 Old 12-05-2010, 12:52 AM   #1
Originally Posted by Christian. View Post
I debated that, but I wanted to explain things in an easy to understand manner so I thought stating boost before WGDC was best. It would not matter if WGDC or Boost was first...this system is pretty damn fast with boost control and it operates in a closed-loop manner with MAP delta feedback.
Christian.
If you've played around with this, how much do initial conditions matter? In other words if I start with 100% in the WGDC table, how much does the boost overshoot for example?
Also, say there is a MAP sensor failure, does the ECU revert to using the WGDC table only?
djuosnteisn (12-05-2010), FreeFlyFreak (12-06-2010)
 Old 12-05-2010, 09:47 AM   #2
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
how does this boost based switch affect ignition timing? since the ecu doesn't use full set timing if not necessary with achieved load. (or is that even correct?)
With constant boost, you'll have varying load. For instance 15psi in 100 degree weather would result in much lower load (air flow) than in 30 degree weather (and 100 degree weather would be quite a bit slower). The ign advance will be calculated as normally for that given rpm and load point.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
dougefresh_ (05-03-2011), jwilkins88 (12-05-2010), m4tic (12-05-2010), Micha (01-04-2015), rfinkle2 (03-19-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/initial-details-into-how-boost-based-tuning-66400/
Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-12-2011 06:14 PM
Volkswagen releases initial pics, details on all-new Caddy Haltech Automotive News 0 07-22-2010 04:50 PM
Initial Impressions of Grimmspeed Boost Solenoid tbot MazdaSpeed 3/6 - ECU Computer Tuning 44 04-14-2010 04:45 PM
Please educate me on a few details of how the turbo on this car works... Smokehouse MazdaSpeed 3 - Engine, Transmission & Driveline 28 01-02-2009 04:05 PM
Page generated in 0.26737 seconds with 23 queries
