| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() | | #41 | ![]() |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
| Not Ranked : 0 score and @stealth your first comment had me laughing so hard, It would have been even better If we could shop a picture of Lex in a wheel chair bald etc. this does address my concerns with knock thanks lex
__________________ New: 2012 Mazda MX5 Miata True Red |
![]() | | #42 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | silvapain (01-20-2012) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Here's a spiffy bit of KR for ya- sadly the log does not include APP or coolant temp, and I've asked that he include them in the future. I have asked the owner if his speed6 was up to operating temp, or if he had a batch of bad/cheap gas, but haven't heard yet... I'll be sending a link to this post, hopefully he'll chime in if ya'll have any questions-
![]() | | #44 | ![]() |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | rfinkle2 (01-20-2012), TiGraySpeed6 (01-20-2012) |
![]() | | #45 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score I think I had already figured it out. Recently changed the open loop overload timing to match my normal table (following what I saw in a ots map) For some reason in 5th I seem to be hitting over my target which I'm guessing is why this is happening. I had advanced the normal table quite a bit previously. Just running in a new revision now, I'll let you know how it goes.
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
| The Following User Says Thank You to skiptowncat For This Useful Post: | rfinkle2 (01-20-2012) |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score In any car you will see engine load go up as you go up in gear. The resistance to acceleration is higher so the engine will work harder and for longer. This increases the components that generate knock and these are cylinder pressure, temperature, and boost. As a rule of thumb, I look at mostly 4th gear when tuning because it will expose KR more readily than 3rd and running 5th to redline gets dicey in most areas.
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #47 | ![]() |
| Not Ranked : 0 score I miss Rodrigo's Xtranormal vids...he put alot of work into those...need to lookup the two really long ones about MSF gossip...too funny. IIRC I get hacked in one of them ![]() oh and great writeup lex...as always you are very clear and concise...
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following User Says Thank You to Dano For This Useful Post: | Cataphract_40 (01-21-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score Oh come on, just because you'd be doing 130....sheesh.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
| The Following User Says NO Thank You to Stealth01 For This Un-useful Post: | skiptowncat (01-24-2012) |
![]() | | #49 | ![]() |
![]() Join Date: May 2009 Location: Calgary
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 892
| Not Ranked : 0 score i get a LOT of part throttle/low load KR nowadays but i never used to... infact i remember logging 20-30 mins for pretty mixed and spirited driving one night and only finding a few instances of knock in the whole the whole log. i wonder what could have caused the change?? also every time i shift i get a fair amount too... i'm hoping it's just a mount wearing or something. |
![]() | | #50 | ![]() |
It could be that your load values you are hitting in the cold months are different, and the timing @ those load values is also different. There is also a multiplier in one of the tables that is based on coolant temp if your car is now running a bit cooler, it may be allowing for slightly more timing. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | bigriver (01-25-2012) |
![]() | | #51 | ![]() |
so are you saying that you think a possible change in timing is causing real knock then?? should i be worried?? i feel as if my car is always a few mins away from blowing lol | |
| The Following User Says Thank You to TriO For This Useful Post: | rfinkle2 (01-24-2012) |
![]() | | #52 | ![]() |
Even @ wot, you are almost never going to see 0 KR. | |
![]() | | #53 | ![]() |
| Not Ranked : 0 score Check out these logs then. Just installed new internals and downpipe and now on a slightly tweaked OTS stage 2 map. Went out to do a MAF cal and a few pulls... keep getting knock with the MAF cals but none whatsoever @ WOT... Any ideas/comments? |
| The Following User Says Thank You to TriO For This Useful Post: | rfinkle2 (01-28-2012) |
![]() | | #54 | ![]() |
I'm not answering for him, nor saying I am as experienced as he is, but your maf cal log fits with many of the posts I've seen him make concerning PT KR. | |
![]() | | #55 | ![]() |
| Not Ranked : 0 score wow that looks like something loose in/around the motor but strange that you don't see it at WOT...the harmonics must be different enough at WOT to prevent it. look around in there to see if any piping is touching the frame or even very close. Also see if anything else is lose.
![]() | | #56 | ![]() |
![]() Join Date: Nov 2011 Location: Orlando FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score lol im getting alot of kr but its below 2.. |
![]() | | #57 | ![]() |
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score hey guys sorry for the nob question, but I'm seeing late on my AP the KR reading 8.0 So I'm really not sure if this really means 8.0 of KR, that's why I'm asking just to make sure. The weird thing is that it's happening when cruising at the time I wasn't punching the car when I'm suddenly reading this on the AP. So no load on the engine when this is happening. My tuning is not completed yet. There is still the regular gas pump to be tune out. Anyone else seeing this?
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. Last edited by bertrand_CX_7; 02-08-2012 at 08:56 AM. Reason: yes 8.0 is KR |
| The Following User Says Thank You to bertrand_CX_7 For This Useful Post: | yurples (02-22-2013) |
![]() | | #58 | ![]() |
| Banned ![]() Join Date: Apr 2011 Location: florissant, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score im going anywhere from 3.5 to 5.6 kr on my logs with the tune i have, im putting my tune back to stock till i get hpfp internals!!! datalog.xlsx |
![]() | | #59 | ![]() |
![]() Join Date: May 2011 Location: Orlando, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,305
Groans: 386
| Not Ranked : 0 score how about something like this: anything out of the ordinary besides fuel pressure? Does not having enough fuel cause knock this high? Not mine.
__________________ BNR3-FREEK-PU-398HP I lost track of the mods in my car. |
![]() | | #60 | ![]() |
| Not Ranked : 0 score I sincerely hope my eyes are deceiving me and you are not running 16AFR at WOT 22PSI and 5+KR. if so please pull your plugs asap and see if there is any insulator left on them.
![]() | | #61 | ![]() |
Groans: 386
| Not Ranked : 0 score was that directed at me? if so it's not my log, again. A person online was experiencing some knock and come to find out, it was a lot more.
![]() | | #62 | ![]() |
| Not Ranked : 0 score Yes toward you but glad that wasn't your log . It was UGLYTappin
![]() | | #63 | ![]() |
Groans: 386
| Not Ranked : 0 score Yes it is. Now back to my question, would dropping fuel pressure cause knock that high? Or is there something else going on that I'm not seeing?
![]() | | #64 | ![]() |
| Not Ranked : 0 score this is my log lol. this is a log i made after installing a stage1 sure aeros+93octane tune on my AP, its at 16psi. not 22. i took the tune off my ap and loaded the factory settings back onto my ecu |
![]() | | #65 | ![]() |
![]() | | #66 | ![]() |
![]() | | #67 | ![]() |
yes the tune is no bueno. you can run a Stage 0 map and still keep the AP installed and get more logs.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 02-15-2012 at 02:46 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #68 | ![]() |
Last edited by woodsmsp; 02-15-2012 at 02:50 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to woodsmsp For This Useful Post: | Cyrius (03-18-2012) |
![]() | | #69 | ![]() |
It can also be caused by other noise as described in this thread. If you want to know if it's real knock, put 2-3 gallons of E85 in your tank when you next fill up and see if its gone. If the KR i still there at WOT it's noise from something else.
![]() | | #70 | ![]() |
| The Following User Says Thank You to woodsmsp For This Useful Post: | Lex (02-15-2012) |
![]() | | #71 | ![]() |
fuel pump or internals will get your pressure right.
![]() | | #72 | ![]() |
| Not Ranked : 0 score I'm seeing KR of 1.5-2.5@ ~4.5k all of a sudden, I have tried making afr richer, reducing timing and load but it's still there. I'm gonna put the side mounts in and see if that shifts it.
![]() | | #73 | ![]() |
![]() | | #74 | ![]() |
![]() Join Date: Mar 2011 Location: Owasso, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score I installed my CP-E fuel pump tonight and did some logging. I noticed some high KR near the redline (sorry for my mediocre log, it is row 367. Should I be worried about this? |
![]() | | #75 | ![]() |
| Not Ranked : 0 score Oh shit, I didn't even notice the 6's. 354-381 is full of knocking. |
![]() | | #76 | ![]() |
| Not Ranked : 0 score Your afr's are way too rich... and timing is almost OTS.... which both make for very high EGTs. I wonder if that's contributing. Regardless, your car is not happy, and likely detonating. You could use a tune man.... or at least try a different OTS map, or pull fuel yourself. Should help.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | knarfies (03-16-2012) |
![]() | | #77 | ![]() |
(Thread Starter) | Not Ranked : 0 score Those 5s and 6s that just happen all of a sudden smell suspiciously like mechanical noise ... cars that I see do this generally have an issue with something internal to the engine. A compression test won't hurt.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | djuosnteisn (03-15-2012), knarfies (03-16-2012) |
![]() | | #78 | ![]() |
What should I look for regarding mechanical noise? I read another thread about the chain being loose, VVT,whatnot but I'm lost as to where to look. If all fails, I might just go for a nice tune. Only downside is I plan to upgrade to stage 2 in the future, so I'd hate to pay twice for the service. | |
![]() | | #79 | ![]() |
| Not Ranked : 0 score You should try to determine if the KR is noise induced, or actual. You can do this by increasing the octane of the fuel.. (throwing in 2 gallons of e85 to a full tank of premium)... If the KR disappears.. then it was real. If it remains, then it's likely mechanical. Most common causes for mechanical noise are things rattling in the engine bay, and banging against the motor (or intake mani / exh mani), or injector seals, or VVT as you stated. If the KR is deemed real... then you should try a few other OTS maps... but read the help file, and don't go wot on them right away. Let the ECU learn fuel trims, and if the trims look decent, then try a single wot pull, and see if there is any KR, and how your AFR and boost look.
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | atvfreek (03-16-2012), knarfies (03-16-2012), Lex (03-16-2012), Sideswipe (04-11-2012), TiGraySpeed6 (03-16-2012) |
![]() | | #80 | ![]() |
![]() Join Date: Feb 2012 Location: weslaco, texas
Groaned at 9 Times in 3 Posts
| Not Ranked : 0 score I hate knock. Last night i reflashed my 6 and it would go up to 2.8 and even at 5 sometimes under heavy driving. Scared the crap out of me so i went to stage one instead
__________________ Current mods installed: greddy type rs bov, autometer boost gauge, magnaflow exhaust, su sri, 3" downpipe, kmd v.2 internals, cobb ap, dreadnaught, juggernaught, whiteline adj. rear sway bar, sure rmm, cx racing fmic, h&r springs, drag wheels, autolite plugs Parts awaiting install: k1 rods, jbr egr block off plate, weisco pistons, 3 bar map sensor and pnp harness, stratified 3 port ebcs, cpe safe seals Parts awaiting order: gtx3071r, SURE 3.25" intake Currently Freek Tuned on pump gas and e85 50/50 |
| Boost Control Explained - EBC / MBC | flyrevs2 | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 02-19-2010 12:04 PM |
| PID tuning explained | wassup61 | Mazdaspeed3/6 General Discussion | 7 | 03-21-2009 09:47 AM |
