 Old 07-24-2013, 01:37 PM   #1
neil123456's Avatar
Posts: 27   (View Stats)
neil123456 is on a distinguished road
Groaned at 14 Times in 2 Posts
Default Maf cal Confusion
First of all thanks for all the information on the forum regarding self tuning using the Cobb AP, I have spent hours reading and has informed me so much however I do have a question (after reading Abilors guide, Buckers guide and loads of threads).
I know how to perform a closed loop maf cal and input the correction in the "MAF Table A&B," but if I do a WOT maf am right in saying that I will make the corrections in the same tables (MAF Table A&B)? I know that I will only correct the cells that are out (as long as there was no knock)?
Any help appreciated
neil123456 is offline   Reply With Quote
 Old 07-24-2013, 01:48 PM   #2
Neubreed's Avatar
Posts: 401   (View Stats)
Neubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the worldNeubreed is the leader of the world
Correct, you continue from where you left off at with the CL adjustments.
-07 CBM MS3-
Neubreed is offline   Reply With Quote
 Old 07-24-2013, 01:48 PM   #3
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
You are correct. Just follow your log cell by cell and you should be able to get the AFR to look like a tabletop on your VD.
If you do get KR you will see the effect before and after the actual KR event. Just ignore that area on that log and work the rest of the cells.
 Old 07-25-2013, 12:39 AM   #4
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Yes you will still make the changes in MAF Table A/B.
www.tunedbynishan.com
Confusion about map descriptions... JDMJOSH
Cobb Access Port/Maps
0 02-09-2013 10:20 PM
MAF Cal Breakpoint/General Confusion andrewpiro MazdaSpeed 3/6 - ECU Computer Tuning 0 05-03-2012 05:39 PM
MAF Cal confusion omgheyitskenny MazdaSpeed 3/6 - ECU Computer Tuning 12 05-01-2012 01:38 PM
Tuning Confusion... MS3KO MazdaSpeed 3/6 - ECU Computer Tuning 6 04-07-2010 11:52 AM
Page generated in 0.25637 seconds with 23 queries
