 Old 12-05-2010, 04:14 PM   #1
evidence's Avatar
Posts: 1,033   (View Stats)
Originally Posted by manelscout4life View Post
I asked Christian about this and he told me the car should target the same boost targets even with changing weather conditions
Point is though (this is the reason many people prefer the stock load system), if your running 20psi in the summer and pushing the limits, you might not want to be running this same boost in the winter. It would result in much higher loads and stress on the engine.
I suppose the only reason to run a boost setup like this is if you can't get your per gear set up properly, or don't want to bother with it? Configuring with the boost setup seems simpler. Losing unique configs for gears 1 and 2 make this even more a deal breaker for me also.
Some things.
The Following 5 Users Say Thank You to evidence For This Useful Post:
Dano (12-07-2010), djuosnteisn (12-06-2010), Fobio (12-08-2010), FreeFlyFreak (12-06-2010), speed23 (12-05-2010)
 Old 12-05-2010, 04:27 PM   #2
fjames's Avatar
Posts: 1,058   (View Stats)
The same is true in reverse for load tuning though. If you tune for max, safe load in cold weather, you'll be in for some pain trying to push enough boost to meet that load target in the summer.
I'm trying the boost toggle today and loving it (ambient 28F.) I have enough experience to know what boost my car can run year round so no problems there. With my max boost at max summer setting, I get 20x load reported, so no problems there.
The huge thing for me is it's much, much smoother to drive. Christian or Trey mentioned in passing that this might happen, but didn't offer an explanation. On a pair of 4-5 shifts I got no, and just a smidge of spike, so that's interesting. Just preliminary, but so far it's looking very promising for a DD.
The Following 5 Users Say Thank You to fjames For This Useful Post:
08_ms3_gt (12-07-2010), evidence (12-05-2010), Fobio (12-08-2010), FreeFlyFreak (12-06-2010), rfinkle2 (03-19-2011)
 Old 12-05-2010, 04:31 PM   #3
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
On the map Christian worked on is hitting 18psi with an ambient of around 34 degrees, my calculated load is showing as 2.29 which I'm guess is 229. Is this too much load?
Heres my log:
http://www.mazdaspeedforum.org/forum/foru...-fmic-bt-e.csv
 Old 12-05-2010, 04:58 PM   #4
fjames's Avatar
You can't really compare loads car to car because the MAF cal will be different. I just go by what the 2871 guys see, and what fully bolted guys see, compared to me. My conclusion is anything that starts with "2" is probably okay if boost is in line. In other words, if you were running 22 psi to get that load, you should be worried, but at 18 psi, you're in the safe zone for performance tuning (which is inherently unsafe.)
Your AFR is pretty erratic and you know your pressure is fucked. I wouldn't be doing anymore logging or aggressive driving until you get that fixed.
The Following 2 Users Say Thank You to fjames For This Useful Post:
manelscout4life (12-06-2010), rfinkle2 (03-19-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/initial-details-into-how-boost-based-tuning-66400/
Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-12-2011 06:14 PM
Volkswagen releases initial pics, details on all-new Caddy Haltech Automotive News 0 07-22-2010 04:50 PM
Initial Impressions of Grimmspeed Boost Solenoid tbot MazdaSpeed 3/6 - ECU Computer Tuning 44 04-14-2010 04:45 PM
Please educate me on a few details of how the turbo on this car works... Smokehouse MazdaSpeed 3 - Engine, Transmission & Driveline 28 01-02-2009 04:05 PM
Page generated in 0.29804 seconds with 24 queries
