 Old 04-10-2014, 09:19 PM   #1
alklein6's Avatar
Posts: 42   (View Stats)
alklein6 is a glorious beacon of lightalklein6 is a glorious beacon of lightalklein6 is a glorious beacon of lightalklein6 is a glorious beacon of lightalklein6 is a glorious beacon of lightalklein6 is a glorious beacon of light
Default Need an etune
Richtune or Freaktune?
alklein6 is offline   Reply With Quote
 Old 04-10-2014, 09:21 PM   #2
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
you will be in good hands with either of them
nilashish is offline   Reply With Quote
The Following 3 Users Say Thank You to nilashish For This Useful Post:
calizoomzoom (04-10-2014), InkedInspector (04-10-2014), snailD (04-10-2014)
 Old 04-10-2014, 09:23 PM   #3
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
calizoomzoom (04-10-2014), ms6mil (04-10-2014)
 Old 04-10-2014, 09:24 PM   #4
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
Im currently working with richtune.. but both are very reputable as far as i know. Of course everyone will vote for whoever tuned them...
calizoomzoom is offline   Reply With Quote
 Old 04-10-2014, 09:27 PM   #5
alklein6's Avatar
I agree with that. I'd just like to hear the bad. Curious is all. I tried buying Freaktune today. And it's "out of stock". So he isn't taking new customers on right now. So weighing options. I should have got it last week I guess
 Old 04-10-2014, 09:30 PM   #6
Yea hes on high demand. lol. I was kind of on an ASAP situation as well. and Richtune will send you a map within 48 hours of your logs. So I should be done this month
 Old 04-10-2014, 09:35 PM   #7
nilashish's Avatar
I have not heard any negative comments about either but i will let the people who have been tuned by them chime in...may I also suggest Stratified. Lex is extremely helpful and knowledgeable...again never heard any complains about Stratified either
 Old 04-10-2014, 09:39 PM   #8
alklein6's Avatar
Do we know who can start ASAP?
 Old 04-10-2014, 09:42 PM   #9
nilashish's Avatar
I see that Stratified has tunes in stock so you can purchase them...from my experience, Lex has been prompt with his communication so might ask him before purchasing how quickly you will get the initial map
 Old 04-10-2014, 09:44 PM   #10
same with Richtune... He started next day after payment
 Old 04-10-2014, 10:38 PM   #11
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Richtune has always been quick to get new maps to me. I was very pleased with the results of the 93 tune.
Currently near the end of a 50/50 E85 tune and have been impressive so far. My VVT decided to die on me so we haven't been able to finish, but I plan on fixing it next week so we should be able to finish soon.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 04-10-2014, 11:05 PM   #12
sidekick's Avatar
Posts: 3,093   (View Stats)
If freektune is not available, why not go stratified?
snailD (04-10-2014)
 Old 04-10-2014, 11:08 PM   #13
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
Richtune FTW
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
 Old 04-10-2014, 11:12 PM   #14
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
I thought someone else was tuning you???
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 04-10-2014, 11:12 PM   #15
snailD's Avatar
Posts: 3,039   (View Stats)
i'd back any of the msf tuners. Rich, Freek, Stratified
 Old 04-10-2014, 11:35 PM   #16
SnowWhiteMs3's Avatar
Posts: 28   (View Stats)
SnowWhiteMs3 is on a distinguished road
I haven't gotten any turning done myself by them but I haven't ever heard one bad thing
SnowWhiteMs3 is offline   Reply With Quote
 Old 04-10-2014, 11:48 PM   #17
NavySailorMS3's Avatar
Posts: 1,436   (View Stats)
NavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the world
Groaned at 31 Times in 28 Posts
FlowTune, figured I would throw it out there since he got me close to 400whp.
GoFastParts
BNR s3 / \ / \ FlowTuned /\ Cobb APv3 / \ Sure SRI / \ Sure TIP / \ Corksport DownPipe / \ Corksport Testpipe / \ CNT CBE / \ HKS BPV / \ Autotech HPFP / \ Custom FMIC / \ CP-E Seals / \ NGK 1 step colder plugs / \ JBR coolant bypass / \ JBR TB TIG / \ JBR IM TIG / \ Grimmspeed EBCS / \ Bosch 3 bar / \ MD EGR Delete / \ MD OCC / \ JBR Trilogy MM
Suspension
ICS N1 Coilovers / \ JBR RSB / \ SPC Camber Arms / \ EVO X Wheels
You can sprinkle green on it all you want, but its still a brownie!!!
NavySailorMS3 is offline   Reply With Quote
 Old 04-10-2014, 11:55 PM   #18
Where are you located
 Old 04-11-2014, 12:51 AM   #19
I was man. But I had some issues that backed me up a lil bit, and "said tuner" decided he wasnt going to respond to any of my emails after the problem got fixed. I didnt feel like kissin this man's ass to tune my shit so i paid richtune..
 Old 04-11-2014, 02:44 AM   #20
Playaj's Avatar
Damn that sucks bro
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 04-11-2014, 03:56 AM   #21
alklein6's Avatar
Jax fl
 Old 04-11-2014, 04:07 AM   #22
alklein6's Avatar
here is my latest WOT 4th gear pull just logged on tuesday. I posted this on another thread too and some are saying too lean. I have the stage 2 93, tih, hpfp otd from cobb loaded.
 Old 04-11-2014, 12:08 PM   #23
Playaj's Avatar
Why are you running stage 2?
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
The Following User Says Thank You to Playaj For This Useful Post:
calizoomzoom (04-11-2014)
 Old 04-11-2014, 06:01 PM   #24
alklein6's Avatar
O you mean with a stock ms3 I shouldn't run a stage 2?
Jk
I felt that with the mods I had it's fine. Now I looked at some of my older logs even before I did the dp and they were just as lean guys
Etune or Protune? NICKELL666 Mazdaspeed3/6 General Discussion 105 04-30-2014 09:02 PM
Looking for etune Jrs7686 2010 MS3 - ECU Computer Tuning 15 09-12-2012 11:02 AM
Looking for a pro to eTune my gen1 MazdaSpeed3NY MazdaSpeed 3/6 - ECU Computer Tuning 6 08-28-2012 06:24 PM
Out of the country or too far away? Get a eTune ! John@TheShopCT Mazdaspeed3/6 General Discussion 12 01-02-2011 12:14 AM
etune tomsnatchez MazdaSpeed 3/6 - ECU Computer Tuning 12 12-29-2010 12:48 PM
Page generated in 0.41902 seconds with 31 queries
