 Old 07-03-2011, 12:58 AM   #1
proudsoldier28's Avatar
Posts: 37   (View Stats)
proudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond reputeproudsoldier28 has a reputation beyond repute
Groaned at 6 Times in 1 Post
Default Lost in log
Im a noob and all the numbers confuse me
proudsoldier28 is offline   Reply With Quote
 Old 07-03-2011, 01:12 AM   #2
IMASA's Avatar
Posts: 209   (View Stats)
Not too bad, but consider getting a new fuel pump or internals. Your AFR's dip into the 12's when your pump is down to 1000psi, though you're not getting any KR.
 Old 07-03-2011, 07:17 AM   #3
ok thank you thats what i was trying to see and thats on a stage 1 map i cant even run a stage 2 with my ap my fuel psi drops way low
 Old 07-03-2011, 08:51 AM   #4
Default another from last night a better log imo
Log from last night a little better i want to do a cal on it but im still confused
 Old 07-03-2011, 11:55 AM   #5
IMASA's Avatar
Looks decent, KR <1.0, just dropping fuel pressure.
What are your AFR targets? Read up on Abilor's tooning guide, do the closed/open look fixes. Might want to drop the boost til you get a new pump.
 Old 07-03-2011, 03:21 PM   #6
ive read threw his tooning guide but still find myself lost
 Old 07-03-2011, 04:52 PM   #7
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Yea i wouldnt wail on it too much until you fix the fuel pump. Not much in the way of tuning for more power until you do that.
You could do a maf cal but you would need to do a log specifically for that (maf g/s and volts, STFT and LTFT)
KILLAH BUILT
 Old 07-03-2011, 08:48 PM   #8
Abilor's Avatar
Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Posts: 839   (View Stats)
Abilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the world
What mods do you have? Maybe post in sig.
Traded
Abilor is offline   Reply With Quote
 Old 07-03-2011, 08:50 PM   #9
sorry about to set that up i have cpe tmic cpe intake hks seq II bov (atmo) cobb turbo inlet m2 dp borla cbe cobb ap
 Old 07-03-2011, 08:58 PM   #10
Abilor's Avatar
Ok, and what map are you rocking right now?
Wow. You could really tear it up with fuel pump internals.
Traded
Last edited by Abilor; 07-03-2011 at 08:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-03-2011, 09:25 PM   #11
Im running a stage 1 map
cpe intake cobb turbo inlet hks bov (atmo) w2 dp borla cbe cobb ap
 Old 07-09-2011, 07:19 PM   #12
Abilor's Avatar
You have a DP installed though?
Traded
 Old 07-11-2011, 11:35 AM   #13
yes
So..Lost my key and FOB...help? HOW TO.. the95z MazdaSpeed 3 - How-To's 42 02-20-2015 09:55 PM
Lost Acceleration lwrees72 2010 MS3 - Engine, Transmission & Driveline 39 08-22-2012 06:40 PM
Page generated in 0.31387 seconds with 24 queries
