2010, 06:49 PM   #14
the part number is 62003
09 MGM MS3
 Old 05-19-2010, 06:54 PM   #15
Part number is 62003-same for all Mazda's I believe.
Previous owner went too far on mods for this to be useful. Went to the Accessport. Seemed perfect for me because I don't plan on a downpipe, only thing left for me power-wise I think is a new top mount intercooler, but that won't be for awhile.
 Old 05-19-2010, 07:18 PM   #16
IshiKage's Avatar
Groans: 278
awesome price, i need to come up on one like that
2015 Mazda 6
 Old 05-19-2010, 07:57 PM   #17
thanks..yah i'm looking to getting this on friday..Does anyone know how this holds up with a hks sri..I'm not looking to go crazy either after I get it my next one would be a CBE..any opinions on these couple mods with hypertech
 Old 05-19-2010, 07:59 PM   #18
read those links i posted and you will find your answers
09 MGM MS3
 Old 05-19-2010, 08:08 PM   #19
I did and did not see HKS SRI for their intakes that is why I'm asking around unless I missed. I saw their sheets with an aftrmrkt intake/exhaust with 288whp. I will def get a CBE just not sure with my SRI. Maybe I'm missing something?
 Old 05-19-2010, 08:14 PM   #20
bro2's Avatar
Posts: 384   (View Stats)
bro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the world
Everything I've read about these have been good so far. There is even a vid on youtube of a guy doing his stock tune vs hypertech on a dyno, I'm not sure how to link or I would. I emailed them and this summer they are going to be working on one for my car, so pumped.
2010 Mica black ms3 ~ cobb AP ~ cp-e nano/ AEM dryflow ~ TRZ rmm ~ 35% tint all around with 15% strip on top ~ 6k hid ~ nokya hyper yellow fogs ~ cp-e towplate
bro2 is offline   Reply With Quote
The Following User Says Thank You to bro2 For This Useful Post:
mattzke (03-07-2016)
 Old 05-19-2010, 08:15 PM   #21
They don't list every intake because they didn't test them all. I heard they brought back the car for COBB because it is a popular intake but I can't be certain. I chose the CP-e nano I think, as it is was comparable. I haven't had any issues yet, though its only been a week.
 Old 05-19-2010, 08:25 PM   #22
custommx3's Avatar
Posts: 12   (View Stats)
custommx3 will become famous soon enough
There will be an exhaust tune soon
2007 Mazdaspeed6
2009 CX-7
custommx3 is offline   Reply With Quote
 Old 05-19-2010, 08:27 PM   #23
felt's Avatar
Groans: 1,364
People, if it will compensate for a downpipe, it will definitely compensate for an intake not on their list.
 Old 05-20-2010, 06:06 AM   #24
yea they did mention they are working on something for a catback, due to the decreased backpressure.
09 MGM MS3
 Old 05-20-2010, 07:33 AM   #25
TenaciousBoost's Avatar
Posts: 245   (View Stats)
TenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the world
Groaned at 12 Times in 3 Posts
This seems almost too good to be true for my retarded ass. I want more power with minor bolt ons without having to tune myself via ATR, I knew it would just be a matter of time before I blew my shit up so I sold my accessport. Pending more positive reviews, I will be all over this hypertech tune like stink on phillyb..
TenaciousBoost is offline   Reply With Quote
 Old 05-20-2010, 07:55 AM   #26
dont wait too long they will probably start selling a lot of these as more reviews come out and will likely sell out at some point. I am like you and didnt want to mess with tuning myself and I like the fact that this tune calibrates the maf for my specific intake.
09 MGM MS3
 Old 05-20-2010, 07:58 AM   #27
5.000000yeah
ridenfish39's Avatar
Posts: 1,269   (View Stats)
ridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the world
Groans: 44
Groaned at 30 Times in 18 Posts
I can't wait until this comes out for the 2nd gen. I think most people (myself included) just want a few minor bolt ons and simple tune to give the car a little more uuumph without having to get the engine built.
2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL
ridenfish39 is offline   Reply With Quote
 Old 05-20-2010, 08:08 AM   #28
ANMSPD3's Avatar
Posts: 364   (View Stats)
ANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant futureANMSPD3 has a brilliant future
Works completly fine with mine.. Catless TXS
ANMSPD3 is offline   Reply With Quote
The Following User Says Thank You to ANMSPD3 For This Useful Post:
felt (05-20-2010)
The Following User Says NO Thank You to ANMSPD3 For This Un-useful Post:
 Old 05-20-2010, 08:10 AM   #29
are you still running your stock midpipe?
09 MGM MS3
 Old 05-20-2010, 09:21 AM   #30
custommx3's Avatar
Yea, but they are making them car specific. Meaning, they have purchased several exhausts for each vehicle and are tuning the cars based on each exhaust. Not a generic tune.
2007 Mazdaspeed6
2009 CX-7
 Old 05-20-2010, 12:08 PM   #31
hmm, i wonder which one would apply to me then, i have all three stock resonators cut out with a racing beat muffler from their ms3 catback kit welded in place of one of the stock resonators... its still 2.5" piping though so i dont know if I will be able to take advantage of the catback tunes...
09 MGM MS3
 Old 05-20-2010, 12:23 PM   #32
IshiKage's Avatar
Groans: 278
i dont see why not
2015 Mazda 6
 Old 05-20-2010, 12:25 PM   #33
Groans: 50
Everyone who's bought a hypertech should go and register it on the website because they'll email you any time there's an update available. That's what Chris@hypertech from 24/7 told me. He needs to become a vendor over here.
 Old 05-20-2010, 12:30 PM   #34
felt's Avatar
Groans: 1,364
He better have very thick skin
 Old 05-20-2010, 12:33 PM   #35
Groans: 50
haha, I wonder if he just decided not do come over here since we have a tendency to destroy vendors morale ....oops...
 Old 05-20-2010, 01:08 PM   #36
ANMSPD3's Avatar
Yes I am,An the sound is VERY nice.
 Old 05-20-2010, 02:23 PM   #37
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
I plan on ordering one tommorow...I was heavy into ATR and the AP but after blowing, I decided that I am not qualified for ATR and now with my current mods, this will work perfectly!
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
The Following User Says Thank You to kgb For This Useful Post:
MSMS3 (06-22-2012)
 Old 05-20-2010, 03:00 PM   #38
IshiKage's Avatar
Groans: 278
its good that he doesnt, no need for him to be harassed by the MSF experts that dont any results to back up all their "knowledge" of this platform.
pretty sure, at some point in time, CPE Jake would began talking shit too
2015 Mazda 6
 Old 05-20-2010, 08:44 PM   #39
iracer7's Avatar
Posts: 329   (View Stats)
iracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond repute
Hypertech - Max Energy Sport - Programmers - StreetSideAuto + coupon code vette = $357.58 shipped. Cheapest place I've found it, might get it for that price.
Cobb AP, CPE SRI, Cobb Turbo Inlet, Turbosmart Dual-Port BOV, ETS 3.5" TMIC, TRZ Rear Motor Mount, TurboXS Race Pipe, TWM Shifter Bushings, Dabears2k 35W 6000k HID's, Luminiacs 2500k halogen fogs, Putco brake light led bulbs, CPE tow plate, Cobb Springs, OZ Racing Ultraleggara Gold Wheels, weapon r torque damper
iracer7 is offline   Reply With Quote
The Following 2 Users Say Thank You to iracer7 For This Useful Post:
IshiKage (05-21-2010), leadf00t (05-25-2010)
 Old 05-20-2010, 08:45 PM   #40
added a link with new bullshit price that i found, fuck
09 MGM MS3
The Following 2 Users Say Thank You to Addikted To Boost For This Useful Post:
banditscout (05-21-2010), Blackrider (08-25-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/hypertech-tuning-device-review-56966/
gapping sparkplugs ? Mazda MPS Owners Club This thread Refback 01-01-2015 06:59 AM
gapping sparkplugs ? Mazda MPS Owners Club This thread Refback 10-21-2014 01:02 PM
gapping sparkplugs This thread Refback 08-14-2014 09:06 AM
Hypertech ! Review pour une Mazdaspeed 6 - Page 2 This thread Refback 03-27-2014 06:07 PM
Hypertech ECU tuning - Please post your user review :-) - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-15-2013 10:15 AM
Hypertech ECU tuning - Please post your user review :-) - Mazda3Forums.com This thread Refback 09-12-2012 06:20 PM
??? ?2 vs. ??? ?2. + ??? ?? ???????? This thread Refback 05-04-2012 06:00 AM
WBSearch This thread Refback 03-01-2012 05:09 AM
Hypertech ! Review pour une Mazdaspeed 6 This thread Refback 11-04-2011 02:26 PM
305whp/343 wtq - Dallasimports This thread Refback 08-14-2011 12:17 AM
FS: Hypertech Max Energy Sport Power Programmer MZ3/MS3 275$sold This thread Refback 06-06-2011 03:15 PM
FS: Hypertech Max Energy Sport Power Programmer MZ3/MS3 290$ shipped This thread Refback 05-21-2011 03:44 AM
FS: Hypertech Max Energy Sport Power Programmer MZ3/MS3 340$ shipped Obo This thread Refback 05-21-2011 12:28 AM
91 Bmw This thread Trackback: 02-09-2011 01:58 AM
Mazda MPS Owners Club • View topic - gapping sparkplugs This thread Refback 01-23-2011 10:13 AM
Mazda MPS Owners Club • View topic - gapping sparkplugs This thread Refback 01-09-2011 02:58 AM
Group Buy: Hypertech Max Energy Sport This thread Refback 11-11-2010 01:22 AM
Hypertech Max Energy Sport Review damianinpa MazdaSpeed 6 - Engine, Transmission & Driveline 55 07-27-2015 10:27 PM
Cobb Tuning Inlet Review Discussion Haltech Review Discussion 62 06-03-2011 06:16 AM
Hypertech Tuning Device holeinmypocket MazdaSpeed 3/6 - ECU Computer Tuning 214 07-06-2010 08:35 PM
Cobb Tuning Catback Exhaust Review Haltech Review Discussion 13 05-07-2010 12:16 AM
Cobb Tuning 3" 07-08 MazdaSpeed3 Street Downpipe Review Haltech Mazdaspeed Forums Performance Parts Reviews 0 12-01-2008 03:08 AM
Page generated in 0.60624 seconds with 36 queries
